#1 |
Gentel-Mod'R
Old Navy " COMPLETED " 30th September
Hi!
I'm the author of a current scratch build called "Alumination" still in progress. In fact in hard Progress...!! But this week end, i bigan my first makable project, with all necessaries tools and materials.. I've found 5 years ago in my father's room his old navy wallet... Aluminium wallet... At first, i used it as a pharmacy cupboard in my WC with one shelf. It was very easy to use everyday and really improbable and funny concept.. You'll probably tell me: " why not"? Two weeks ago, my girl freind needed a correct computer for her studies. Then I decided to gave her my old hardware configation: GA p35-dsr rev2.0. e6750 overcocked at 3,6 Ghz. 8800 gts. Pretty old for a geek isn't it? But still working like a charm... Well, i combined the two olds stuffs PC&Navy Wallet.. Another improbable combination.. You'll probably tell me for the second time: " why not"? So let's show you some... dust and durty work, [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] Last edited by Canardwc; 1st Oct 2011 at 12:44. Reason: completed |
#2 |
Gentel-Mod'R
So, I worked hard all night long and i waked up my neighbour at 4:00 pm... He wasn't really happy...
![]() But This project progress by big step... Hope that continue like that... [IMG] |
#3 |
↓ Don't trust that face!
Cool.
![]() Nothing says 'bomb' quite like a modified metal suitcase. Be careful how you transport it.
__________________
#5 | |
Gentel-Mod'R
So it's a good observation, because i exactly would like do it!!! Stupid, stupid I am.... ![]() lol |
#6 |
Gentel-Mod'R
the objectif of this scratch buil is not to do a professionnal build, i want to keep the spirit of this Old Navy wallet.
It's a "Punk" project, so do not expect amazing finitions...
#7 |
Gentel-Mod'R
I'll finish my project soon. I didn't took many pictures, because work is better than talk... and take pictures...
#8 |
Gentel-Mod'R
Old Navy - FINISHED
Job done!!! Hihaaaaaa!!!!!
[IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] Well, i done my first "Punk" scratch build. Use military wallet to unmilitarise it to do a common object like a personal computer... |
#9 |
Collector of Things
The very first image reminded me of a completely torn down Coolermaster Cosmos case that a friend did.
Nice work with the mod, it turned out really well... pretty much the ultimate type of case for a LAN party. How's the cooling and noise levels in that thing? |
#11 |
Gentel-Mod'R
Hope you'll like my project. And Many thanks to all have seen it...
Let me knows what you think about it... NB: That's the diagram airflow ... I will soon start this one: http://forums.bit-tech.net/showthread.php?t=217260 |
#12 | |
Gentel-Mod'R
![]() REally thanks, a Punk Project... And thanks to your website, Amazing Community here!!!!
#13 |
Gentel-Mod'R
That will be my last post on this thread.
Some good qualities pictures... IO shield from inside: On/OFF power button (homemade with old piece of caoutchouc): Point of view: Navy: The Punk rear of the beast: |
#14 |
Multimodder
weak spot in my opinion will be definitely the CPU temp, the airflow will more likely be somethink like:
![]() I may be wrong, but i think you better add an exhaust fan to the left of the CPU
__________________
Scratch Build : GALLUZZO-I : silent wood case MOTM nominee |
#15 | |
Gentel-Mod'R
Then, after 30minutes of OCCT, the maximum temperature rise to 65°C.. The CPU is O/C with stock cooler, so I think it's "normal"... |
| Thread Tools | |
| View Mode | |
