News Crucial boosts M4 SSD speed
Discussion in 'Article Discussion' started by Claave, 30 Aug 2011.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    OOOOO will definitely take a look!
  3. Ph4ZeD
    22 Jul 2009
  4. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    I can only hope OCZ follow suit, I need moar speed from my Vertex 3!
    TSB
  5. Meaty Pete
    Meaty Pete King of the Potato People
    8 Apr 2010
    Be changing the firmware when I get home. Does that mean it can beat the vertex 3 now?
  6. Stotherd-001
    Stotherd-001 Minimodder
    15 Apr 2009
    Got one of these the other day... think I'll update the firmware before installing anything on it though.
  7. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Edit: read the posted link properly now.
    I did a bench last night, so il update the firmware and run another this week!
  8. kenco_uk
    28 Nov 2003
    http://forums.bit-tech.net/showthread.php?t=215639
    I updated mine on day of release. Ensure you have backed up any important info, just in case. You need to have the sata port it's connected to set to ide and all other sata ports set to IDE/Compatible temporarily (or disable those that the ssd isn't connected to), otherwise the bootable cd update sticks on finding the drive.
    I know my speeds went up a fair bit, but I guess it needs to run trim to get the full benefit. Is there a way to manually run it on these drives? Like how you can with the Intel SSD Toolbox on Intel drives?
  9. Ph4ZeD
    22 Jul 2009
    I can't actually get the firmware updated for my drive yet :(
  10. AstralWanderer
    AstralWanderer What's a Dremel?
    17 Apr 2009
    The price has really dropped for the 128GB drives recently - there are a few other vendors offering good prices also (better once you take free delivery into account) for those who can't stomach Overclockers.
  11. Vo0Ds
    Vo0Ds Fake potato
    6 Feb 2004
    Seems SSD's are still climbing sharply in speed and capacity, think I'll wait 'till next year to partake...
  12. salesman
    salesman Minimodder
    29 Apr 2007
    I did this and it took me 5 minutes. Quite easy and painless, took longer to burn the iso to disc then it did to update the firmware. I read the 20 steps crucial has and I followed like 5 of them. Download, burn, restart, type yes, restart.
    Bad part for me is I have the 64gb setup using SATA II port so I really do see a difference in boot times. One day I will have the SATA III port, one day.
  13. samkiller42
    25 Apr 2006
    I'm with salesman, Using a X58 UD5 things a re a little slower than our Sata 3 counterparts, but the update has made a difference, it is quicker than before.
    +rep to Crucial.
    Sam
  14. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    Just wondering; I have a 256gig version in my main machine and a 128gig in another machine. Can I use the same ISO for both drives or is it capacity specific too?
    I'm pretty sure that the capacity doesn't matter, but better to be safe than sorry.
  15. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Here's a quick guide for updating the firmware from a USB drive.
    1. Format a USB drive with FAT/FAT32.
    2. Download Syslinux and extract the syslinux.exe file from either the Win32 or Win64 folder
    3. Run syslinux -m -a X: where X is the drive letter of your USB drive.
    4. Extract the contents of the BOOT folder in the firmware ISO to the root of the USB drive.
    5. Rename ISOLINUX.CFG to SYSLINUX.CFG
    6. Boot from the USB drive, and it'll ask for confirmation to upgrade the firmware. In my experience, it'll successfully update even if the controller is in AHCI mode.
    I've seen a slight improvement in general loading times on the Thinkpad with this new firmware. :)
  16. DirtyH
    DirtyH What's a Dremel?
    20 Jan 2005
  17. Waynio
    Waynio Relaxing
    20 Aug 2009
    Wow that's a nice surprise for owners :):clap:. I took the plunge & gamble for a corsair force 3 though but so far so good :).
    I was a bit worried going for a sandforce drive after seeing so much negative about them but mine seems nice, didn't bother updating the bios on it either, thought I'd see if it's fine before doing that & it seems to be with good speeds.
  18. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    The speeds are a nice bonus, but the fact that the drive actually works correct from cold boots, is worth 100 speed increases .
  19. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    Get a PCI-E card for about £17 that has 2x SATA 6G/b ports :)
  20. cgthomas
    cgthomas Cpt. Handsome
    20 Oct 2009
Tags: Add Tags
