View Poll Results: What paint color for Grafik Card?
Natural aluminium 6 23.08%
Black 13 50.00%
White 7 26.92%
Multiple Choice Poll. Voters: 26. You may not vote on this poll
Reply
Thread Tools View Mode
Old 9th Nov 2011, 17:35   #141
Fredcompany
Sir, your PC just bit me.
Fredcompany's Avatar
Fredcompany has yet to learn the way of the Dremel
Looking awesome. You should paint the fans or change the stickers though :P
Oh, and STOP SPEAKING FRENCH!!
Fredcompany is offline   Reply With Quote
Old 9th Nov 2011, 17:57   #142
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run Crysis
Je suis totalement d'accord avec vous cher monsieur. Il se pourrait fort bien que les ventilateurs rendent mieux avec leurs ailettes toutes de blanc vêtues.
Ok, I take my coat . Fans with white blades would look awesome
GuilleAcoustic is offline   Reply With Quote
Old 9th Nov 2011, 18:58   #143
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Canardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the Dremel
Hi Fred, i'll give you a lil lesson of french!!!
I translate only for you our french posts...
Originally Posted by GuilleAcoustic View Post
Joli overclocking monsieur
Nice overcloking Mister.
Originally Posted by Canardwc View Post
Je n'y suis pas pour grand chose, c'est un GPU trés souple, un peu comme le i7 2600k de chez Intel. Ils montent trés facilement en fréquences...
Merci quand même!
That's not my fault, this Graphic Processor Unit is readily adaptatable, like the Intel i7 2600k. they easy rise in high frequencies.
Il monte bien, mais les températures sont vraiment bonnes pour cette fréquence
Rise well, and temps are reasonable for this frequeny.
---End of the translation---
Hope you'll be satified Freddy!!
Have a nice day!
Canardwc is offline   Reply With Quote
Old 9th Nov 2011, 19:00   #144
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Oh, forgot to say you thanks...
Old 10th Nov 2011, 21:42   #145
Fredcompany
J'a comprenné la plupart de la francais
Old 13th Nov 2011, 22:37   #146
Canardwc
Gentel-Mod'R
Canardwc's Avatar
The second aluminium graphik card shell is almost finish.
Have to paint the shell, extend the fans cables and sleeve them...
Some pictures to do your own opinion...
Old 13th Nov 2011, 23:09   #147
Canardwc
Gentel-Mod'R
Canardwc's Avatar
May I have your attention please... I'm looking for a PCI 16x 2.0 extender. I surfed everywere on the web, but i didn't find it. If someone know, please, let me know!!!
Thanks in advance!!
Old 13th Nov 2011, 23:42   #148
SuicideNeil
I'm insane, not stupid.
SuicideNeil's Avatar
SuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for presidentSuicideNeil should be considered for president
Is this any good?
It doesn't mention 2.0 but I figure if it fits the 16x pci-e soecket, and it's just wire extensions, it should do the trick?...
__________________
ASUS P8Z77-M PRO | INTEL CORE i5 2500K @ 4.3GHZ | EVGA GEFORCE GTX 670FTW | CORSAIR VENGENCE DDR3 1600MHZ 2x 4GB | SAMSUNG SPINPOINT F3 1TB | TITAN FENRIR | ACER PREDATOR | WIN 7PRO x64
SuicideNeil is offline   Reply With Quote
Old 14th Nov 2011, 02:04   #149
JA12
Minimodder
JA12 has yet to learn the way of the Dremel
They're most often called risers or in the same category as risers.
http://linitx.com/product/10865
http://linitx.com/product/10537
http://www.mitxpc.com/proddetail.asp...EX16FR&cat=184
JA12 is offline   Reply With Quote
Old 14th Nov 2011, 09:35   #150
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Originally Posted by SuicideNeil View Post
Is this any good?
I prefer be sure for the 2.0 pci-e. Anyway, Thank U!
Originally Posted by JA12 View Post
Thank you too, i think i'll take one mentioned in the third link...
Old 14th Nov 2011, 10:36   #151
GuilleAcoustic
Ook ? Ook !
That's looking good . Out of curiousity, why do you need a PCIe riser ?
Old 14th Nov 2011, 10:53   #152
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Hi Guille,
Thanks you, sounds cool...
Nobody allready told you? Curiosity killed the cat!!
Because the space between the cards is too tight. The VGA on the TOP don't breath enought
Old 14th Nov 2011, 11:01   #153
GuilleAcoustic
Ook ? Ook !
Ok, I understand. Those ribbon riser are perfect for that purpose
Old 14th Nov 2011, 11:17   #154
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Have you seen what JA12 and Suicidneil have suggested?
Do you think if there are all equal?
I prefer this one, probably because it's the most expensive (expensive=quality), i know it's not always true, and the description match with what i'm looking for:
Old 14th Nov 2011, 12:02   #155
GuilleAcoustic
Ook ? Ook !
The one suggested by SuicideNeil is PCIe 1.0 compliant. You need PCIe 2.0. 2.0 and 1.0 are physically compatible, just the bandwidth is higher on 2.0. This could work, but you could have issue if the riser cannot handle the higher speed (the change are low but .... I'd play ion the safe side)
Description
* This riser card provides expansion for 1 slots with cable.
* PCI-E PCI-Express 16x Riser Card Extender Cable 1U/2U
* The Flexible Single Slot PCI-Express 16x Riser Card makes the PCI-Express 16x Card away from motherboard , with the PCI-Express socket directly in line with the socket on the motherboard.
* It is flexible cable design and suitable for your own projects .
* Gold plated contacts for best conductivity and long life .
* No Driver necessary and jump-less .
* PCI-Express 16x Slots.
* PCI Express Specification Version 1.0 Compliant.
* Fit for 1U/2U rackmount chassis.
* Length approx :15cm
Package Includes:
1 x Ribbon PCI Express 16x Riser cable
About JA12 suggestion, I'd go with the third one (also linked in your post). The first one has no mention about the PCIe revision, and the second one is only suited for single slot cards.
Old 14th Nov 2011, 12:42   #156
Canardwc
Gentel-Mod'R
Canardwc's Avatar
You have confirmed what i was thinking... Thanks!!
Old 14th Nov 2011, 13:34   #157
lakisss
I know what a dremel is...
lakisss's Avatar
lakisss has yet to learn the way of the Dremel
I have this and it works.
lakisss is offline   Reply With Quote
Old 14th Nov 2011, 19:57   #158
Vetalar
*learning english*
Vetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the Dremel
why use 2*2 80mm fans when 1 120fan attached to GFX 'back' (parallel to case intake fans) can
a) blow both GFX atonce
b) draw all hot air from case
c) feeds with cold air from outside of case (some airduct)
Vetalar is offline   Reply With Quote
Old 14th Nov 2011, 20:38   #159
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Hi,
In aircooling (if i have lernt my lessons well) don't consider just the airflow volume, there is the air pressure.. And if i remember, the air pressure on a heatsink is the more important.
If I say a bullshit, let me know...
But my case design will form 2 airduct:
- Processor airduct.
- VGA airduct.
Old 14th Nov 2011, 20:41   #160
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Bis repetita!!! Do it again! do it again!
Reply
Tags
aluminium
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
