#1 |
What's a Dremel?
Lament Configuration // Finished.
![]() hello friends // hola amigos, This project is inspired by the hellraiser cube called "Lament Configuration".//este proyecto esta inspirado en el cubo de hellraiser llamado "lament configuration". This is a work that is started of zero, and the main materials are aluminum and acrylic.//Es un trabajo comenzando de cero, y los materiales principales serán, aluminio y acrílico. ![]() ![]() angle of aluminum: 8/4 x 1/8 acrylic: white 3mm x 32cm and black 2mm x 32 cm ![]() ![]() L + screw ![]() start drawing // inicio del dibujo ![]() beginning of the draft // inicio del calado ![]() ![]() filing // limado and video: test manual jigsaw the real duration of the video is 36 minutes more pics: ![]() ![]() ![]() ![]()
#2 |
What's a Dremel?
Usb 2.0 that will be use for this mod // usb 2.0 que serán utilizados para este mod:
![]() It is giving form to the cube // dando forma al cubo: ![]() ![]() It is joining the acrilic plaque to the metallic structure // Uniendo la placa de acrilico a la estructura metalica: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() At finally the base for the hd // por ultimo la base para el hd: ![]() Later of search much,( in Colombia is difficult find coolermaster), i could find a coolermaster´s ventilator: luego de buscar tanto,(en Colombia es dificil conseguir coolermaster), logre conseguir un ventilador coolermaster ![]() me dispuse a hacer el motherboard tray de una lata de un case viejo i resolved to make the motherboard tray of a tin of a old case ![]() doblar bend ![]() lijar sand ![]() Remachar rivet ![]() ![]() ![]() ![]() yes, i know, it doesn´t totally sanding, the sandpaper is finished, but i decided change the motherboard tray cause it didn´t like me, i have another idea. later, i will finish of assemble the cube´s structure cute the the platens at angles of 45 degrees Si lo se no esta totalmente lijado, se me acabo la lija , pero decidi cambiar el motherboard tray no me gusto, ya tengo otra idea. luego terminar de armar la estructura del cubo. cortar las platinas en angulo de 45 grados ![]() y claro esta unirlas al cubo: and of course join it to the cube ![]() ![]() y agregar soportes adicionales: and add aditional supports ![]() + acrylic ![]() ![]() luego a dibujar: later to draw ![]() ![]() http://www.youtube.com/watch?v=oKaY_ItALqQ Muchas gracias a los que siguen mi humilde trabajo. thank you very much to people that follow my humble work. |
#3 |
Multimodder
great start.
Reminds me of Pandoras box somehow. |
#4 |
What's a Dremel?
*well friends, the advances of yesterday were:
Adaptation of the slide to set the pci, ![]() 4 discs while, ![]() ![]() then mount the images and sanding and that Diseño del motherboard tray para pintado posterior. *design of the motherboard tray then paint it. ![]() ![]() Cortando angulo para unir el motherboard tray con los rieles,Perforaciones para los remaches,fijación del riel,Mothertray montado,con hardware de prueba (board no prende y tarjeta de video con artifacts). * Cutting angle to attach the motherboard tray to the rails, ![]() ![]() ![]() holes for rivets, ![]() ![]() fixing the rail, ![]() Assembled Mothertray, ![]() ![]() ![]() ![]() With test hardware (board does not turn video card with artifacts) ![]() ![]() fije los angulos para la fuente (lata de fuente generica, sera removida), angles set to the source (source can of generic, will be removed) ![]() pintura a la base de la board, *paint the board´s base. ![]() ![]() 2 capas de pintura + lijado, *2 layers of paint +sanding ![]() corte del logo de Cooler Master, *cut the cooler Master´s logo ![]() ![]() Corte de las letras, *cut of the letters. ![]() ![]() ![]() ![]() So let make the outer cube frame, dimensions 53cm height x 53cm width x 43cm length. Cutting: ![]() Join the pieces together: ![]() mmmm Thank you my friend but I don't have any Welding, so I have to go this way: ![]() ![]() ![]() ![]() Outer Cube Frame (Completed) ![]() Setting up the fan for the Power supply: ![]() ![]() Adaptation for wiring the power supply: ![]() ![]() ![]() ![]() ![]() ![]() ![]() This fan goes in the same as the power supply but in the bottom section, it will work as intake. ![]() Now is time for the Cooler Master's fan ![]() ![]() Mounted: ![]() in the case and working: ![]() ![]() ![]() fron the other side: ![]() ![]() Cut: ![]() bending and perforated: ![]() and then rivet: ![]() Test, ![]() ![]() before: ![]() after: ![]() I bought some brackets and steel rope to hold the cube in place: ![]() ![]() ![]() Then I cut a piece of black acrylic and installed the invisible swith, you will be able to see it when it’s on: ![]() ![]() Sleeving the Cathodes: ![]() ![]() Opening system for the door, the hinges are from chain parts: ![]() Installing the Power Supply: ![]() Details on the Rear Panel: ![]() Installing Hardware: ![]() ![]() Small Gallery, tomorrow more updates: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Cuando tomaba fotos, timbraron en mi hogar y era mi disipador Hyper N620 presentado por la modelo ![]() ![]() ![]() Stock vs Hyper ![]() Instalado: ![]()
| Tags |
| configuration, lament, mod, modding, tortured |
| Thread Tools | |
| View Mode | |
