Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 11th Sep 2011, 20:23   #1
ketuhanh
What's a Dremel?
ketuhanh has yet to learn the way of the Dremel
asus p8z68-v pro cpu led lid up
hello,
I just finished building my new PC. The Problem seeing is when I turn it on, it stays on for 2-3 seconds, and turns itself off (automatically), then it turns back on itself (automatically) and stay on. There is no signal to monitor and also noticed the CPU LED on the board is lid up "red". Please help.
Here are the spec
i7 core 2600k
ASUS P8Z68-V PRO mother board
CORSAIR Vengeance 16GB
CORSAIR Enthusiast Series TX650 V2 650W
ASUS Black 12X BD-ROM 16X DVD-ROM
HITACHI Deskstar H3IK20003272SP 2T sata 3.0 Gb/s hard drive
ketuhanh is offline   Reply With Quote
Old 23rd Sep 2011, 17:45   #2
Dev929
What's a Dremel?
Dev929 has yet to learn the way of the Dremel
I'm having the exact same problem with the non pro version asus
Dev929 is offline   Reply With Quote
Old 29th Sep 2011, 22:48   #3
Nyro Xeo
What's a Dremel?
Nyro Xeo has yet to learn the way of the Dremel
Hello,
Did you solve your problem ? Because it's happening exactly as you said on my Asus P8Z68-V Pro.
Could someone help ? It's my first PC assembly. Thank's.
Nyro Xeo is offline   Reply With Quote
Old 2nd Oct 2011, 15:46   #4
Dev929
What's a Dremel?
Yes I resolved my problem. I had too much thermal paste or maybe it was just reseating the CPU and heatsink but it boots normally now.
Old 3rd Oct 2011, 23:33   #5
Nyro Xeo
What's a Dremel?
Thank's. I solved it too, thank's to this (point 2) : http://www.tomshardware.co.uk/forum/...video-problems
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
