Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 1st Sep 2011, 08:18   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
PC Hardware Buyer's Guide September 2011
Our monthly guide to getting the best components for your PC build, whatever your budget.
http://www.bit-tech.net/hardware/buy...ptember-2011/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 1st Sep 2011, 08:23   #2
gogzyhutch
What's a Dremel?
gogzyhutch has yet to learn the way of the Dremel
An m-ATX mobo in a premium player rig......odd decision but fair do's!!!
gogzyhutch is offline   Reply With Quote
Old 1st Sep 2011, 08:41   #3
confusis
Kiwi-modder
confusis's Avatar
confusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysis
In the affordable, wouldnt a Phenom 840 and AM3+ board be a better and cheaper option? AM3+ = more future proof than Intel's flavour of the week sockets, and the Phenom 840 (even w/out l3 cache) performs pretty much equally as well as the core i3 2100, and is a quad core?
confusis is offline   Reply With Quote
Old 1st Sep 2011, 08:41   #4
xaser04
Ba Ba Ba BANANA!
xaser04's Avatar
xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.
Buyers guide looks good this time around. Bit have finally adjusted the pricing on the affordable all rounder to better reflect the GPU and memory pricing.
One critism though is the PSU. It might be excellent but £75 is too much for a 525w PSU especially considering the excellent Corsair TXV2 650w can be had for £10 less.....
It is also too expensive considering the build it is going in (£500 all in). If you dropped the PSU to something like the BeQuiet L7 530w (~£42) and dropped the cpu cooler entirely you could squeeze a Core i5 2500k in the system. Increase the budget a small amount and the cpu cooler can also be added back.
__________________
Daedalus - Clevo P170SM | i7 4700MQ @ 3.4Ghz | GTX780M 4GB @980/6000 | 16GB DDR3 | 17.3" 1920x1080 |
ZPM "VIVE" Mini - Fractal Node 202 | i7 4770S | GTX1070 | 8GB DDR3 | 4K TV / HTC VIVE |
Consoles / Retro - PS4 Pro | PS4 | Xbox One x2 | Dreamcast x2 (VGA) | WiiU | Retron5 |
Last edited by Claave; 1st Sep 2011 at 11:11. Reason: Typo corrected, thanks and have some rep
xaser04 is offline   Reply With Quote
Old 1st Sep 2011, 09:05   #5
jakall78
What's a Dremel?
jakall78 has yet to learn the way of the Dremel
The video cards are all Nvidia - this is a joke, AMD is out of business or what???
I`m ok with the cheaper ones, it`s open for discussion, but the 590 is just such a bad example of manufacturing. Defect rate is through the roof, because of the bad conceived VRM. How can that failure be a recomended video card?
Links:
http://www.youtube.com/watch?v=sRo-1VFMcbc
http://www.thinq.co.uk/2011/3/30/nvi...aths-continue/
http://www.hardware.fr/articles/747-...thermique.html
http://translate.google.com/translat...rclocking%2F12
This last one being the most interesting, it shows the miniscule VRM Nvidia put on the 590.
And don`t tell me you didn`t know about this.
jakall78 is offline   Reply With Quote
Old 1st Sep 2011, 09:21   #6
Sentinel-R1
Morse Monkey
Sentinel-R1's Avatar
Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.
Yes, but not as future proof as the intel option. With this one, drop in a 2500k when you have the cash and you're nicely upgraded. In fact, add another 460 for £120 and you've got a very good gaming machine.
__________________
6700K @ 4.7GHz | EVGA Z170 FTW | SLI EVGA GTX 780s @ 1176/6400 | 16GB Corsair DDR4-3000 | Corsair Carbide Air 540
Sentinel-R1 is offline   Reply With Quote
Old 1st Sep 2011, 09:45   #7
confusis
Kiwi-modder
confusis's Avatar
Or, with socket am3+ (like i said in my post) you have at least a year, maybe two of upgrade life..remember bulldozer is coming out soon?.. intel changes sockets like they change their underwear
Old 1st Sep 2011, 09:49   #8
hurrakan
Modder
hurrakan has yet to learn the way of the Dremel
re: Premium Player
The Vertex 3 (and other Sandforce 2281 SSDs) are too unreliable for a boot drive. They have a BSOD bug that has yet to be fixed (even after months of trying). I really wanted to buy a Vertex 3 but I cannot justify it (especially after browsing the OCZ forums).
The Intel 510 240GB is MUCH more reliable and equally fast as the Vertex 3 in most tests. The 510 costs a bit more but I cannot risk losing my system to BSODs.
Micro-ATX boards don't have enough PCI slots for me. So I think I will get the P8P67 Pro R3.1 instead.
hurrakan is offline   Reply With Quote
Old 1st Sep 2011, 09:51   #9
MjFrosty
Hypermodder
MjFrosty's Avatar
MjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on youMjFrosty - may the hammer of Bindi be bestowed on you
Nice and informative. I'm sure my x58 system can last till November, though. Also I like how you use the Xigmatek Elysium which is excellent value for money. Best £150 I've ever spent.
__________________
Fast
MjFrosty is offline   Reply With Quote
Old 1st Sep 2011, 09:51   #10
hurrakan
Modder
Which optical drive should I get to backup (rip) my blu-ray movies, in a "premium" style (quickly + silently)?
Old 1st Sep 2011, 09:58   #11
murraynt
I Mod, Therefore I Own
murraynt's Avatar
murraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for president
Looks better that last month I must say. Only thing that caught my eye was a 75 pounds PSU for a budget build. Reducing that to a 450 corsair could allow alot of people to squeeze in a quad core
__________________
l I5 4690k l MSI Z78I l 8GB corsair 1600mhz l Asus 5870 v2 l Fractal Node 304 l 60GB Crucial M4 l F3 1TB Spinner l 700Watt Thermaltake l Samsung IPS231 l
Steam: murraynt
murraynt is offline   Reply With Quote
Old 1st Sep 2011, 10:00   #12
Abhorsen
Hypermodder
Abhorsen's Avatar
Abhorsen has yet to learn the way of the DremelAbhorsen has yet to learn the way of the DremelAbhorsen has yet to learn the way of the Dremel
Does the re-use of the same copy every month annoy anyone else, or just me?
__________________
None found.
Abhorsen is offline   Reply With Quote
Old 1st Sep 2011, 10:03   #13
Sentinel-R1
Morse Monkey
Don't get me wrong, I'm not wholly disagreeing with you. We've yet to see how Bulldozer will stand up to a 2500/2600K - but realistically, I think AMD will have a tough fight to top those two CPUs, therefore I think they're spot on with their recommendations and a Sandybridge gaming system will last a lot longer than 2 years before it needs upgrading again.
__________________
Old 1st Sep 2011, 10:12   #14
Shayper09
Swimming in Deionized.
Shayper09's Avatar
Shayper09 has yet to learn the way of the Dremel
Nice outline, but some decisions just don't make sense.
I would post which ones, but I'm about to lose signal so shall do it later .
__________________
The Ghost
i5 2500k
GTX 580
Watercooled Phantom
Click For Build Log
Shayper09 is offline   Reply With Quote
Old 1st Sep 2011, 10:16   #15
isaac12345
Supermodder
isaac12345 is a Super Spamming Saiyanisaac12345 is a Super Spamming Saiyanisaac12345 is a Super Spamming Saiyanisaac12345 is a Super Spamming Saiyanisaac12345 is a Super Spamming Saiyanisaac12345 is a Super Spamming Saiyanisaac12345 is a Super Spamming Saiyanisaac12345 is a Super Spamming Saiyanisaac12345 is a Super Spamming Saiyanisaac12345 is a Super Spamming Saiyanisaac12345 is a Super Spamming Saiyan
£75 PSU for the all rounder build?!! Clearly the antec PSU should be good enough. The savings can be put into a buying a 6870 instead.
isaac12345 is offline   Reply With Quote
Old 1st Sep 2011, 10:27   #16
mat0tam
Mr I Dont Know What I Want
mat0tam's Avatar
mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!mat0tam - it's over 9000!!!!!!!!1!1!1!!!
Thankyou for your post - Looking at dropping the price a tiny bit myself
Last edited by Claave; 1st Sep 2011 at 11:16. Reason: typo corrected, cleaning up quotes for new posters
mat0tam is offline   Reply With Quote
Old 1st Sep 2011, 10:31   #17
MaverickWill
Dirty CPC Mackem
MaverickWill's Avatar
MaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run CrysisMaverickWill can run Crysis
Originally Posted by Article
This month we’ve made a couple of significant changes to the spec of our Affordable All-Rounder. First of these is a change in motherboard, as we (rightly) took some stick in the comments thread of our last buyer's guide for recommending an H67-based motherboard. This was done to keep the price of the build down and the chipset’s lack of overclocking didn’t matter too much, given that we’re also recommending a processor that can’t overclock. Realistically, though, using an H67 board overly limits your upgrade options, as you’ll never have the option to slap in a K-series CPU and go overclock happy.
Originally Posted by MaverickWill
At the risk of coming across as slightly arrogant, I think the ball has been somewhat dropped by the Bit-Tech boys, with regards to the Affordable All-Rounder. Changing out the Pentium for the i3-2100 is a bit of a sideways step (I'd normally stick to overclocking-friendly parts on budget builds to eke out that lovely performance), but understandable if an upgrade path is desired.
And then it gets a swift kick to the chops by using an H67 motherboard. Really, guys? You recommend an upgrade path through LGA1155 with ZERO chance of using the i5-2500K? To add insult to injury, you take one of the most frugally-powered desktop chips on the planet, and attach a Freezer 7 Pro. For the extra £15, you could have a P67 motherboard, right?
It might not be significant, but I've managed change faster than Obama. Yeahhh!
__________________
Antony's got his hat on, hip, hip, hip, hooray!
MaverickWill is offline   Reply With Quote
Old 1st Sep 2011, 11:13   #18
impar
impar's Avatar
impar is definitely a rep cheat.impar is definitely a rep cheat.impar is definitely a rep cheat.impar is definitely a rep cheat.impar is definitely a rep cheat.impar is definitely a rep cheat.impar is definitely a rep cheat.impar is definitely a rep cheat.impar is definitely a rep cheat.impar is definitely a rep cheat.impar is definitely a rep cheat.
Greetings!
Still on 4GB RAM?
impar is offline   Reply With Quote
Old 1st Sep 2011, 11:14   #19
jeeesus
What's a Dremel?
jeeesus has yet to learn the way of the Dremel
+1
Title needs to be corrected, like this: "Intel and NVidia PC Hardware Buyer's Guide September 2011" .
P.C. Golden rule: The adds on site you see, the recommended config you get.
Do you see here any AMD add? ;-)
Last edited by Claave; 1st Sep 2011 at 11:17. Reason: Cleaning up quotes, leaving valid discussion
jeeesus is offline   Reply With Quote
Old 1st Sep 2011, 11:39   #20
Smellyhead
Supermodder
Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.Smellyhead is definitely a rep cheat.
Just me, or do these setups get more expensive every month?
The All rounder has gone from £445 - £465 - £500 Getting past the point of been the "affordable" one, no?
I know prices change, but seriously, you just seem to replace stuff with more expensiv stuff for no reason in each build.
__________________
i7 2600k | Gigabyte Z68A-D3-B3 | 8GB Vengence | Sapphire 380x Nitro | Antec VP550
Smellyhead is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
