Reply
Thread Tools View Mode
Old 28th Sep 2011, 06:25   #1
mordillo
What's a Dremel?
mordillo has yet to learn the way of the Dremelmordillo has yet to learn the way of the Dremel
[Project] CM 690 II - "Mariazinha"
Hi everyone.
I present my modest atempt in modding this case and creating a dual loop system.
My goal is achieve a clean look with most of the wires, pumps and rad's all concealed.
I know the quality of both the modd's and the photos aren't the best but bear with me - I am still learning...
So now the hardware list :
MotherBoard - Asus P67 Pro
Cpu - Core i7 2600k
Ram - Gskill RipjawsX DDR3 1600Mhz 4GB - CL7
Gpu - EVGA 580 SC
HD - SSD OCZ Vertex 3 - 60GB
Storage - Samsung 250 x2 (raid 0)
Watercooling list:
XSPC RS240 x2
Swiftech MCP350 x2
Swiftech Apogee XT
EK FC580 GTX - Nickel
Tubing - PrimoChill 5/8 Clear
Conectors by BitsPower
This Project will be called Mariazinha.
So now on with this build.
MotherBoard Fully Dressed
GPU Dressed
Case all naked
I/O Shield Painted and Placed, PSU threaded for new screws and Lian Li Aero Slots
New Vertical Plate with SSD Mount. This piece is made in acrylic and with vinyl aplied.
Lower Section separation plate with rad and connections
In Place
Another View
Overall View of the work so far (Still a long way to goooooooooo). Just did a quick mock up for you guys to see what's coming. Everything will sit flush when it's finished.
Hope you enjoy!
mordillo is offline   Reply With Quote
Old 29th Sep 2011, 06:05   #2
mordillo
What's a Dremel?
..Update..
HD cage back in place after a litle grinding and paiting.
Did a almost definitive mock up with the hardware to test the loops.
Still not happy with cpu loop so i'll change the block so that the tubes are paralel
View of the pump area (dont mind the double sided tape it is only temporary)
Test mock up for the backplate. Still working on the design. In the end this will be nickel plated.
Time for sleeving xD
Hope you enjoy
Old 29th Sep 2011, 11:56   #3
pyro1son
Linux User!
pyro1son's Avatar
pyro1son has yet to learn the way of the Dremelpyro1son has yet to learn the way of the Dremelpyro1son has yet to learn the way of the Dremel
This is looking good. I'd love to do the same thing to my 690 but don't have the time or money! Keep up the good work!
__________________
Main Rig
Phenom II X4 | Dark Rock Pro | GA-880GA-UD3H | GTX 460 | 2x2Gb HyperX Blu & 2x4Gb XMS3 | 250GB 840 SSD | 1TB + 3TB HDD | CM 690 II Advanced
Laptop
i5 24320M | nVidia GT540M | 4Gb RAM | 500GB HDD
Steam, Origin, BFBC2, WoT: Pyr0660
pyro1son is offline   Reply With Quote
Old 29th Sep 2011, 12:02   #4
Fuganater
Supermodder
Fuganater's Avatar
Fuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run Crysis
Now that is a clean mod. Do a pro job on sleeving your cables and it will be perfect!
__________________
-Fugatech-mods-
-Facebook-
Fuganater is offline   Reply With Quote
Old 29th Sep 2011, 12:55   #5
Razer2007
Building Proxima
Razer2007's Avatar
Razer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the Dremel
Nice work on that panel, and nice hardware. Do your best and take your time. Keep up the good work
__________________
Razer2007 is offline   Reply With Quote
Old 29th Sep 2011, 20:04   #6
mordillo
What's a Dremel?
Thank you for your words. Hope that this mod doesnt let anyone down :P
Not really posting a update but that Swiftech was bothering me a lot.
So out with the old and in with the new
Looking good...:yepp:
And as a little gift for myself (and because it looks wayyyyyyyy better)
That's it for now. I really should get back to sleeving. See you soon!
Old 8th Oct 2011, 07:22   #7
mordillo
What's a Dremel?
Good morning everyone.
As promissed here is the update.
I have to warn there are a lot of pics ^^ This is a build where i try to learn and develop my modding skills as well as my photografy skills.
Hope it comes out well!
Let's begin with the new acrylic pieces. After the mock up's i did some tweeks and with the final dimensions here is the result
(here u can see i had to cut 2 of the pass trough because there wasnt enough clearance. AS these are nickel plated they were extremelly dificullt to get a acceptable colour. A lot of sanding went here....)
(close up of the joint as requested by PB)
(here a little surprise - first mock up)
(Finished :P)
(will look extremelly cool)
(aquaero 5 LT)
(mounted in the underside of HDD cage)
Res with temp sensors
Top Panel mounted
Remember this?
Flipped
(and here is where it goes. It covers the two tube holes just perfectly)
And now a few random shots of the work done.
(same photo with lighter ilumination)
I will post the full detail of this work once the new update comes out. For now it's only a little teaser.
Hope you enjoy
Old 8th Oct 2011, 09:40   #8
KiiYzOo
Multimodder
KiiYzOo has yet to learn the way of the Dremel
WW!!! amazing work I'm subbing to this
KiiYzOo is offline   Reply With Quote
Old 8th Oct 2011, 10:21   #9
xSoMBrAx
Supermodder
xSoMBrAx has yet to learn the way of the DremelxSoMBrAx has yet to learn the way of the Dremel
So much in such a small case... great acrylic and fitting job
__________________
Latest Project: « «[ Little Angel ]» » (FINISHED!)
Sponsors: *** Aquatuning | Atlas Informática | NZXT ***
*** ProSilentPC | Seasonic | IzarMicro | E22 ***
Follow me on Facebook!
xSoMBrAx is offline   Reply With Quote
Old 8th Oct 2011, 22:09   #10
peteski
long live the pc
peteski's Avatar
peteski has yet to learn the way of the Dremel
sweet start to the build mordillo it all looks smart as i love the black acrylic and love that mobo
subscribed
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl,
peteski is offline   Reply With Quote
Old 9th Oct 2011, 08:01   #11
Razer2007
Building Proxima
Razer2007's Avatar
Wow really good work. Nice plumbing + rep
__________________
Old 9th Oct 2011, 13:11   #12
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.
This is all seriously neat and tidy. Shaping up to be a really nice build.
bulldogjeff is offline   Reply With Quote
Old 11th Oct 2011, 07:00   #13
mordillo
What's a Dremel?
Thanks to all who have comented.
Just a little teaser of the work being done.
It is very hard to connect everything in such a tight space.
Hopefully today the loops will be finished.
Cheers.
Old 11th Oct 2011, 21:10   #14
Yeoo
Supermodder
Yeoo's Avatar
Yeoo has yet to learn the way of the DremelYeoo has yet to learn the way of the DremelYeoo has yet to learn the way of the DremelYeoo has yet to learn the way of the DremelYeoo has yet to learn the way of the DremelYeoo has yet to learn the way of the DremelYeoo has yet to learn the way of the Dremel
very understated black components, looks classy
__________________
CPU: AMD Athlon II x2 250 3.0GHz / MOBO: ASUS M4N68LE-M V2 / RAM: 4GB DDR3 1333MHz / HDD: Samsung F3 1TB / GPU: Sapphire Radeon HD 6750 / CASE: Fractal Arc Mini
My First custom build......Next Build: i5 2500k
Yeoo is offline   Reply With Quote
Old 12th Oct 2011, 08:16   #15
soul_train
Multimodder
soul_train has yet to learn the way of the Dremel
Keep it coming bro! Show us a litlle more
soul_train is offline   Reply With Quote
Old 12th Oct 2011, 16:02   #16
peteski
long live the pc
peteski's Avatar
i love that mobo. and in your case and set up so far it looks smart as .
keep up the good work
__________________
Old 16th Oct 2011, 07:47   #17
mordillo
What's a Dremel?
I am gad you enjoy. I am loving the result.
Here's an update
And finally with the 2 loops all filled up
Tomorrow should reveal a 95% done machine. Hope you enjoy
Old 24th Oct 2011, 10:17   #18
jakobfrimmel
Supermodder
jakobfrimmel's Avatar
jakobfrimmel has yet to learn the way of the Dremel
looks absolutely stunning! i love the whole composition! great build!
__________________
Main rig:
CPU: Phenom II 955 @ 4ghz cooled with a H50
GPU: HD 5850 Powercolor (Bricked) awaiting new card to hold me out till August
Motherboard: Gigabyte 890xA-ud3
RAM: 4gb ddr3 1600 OCZ @1600
jakobfrimmel is offline   Reply With Quote
Old 24th Oct 2011, 10:29   #19
andrew8200m
Not quite with it...
andrew8200m's Avatar
andrew8200m is a hoopy frood who really knows where their towel is.andrew8200m is a hoopy frood who really knows where their towel is.andrew8200m is a hoopy frood who really knows where their towel is.andrew8200m is a hoopy frood who really knows where their towel is.andrew8200m is a hoopy frood who really knows where their towel is.andrew8200m is a hoopy frood who really knows where their towel is.andrew8200m is a hoopy frood who really knows where their towel is.andrew8200m is a hoopy frood who really knows where their towel is.andrew8200m is a hoopy frood who really knows where their towel is.andrew8200m is a hoopy frood who really knows where their towel is.andrew8200m is a hoopy frood who really knows where their towel is.
Looking very good mate!
andrew8200m is offline   Reply With Quote
Old 24th Oct 2011, 10:33   #20
Vo0Ds
Fake potato
Vo0Ds's Avatar
Vo0Ds has yet to learn the way of the DremelVo0Ds has yet to learn the way of the Dremel
Wow, love how clean and elegant this is :-) Definitely one of my favourite case mods on here at the moment.
__________________
Masara: i5 2500@4.2Ghz | Asus P8P67LE | EVGA GTX460SC | 8Gb Corsair 1600 | 1TB WD-C BLACK | Fractal R3 | LG 23" IPS
LEGO Ghetto HTPC: Broken-ass laptop pulled apart, now a HTPC... made of LEGO. UNDER CONSTRUCTION
Vo0Ds is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
