Scratch Build – In Progress octTower - Completed - Final photos round II
Discussion in 'Project Logs' started by craig - toyoracer, 25 Aug 2011.
  1. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Hello Bit-Tech, my name is Craig, -toyoracer on some other sites. I am from Canada, and have come here to share in the modding spirit and fun you all have created.
    So how did I get here. It all started back in '91 when my kids were given a 8088 to play with, so smart dad took charge (oh no) ended up changing some system files (logical naming is not in the computer world) Computer no longer worked, friend from work took hours to solve and then said to me Never,Never touch a computer again, back to the couch I went.
    Fast-forward '06 new wife and 16 year old son, who is into Computers. Well he gives me his old one and tells me the basics (I forget) tells me again, next day I forget, what, "old dog learns slow" I don't have time to teach an old slow dog, use "google" and read and learn. Tough lovin, smart kid.
    2010 I am ready to build my first PC.
    Goal: Design and build a nice looking case, that pushes my skills upward.
    Design : Unique theme that is more than just a rectangle box. Clean lines with no fasteners showing. Black (goes with any livingroom the wife might come up with) chrome (can't do that) polished aluminum, I can.
    I began construction June 2010. Using steel 20AWG for base panel and 22AWG for the rest. Bending is done with bench-top 700mm brake. All joining will be done by soldering frame panels.
    Lets start with holes made first and then bent up forming front panels
    top panel
    channel formed
    and soldered, with motherboard mounting inserts
    formed base plate with rolled edge
    intake holes and formed fan mount
    lower front intake blank, then bent up
    test fitting
    NoobNeb and peteski like this.
  2. Attila
    Attila still thinking....
    22 Feb 2008
    Nice start Craig. :thumb: The photos also show a nice work space. I'll be following. :)
  3. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    Only a years worth of photo's to catch up on!
    Looking good so far.
  4. craig - toyoracer
    1 Mar 2011
    Attila thank you :) fitting for you to have first post since your suggestion led me here.
    The shop is at dad's, we built it for us to play in, woodworking upstairs, metal, auto downstairs :D
    :lol: thanks sparkyboy, yes what was I thinking. Pick out the best looking, re-size, touch-up the early ones (started with cheap point and shoot) Wish I found BT a lot sooner :lol:
    on with the catch up show
    Making of the back plate
    fan test fit
    Making rolled edge for motherboard tray
    5.25 bay enclosure
    I/O housing
    and all soldered up, not just a rectangle box :clap:
    HDD mounting plate
    tools of the build, and first side panel with rolled edges. I later changed to "u" edges :duh: should have left them, but thought to narrow, would have worked out.
    cleaned up with a few extras attached
    Hope you all like the show. more tomorrow :)
  5. craig - toyoracer
    1 Mar 2011
    Continuing the update
    this is my favorite part made, design wise it improves on the original and the fitting is awesome. I/O module is screwed on from the inside.
    here both side panels,, octagon window cut-out and 5.25 bay stealth door latch parts
    the inner door panel with piano hinge
    how the latch is made
    the last time inner workings will be seen
    door paint job
    optical drive sled
    all together now
    un-latched
    top exhaust is contained in a mesh housing. For those that noticed, I started with 2 fan holes and then opened up to rectangle opening. This is to accommodate the summer/winter fan plates (2 more updates) the mesh was bent up and edges filled with epoxy and mounted on aluminum plate, like so
    you know what this is
    motherboard tray is polished and fitted
    close-up, SSD rack hangs on right side, holds 2
    some side panel reflections
  6. Cheapskate
    13 May 2007
    Wow! That moved fast. I like.:D
  7. craig - toyoracer
    1 Mar 2011
    -shiny update -Aug27
    Thank you very much. Fast, :hehe: started June 2010 :lol:
    Now for the shiny stuff
    Aluminum angle cut and polished
    the brazing starts
    all cleaned up
    here Little Bull checks out the parts to attach the drives
    and checks to make sure the wild drives are safely caged
    after a few attempts, I have power cable just right, some work to do on those data cables :rolleyes:
    For the front air intake, and what started this whole design, Was a special fan grill by Bill from MNPCtech, for HardwareCanucks build he did.
    I am Canadian and like hardware, so I needed one.
    polished up and how it would be mounted
    but it was not quite right, needed some modding, now it looks right for my case
    You may be asking where did the name octTower come from. Let me show you :clap:
    The build-log is here. A great big thank you to mvagusta for helping me make a vision into reality :clap:
    The case feet are just wrong so new shoes made. :D
    The fast catch up is almost done. I know some of the photos are not the best, so thanks for wading through them :)
    Guest-56605 likes this.
  8. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Simply..... WOOOOOOOOOOOOOW!!!! The design rocks, the execution is flawless, everything screams SUCCESS in this mod/worklog!! My friend I am in love with your mod!!! More pics pl0x!!! :) :)
  9. Attila
    22 Feb 2008
    I agree. The i/o door is really nice, but so is the drive cage. Very nice work. :thumb:
  10. Guest-56605
    Guest-56605 Guest
    Stunning Craig :thumb:
    Superb metal working skills :thumb:
    I like it, I like it a lot!!! :D
    + rep
  11. craig - toyoracer
    1 Mar 2011
    Alex thank you very much, I am speechless. :) more pics for sure :D:D
    Thank you Attila, yes the cage took some thinking and I like the out come a lot :D
    Thanks man, glad you like it. :D Taking my time on each step.
    A few pictures of the power on lights
    I had a hard time getting a good photo of HDD activity light, so much reflection
    This is close to real life brightness, pro photographer I am not
    the shoes look just right I think, not to big and are rubber mounted
    After a couple of trial runs, this is what the Sata power cable became
    My first sleeving attempt
    now it looks good but, problem with the bend radius meant I needed to do something different to get the right look. The bends needed to be 90˚ off the motherboard and the PSU. So I made molded plugs to fit.
    First a mold to hold the sleeve in place
    un-molding
    mistake made in length for radius, cut adjust length and mod the mold :hehe: use what you have to make it work
    next mold for the 90˚ bend, now using fast setting epoxy is good, it is not always smooth going
    but you can file, sand add more epoxy, file, sand
    repeat 2 more times since PSU is a double plug.
    One custom 24 pin cable, time and effort I think worth it, to get what you need or want :D
    Angel OD likes this.
  12. y0gi
    y0gi What's a Dremel?
    23 Nov 2010
    Awesome work going on here Craig.:thumb: Absolutely love that 24 pin. My first post just for you.;)
  13. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Very nice build!! :thumb:
    And that octo tower thingy is just a work of WIN!
    Really amazing sir! +rep!
  14. Zorndar
    Zorndar What's a Dremel?
    26 May 2008
    Awesome workmanship and a nice clean look. Did I mention that it was frigging fast?
  15. craig - toyoracer
    1 Mar 2011
    Welcome to BT y0gi, hope you have some fun and join in with your modding too.
    Thanks, I am having fun trying out new things on my first build. :)
    Thank you very much. octo thingy :lol::lol: I like it
    what is +rep ?
    Thanks - little take on Mr.Spock - if hours were weeks from the first post till now would be close :naughty:
    So I need some spacer nuts and no sense looking for some, so using 1/2" rod cut to 35mm drill and tap both ends
    then file down ends like so
    into my ghetto lathe and turn them down - .275"
    (sorry this will drive you crazy Imp.&Metric)
    handy parting tool
    some more filing, Repeat 8 times, and you have
    Mushroom Nuts :D:D
    Now being the middle of summer needed some ice-cubes
    :naughty: no they are the spacers, and where does all this go
    :duh: not there, :confused: here :D
    some reflections
    Now for some hardware mods, the copper had to go
    and a nice clean smooth top
    XFX 5770HD needed some refinements
    blue is my accent color
    someone may spot the changes made
    so just 2 items left to show, that brings us up to-date
    more than happy to answer all questions :D
    kelmannen likes this.
  16. Guest-56605
    Guest-56605 Guest
    Damn ain't you full of surprises Craig!!! :dremel:
    Looking sweet bud :thumb: :D
    The green boxes next to your Avatar indicate your reputation
    When someone awards you reputation they normally abbreviate it as +rep = Reputation :thumb:
  17. craig - toyoracer
    1 Mar 2011
    Surprises me :D thank you
    Well here are the last 2 items of this catch game :clap:
    I have no idea if this will improve cooling but the idea makes sense.
    Out of the oven onto the mold
    when cooled
    all together, Little Bull likes it, no wire to look through :)
    test fitting, looks okay
    this week mounted the top exhaust fans
    these are the summer ones
    here under the mesh
    there is still a few things to do, hopefully it cools down a little, the lazy days of summer :hehe:
  18. talladega
    talladega I'm Squidward
    18 Aug 2007
    i like this :thumb:
  19. benjjamin
    benjjamin needs MORE POWER!
    13 Sep 2010
    Nice work you have there :)
  20. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    ..... wow! incredible workmanship!
