Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 12th Sep 2011, 12:07   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Smartphones outsell feature phones for first time
Huge drops in feature phone sales are matched by large gains in smartphone sales, helped by Android.
http://www.bit-tech.net/news/hardwar...eature-phone/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 12th Sep 2011, 12:24   #2
V3ctor
Tech addict...
V3ctor's Avatar
V3ctor has yet to learn the way of the Dremel
Even my mother has a smartphone, and she hates mobile phones... using touch screen was the best thing that could happen to a phone
__________________
Main: Intel Core i7 4770K@4.5Ghz / ASUS Sabertooth Z87 / 2x4Gb Gskill Trident X 2400Mhz / MSI GTX 750Ti 2Gb GDDR5 / Samsung T260 / 2x Corsair Force GT 240Gb raid0/ Corsair HX-850W/ Silverstone FT02R-Wi
Laptop: Intel Core i7 4790K 4-4.4Ghz / 8Gb DDR3 1600Mhz / nVidia GTX 980M 8Gb GDDR5 / Samsung SSD 256Gb XP941
Hobby: AMD Opteron 175 / ASUS A8N-SLi SE / 3Gb DDR400 / ATI HD4850 512Mb GDDR3 / Crucial M550 128Gb M2
V3ctor is offline   Reply With Quote
Old 12th Sep 2011, 12:49   #3
the-beast
Modder
the-beast has yet to learn the way of the Dremel
I have a feature phone, as I can not afford a smart phone
the-beast is offline   Reply With Quote
Old 12th Sep 2011, 12:53   #4
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
I use a "feature Phone" regularly due to high cost of using the smartphone here in Germany.
Also, use of the internet connection is not covered by usual "pre-paid" conditions here.
So people buy a Phone, load up 10€, use the net and get a bill over 1000€.
Legislation is slowly changing though, so we might get some interesting tariffs.
Also, roaming is ridiculously expensive.
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 12th Sep 2011, 13:27   #5
dunx
ITX is where it's at !
dunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysis
Work provide me with a cheap nasty Nokia that does calls and txt. in monochrome...
What else do I need ?
dunx
__________________
Gigabyte Z87x OC-Force - i7-4790k @ 4.3 GHz - 16 GB Crucial Ballistix Tracer Orange/Blue DDR3 @ 1600 MHz - 256 GB Plextor SSD x2 - 6x WD Caviar Black 1TB SATA III HD's - GTX 970 x2- GTX 780 - Titan Black - Coolermaster 1250W PSU - Lian Li PC-D600 - 3x Noctua NF-A14 fans - custom water-cooled - Alphacoool 420mm rads in white - XSPC CPU block and D5 pump - Griffin Powermate x2
dunx is offline   Reply With Quote
Old 12th Sep 2011, 13:49   #6
dyzophoria
Supermodder
dyzophoria has yet to learn the way of the Dremel
honestly my new smartphone (issued by the office) based on android, was better as a GPS device than the old handheld unit we had, and actually helped us better on our long range radio communications on getting the damn things aligned, and I couldn't ever think before that I would find such an awesome use for a smartphone,lol
__________________
[FONT=Lucida Console]picture this..[/FONT] // [FONT=Tahoma][FONT=Fixedsys]picture that..[/FONT][/FONT]
dyzophoria is offline   Reply With Quote
Old 12th Sep 2011, 14:40   #7
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
no, it isn't. the keyboard on phones is much more practical. keyboards are so much faster to use, so much more responsive, and neither the keyboard nor your fingers get in the way of the screen. touch screens are good for navigation but otherwise they're just gimmicky and inefficient.
__________________
4.5GHz FX-6300 (on an AM3 board) with C'n'Q on, 8GB of RAM, R9 290, ADATA SP900 64GB SSD, Arch Linux 64 bit.
schmidtbag is offline   Reply With Quote
Old 12th Sep 2011, 15:04   #8
Apocalypso
Fully armed and operational.
Apocalypso's Avatar
Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!
In your opinion.
I would say a capacitative touchscreen allows a user to type faster than on a mechanical keyboard simply by virtue of little to no resistance when registering the keypress.
__________________
Intel Core i5 2500k | ASUS HD 7970 DirectCU II | 8GB Corsair XMS3 1600MHz | Crucial M4 128GB | F3 1TB x 2 | Asus Sabertooth P67 | Corsair HX1050 | HAF 932 | Dell U3011
EK Supreme HF | XSPC RX360 | Scythe AP-14's | MCP355
ARCAM rDAC | Matrix M-Stage | KRK RP5 G2 | KRK 10s | Beyerdynamic DT990 600Ω
Apocalypso is offline   Reply With Quote
Old 12th Sep 2011, 15:17   #9
Taffy
Folding for Margaret 17/3/2011 RIP
Taffy's Avatar
Taffy has yet to learn the way of the DremelTaffy has yet to learn the way of the DremelTaffy has yet to learn the way of the DremelTaffy has yet to learn the way of the DremelTaffy has yet to learn the way of the DremelTaffy has yet to learn the way of the Dremel
I use a smartphone on PASYG because thats all I need, I could do with a simple phone , calls and text, plus a decent camera, but I cannot find one foe PASYG
__________________
1) MSI 790FX-GD70, AMD PH.II X4 955, 4GB Corsair DDR3, 1 x GTX 760, 1000W PSU in Lian Li 2100. 2) Alienware M17x-R2 folding on i5 520M
Taffy is offline   Reply With Quote
Old 12th Sep 2011, 15:21   #10
Taffy
Taffy's Avatar
OOps that should read a simple Nokia NOT a smartphone
__________________
Old 12th Sep 2011, 15:54   #11
Xir
Xir's Avatar
Are there any smartphones out there that have a decent standby-and-call time?
Like a week standbytime@10 mins calls a day and some texts?
__________________
SN25P
Old 12th Sep 2011, 15:59   #12
Tyinsar
6 screens 1 card since Nov 17 2007
Tyinsar's Avatar
Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.
I sit in front of a computer at work all day and have one in almost every room of my house - I have not found any need for a smart phone. Besides that, Canada has some of the highest cost plans in the world (link1) (link 2). I'm not giving those greedy people any more money than I have to.
Occasionally I'd like to be able to look something up while on the road or in a restaurant but I can live with a bit of delay in looking up things - especially since waiting just a little is a lot more cost effective.
__________________
Regardless of what you believe there is someone at least as smart, or smarter, than you who believes something you think is stupid (and it's not just because you know something they don't).
Tyinsar is offline   Reply With Quote
Old 12th Sep 2011, 16:03   #13
Zinfandel
Zinfandel's Avatar
Zinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpitZinfandel is almost as Godly as yodasarmpit
I have an LG Optimus GT540 and pay £10 a month for 250 minutes, unlimited texts and unlimited internet.
Giff Gaff rock.
Zinfandel is offline   Reply With Quote
Old 12th Sep 2011, 17:23   #14
PCBuilderSven
Multimodder
PCBuilderSven has yet to learn the way of the Dremel
Probably because Stephen Elop (CEO of Nokia - previously the biggest feature, and smart, phone maker) is doing everything he can to stop people buying Nokia phones. Since really Nokia were the only people who still made feature phones and now no-one makes featurephones anymore nobody can buy them.
PCBuilderSven is offline   Reply With Quote
Old 12th Sep 2011, 19:24   #15
V3ctor
Tech addict...
V3ctor's Avatar
She hated the buttons, she's very old, and using the touchscreen she can even send me messages, something that she didn't care about when she had old phones.
It's easier to use than old phones...
__________________
Old 12th Sep 2011, 22:12   #16
SlowMotionSuicide
Come Hell or High Water
SlowMotionSuicide's Avatar
SlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for president
Where did all these smartphone-hating luddites suddenly crawled from?
Go back to burning looms or something, this site is for tech enthusiasts.
__________________
G3258 @ 4.3GHz | MSI Z97 Gaming 5 | 8Gb Dominators | GTX 660 | Crucial MX100 256GB | F1 Spinpoint 1TB | Seasonic P-760 (XP≤) | NZXT H440W
SlowMotionSuicide is offline   Reply With Quote
Old 13th Sep 2011, 02:07   #17
malcolm
Multimodder
malcolm has yet to learn the way of the Dremel
Nah, no tactile feedback is crap.
Same, and the answer is of course nothing.
Which is totally negated by actually having to look every time you try and press a virtual button to see if it worked. Tactile feedback > touch screen buttons every time a coconut. Shouldn't be too long before touch screens with tactile feedback get here though.
No. I think my 1 yo Nokia still does 10 days though.
Ah huh... I'm guessing you're probably a pron enthusiast, but I bet you're not into interracial goat pron?
You can be enthusiastic about some techs and not others.
FWIW I have had them since things like the PPC2002 HTCs, as we develop for them. For their primary purpose they're all just varying degrees of crap compared to the trusty do nothing Nokia. For everything else I use a little foresight about my day, a netbook, and a life.
__________________
Like chrome? Watercooling? 2k car paint? Beaker!
How about plexi? Little lights? Pandora!
malcolm is offline   Reply With Quote
Old 13th Sep 2011, 02:29   #18
Floyd
Wire Twister
Floyd's Avatar
Floyd has yet to learn the way of the Dremel
My Droid Bionic approves of this message I got it on launch day and have been happy since. Before that I had the OG Droid and the performance was night and day.
Floyd is offline   Reply With Quote
Old 13th Sep 2011, 07:12   #19
Wicked_Sludge
My eyes! The goggles do nothing!
Wicked_Sludge's Avatar
Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.Wicked_Sludge is a hoopy frood who really knows where their towel is.
ive got a "feature" phone...if you can call it that. its a pay-as-you-go no-contract motorola with basic text and calls. the only thing i wish it had was T9...as typing out every letter on a 10-key is a bit time consuming.
__________________
My Rig:
Gigabyte GA-P55A-UD3|Intel Core i7-870 @ 4.0Ghz|12GB G.Skill Ripjaws DDR3 1600|AMD 7970GHz Edition|2x Barracuda 1TB RAID 1
Wicked_Sludge is offline   Reply With Quote
Old 13th Sep 2011, 09:36   #20
Apocalypso
Apocalypso's Avatar
Which I don't have a problem and isn't an issue for many people that I know.
It sounds like you're justifying your own inability to type fluidly on a touchscreen as a problem with the hardware as a whole.
I don't like mechanical keyboards but I'm not about to dress it up as anything other than personal preference.
__________________
Reply
Tags
subjective experiences
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
