Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 8th Sep 2011, 11:44   #1
BoogieMan
Cunny Funt
BoogieMan's Avatar
BoogieMan has yet to learn the way of the Dremel
Which single slot card for a shuttle sh55j2
Hey,
I have just bought a shuttle sh55j2 and installed an i3-540 and 16gb Kingston ram. It has on board graphics but I was thinking about buying something that will give it a bit more gpu power.
I am limited however as the system has a 300watt psu and a wireless pci card (which only gives room for a single slot card).
I do most of my gaming on a ps3, the pc is mainly used for office tasks, photoshop, programming etc.
My final requirement is that the card could potentially be used in macosx as I may consider hackintoshing the shuttle someday.
Any ideas which card I should look for which is currently on the Market or is coming out in the foreseeable future?
Thank you for any advice
BoogieMan is offline   Reply With Quote
Old 8th Sep 2011, 12:24   #2
Fingers66
Kiwi in London
Fingers66's Avatar
Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.Fingers66 is the Cheesecake. Relix smiles down upon them.
There are many single slot GPU's available but the performance and price varies. What kind of performance are you after? Gaming?
If you are only using it for office tasks, photoshop, programming etc, the on-chip GPU of the i3 540 will be more than enough.
I know because I use one in a mini-ITX PC (see sig).
__________________
Gaming: [Silverstone TJ08-E][Asus Maximus Gene V][i5-3570K][Corsair H55][8GB Crucial Ballistix 1866MHz][Asus GTX 580][Samsung 840 Pro 256GB][Corsair HX650][Dell U2412M][Corsair K60]
Main: [Lian Li PC-A04][Asus P8Z77-M Pro][i5-2500K][8GB 1600MHz][Asus 6850 DirectCU][Corsair Force 3 120GB][Seasonic S12 430w]
Kids: [Silverstone SG05B][Asus P8H61-I][Pentium G840][4GB 1333MHz][OCZ Vertex Plus R2 120GB][Dell E207WFP]
Projects: [Antec 300 improved] NAS 1: [Synology DS211j] NAS 2: [OpenMediaVault]
Fingers66 is online now   Reply With Quote
Old 8th Sep 2011, 13:04   #3
BoogieMan
Cunny Funt
BoogieMan's Avatar
I would love to be able to run Deus Ex 3 (much prefer it on a PC to the PS3) but I guess that is not going to be possible with a single slot graphics card?
Besides that just standard office tasks..
I am looking to spend about £80, at a push max £120.
Old 8th Sep 2011, 13:21   #4
Fingers66
Kiwi in London
Fingers66's Avatar
In that budget a single slot AMD 5770 would work but I cannot vouch for how well it runs Deus Ex 3.
You can get single slot AMD 6850's but I haven't seen them in the UK yet (Powercolor make them).
According to the Hexus review of the Shuttle SH55J2, you can fit a dual slot GPU as long as the power supply is up to it.
If the PSU you have in your shuttle can take it, you can get a "normal" AMD 6850 with a copy of Deus Ex 3 for around the £120 mark: http://www.scan.co.uk/shop/computer-...28960-cores%29.
If you only have the standard 300w PSU in your Shuttle, a replacement 500w model isn't cheap: http://www.kikatek.com/product_info....source=froogle.
__________________
Old 8th Sep 2011, 13:24   #5
BoogieMan
Cunny Funt
BoogieMan's Avatar
My problem is I have a PCI Wireless card built into the shuttle that takes up the secondary slot so I need a single slot one. I will have a look into hunting down that Powercolor one you mentioned. Might be able to order it from eBay US.
Thanks for the excellent reply.
Old 8th Sep 2011, 13:32   #6
Fingers66
Kiwi in London
Fingers66's Avatar
Do some homework and find out if a 5770 will play that game. You can get single slot versions for around £90.
__________________
Old 8th Sep 2011, 13:53   #7
noizdaemon666
I've been away far too long
noizdaemon666's Avatar
noizdaemon666 is definitely a rep cheat.noizdaemon666 is definitely a rep cheat.noizdaemon666 is definitely a rep cheat.noizdaemon666 is definitely a rep cheat.noizdaemon666 is definitely a rep cheat.noizdaemon666 is definitely a rep cheat.noizdaemon666 is definitely a rep cheat.noizdaemon666 is definitely a rep cheat.noizdaemon666 is definitely a rep cheat.noizdaemon666 is definitely a rep cheat.noizdaemon666 is definitely a rep cheat.
I reckon a 5770 would play it, dependant on resolution. Won't be able max out all the settings to super duper awesome smashing great though.
__________________
AMD A4 5300 @ 4GHz | | 4GB 1600 Patriot | 128GB SSD | 500GB Samsung HD501LJ | 320GB Hitachi 2.5" | CX430 PSU
noizdaemon666 is offline   Reply With Quote
Old 8th Sep 2011, 17:43   #8
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.RichCreedy is the Cheesecake. Relix smiles down upon them.
i have dues ex 3 running on a gt240m it works just fine
RichCreedy is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
