Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 10th Oct 2011, 21:49   #81
phinix
Say it! Who's your dremel?!
phinix's Avatar
phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!
So is that latest patch/update fixing the texture problem? Or is it still ugly?
__________________
::: i5 2500K :: GTX670 :: 2x 840 PRO 128GB :: Gigabyte Z77 mATX :: 4GB Ballistix :: Hazro 27" :: CM QF Rapid MX Browns :::
projects: ::: “PHINIX CUBE” ::: "PHINIX nanoTOWER" ::: "PHINIX AURORA" :::
phinix is offline   Reply With Quote
Old 10th Oct 2011, 23:32   #82
IvanIvanovich
будет глотать вашу душу.
IvanIvanovich's Avatar
IvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on you
I forced 8k already, but I haven't noticed any additional improvements. Far objects still look terrible. If near objects still look bad, i suggest you should do the same as it does help it look considerably nicer for things in the foreground.
__________________
[end of line]
intel i5-750 | evga p55 sli | 8gb mushkin blackline | evga gtx670 | 240gb mushkin chronos dx
| creative titanium hd | mushkin 580w | gh60 custom | logitech mx revolution | achieva shimian qh270
IvanIvanovich is offline   Reply With Quote
Old 11th Oct 2011, 01:35   #83
thehippoz
Banned
thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!
muddy textures? bad sky?
it might be like that because of the auto balancer.. I'll take some more screens tonight
it's nothing like described in this thread.. but being on amd I have to play at 30fps until they fix their driver..
there are textures that are compressed to hell but it's very obvious.. nothing muddy about them- they are clear as day.. I almost want to put in the 460 to see what you guys are talking about
or do I
thehippoz is offline   Reply With Quote
Old 11th Oct 2011, 01:50   #84
IvanIvanovich
Yep, the autobalancer sucks. Thats why Forcing 8k, or if you have over 1.5gb vram, you can go to 16k it makes it look a lot better as you are essentially bypassing the autobalancer. But it sounds like some things are very different for nvidia vs amd user. Each has it's own set of issues. I have nvidia, so all i know is that following the guide for the rageconfig.cfg and the beta driver has eliminated all of the tearing and pop in for me, and made it look much better except for distant object which are still terrible.
It's not that the distant things look vague, which they should. It's that distant things look like sharply defined things with terrible textures. That is not the way to do it. They need some bokeh or something.
__________________
[end of line]
Old 11th Oct 2011, 06:21   #85
thehippoz
Banned
yeah lysol.. hope they get a texture pack- but in game it looks fine least to me..
wish my back wasn't killing me right now, I'd probably pull a late one..
*edit- some better shots where you can see the texture fails.. and some more good shots
Old 11th Oct 2011, 12:57   #86
Apocalypso
Fully armed and operational.
Apocalypso's Avatar
Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!Apocalypso - it's over 9000!!!!!!!!1!1!1!!!
I've enabled the 8k textures with the rageconfig.cfg but I still think it looks woeful.
__________________
Intel Core i5 2500k | ASUS HD 7970 DirectCU II | 8GB Corsair XMS3 1600MHz | Crucial M4 128GB | F3 1TB x 2 | Asus Sabertooth P67 | Corsair HX1050 | HAF 932 | Dell U3011
EK Supreme HF | XSPC RX360 | Scythe AP-14's | MCP355
ARCAM rDAC | Matrix M-Stage Amp | KRK RP5 G2 | KRK 10s | Beyerdynamic DT990 600Ω
Apocalypso is offline   Reply With Quote
Old 11th Oct 2011, 20:34   #87
Pete J
The upgrade bug biteth...
Pete J's Avatar
Pete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on youPete J - may the hammer of Bindi be bestowed on you
Ditto. I tried 16k but predictably ran into memory issues.
And no SLI support sucks MAJOR donkey balls.
__________________
Lian Li PC-P80B / EVGA Classified 3 / i7 920 D0 @ 4043GHz (no HT) / NH-U12P / 3x4GB Corsair Vengeance @ 1544MHz 8-8-8-24-1T / 3x EVGA 3GB GTX 660 Ti SC+ @ 1150MHz core boost 7400MHz memory / X-Fi Titanium Professional / 2 x 250GB Samsung 840 / 120GB Vertex 2 / 2x1TB RAID0 Spinpoint F1 / 2TB WD Caviar Green / Silverstone 1500W / 3007WFP-HC / 2407WFP / Beyerdynamic MMX300 / Logitech K350 Wireless Curve / Razer Mamba (2012) / Sidewinder Force Feedback 2 / Datacolor Spyder3 / Windows 7 Ultimate x64
Pete J is offline   Reply With Quote
Old 11th Oct 2011, 21:57   #88
phinix
phinix's Avatar
WOW!!! Does it really look that bad?!!!
__________________
Old 12th Oct 2011, 13:13   #89
thehippoz
Banned
not really.. you have to play it to see- it's just certain textures in game.. amd are really taking their time fixing the beta driver
I can't even play at 60fps because there's a bug in the fixed video driver for dual cores.. using a older driver- but you can see the graphics are decent
check it out in 720p- was capped in 1080 on a 6970 (sorry about the lag and fps- game play is much faster without fraps)
if ati could keep that quality on the 10.6 and fix the bugs..
Old 12th Oct 2011, 15:35   #90
soviet_
Bantros
soviet_'s Avatar
soviet_ has yet to learn the way of the Dremelsoviet_ has yet to learn the way of the Dremel
This isn't a reply to anyone in particular, just in general to a lot of the negative comments I've seen on here and other forums.
How anyone can say this game looks bad is beyond me. First time we've seen a game with true artistry being used but all because the textures are a bit murky and lo res at close range, apparently it's a huge ugly mess of a game and John Carmack can go and **** himself.
Well, I for one think it's absolutely fantastic and not only to look at. The shooting mechanics are solid, as you would expect but still a lot of games get this feeling wrong. Character movement is just right and the racing is great. Voice acting is good, the characters look brilliant, even the general NPCs look better than some lead characters in other games.
Of course I have some gripes as there's some texture pop in, although it's not been that apparent for me, and yes at close range the textures lack definition but I think the fact that everywhere in the game looks pretty unique and I haven't noticed a repeated area makes up for it. Obviously the launch was a bit of a mess and the game wouldn't even start for me until I messed around for almost an hour so I get why some people are pissed off.
__________________
i5 2500K @ 4GHz / ASUS P8-P67 PRO / 8GB Corsair DDR3 / PowerColor HD 6970
Crucial 128GB SSD / Samsung F3 1TB / Corsair HX 850 / Antec P182 / Dell 2408WFP
soviet_ is offline   Reply With Quote
Old 12th Oct 2011, 17:04   #91
tranc3
ADHD Modder
tranc3's Avatar
tranc3 has yet to learn the way of the Dremeltranc3 has yet to learn the way of the Dremel
I haven't had any problems since the patch, and even before that it I was only having the texture pop in issue, and fixed that with a few tweeks. Game is running solid on my system and looks fine. I hear ATI is still having a problem but I can't confirm that. Nvidia has a guide on setting it up if you look around.
-edit
You can tell that the charters have a much higher resolution texture then the world.
__________________
[AMD Kuma 7750 2.77 |Asus M3N78-EM|Mushkin 4x1GB DDR800 |WD Caviar 500GB|GeForce EVGA GTS 250 512MB|OCZ StealthXStream 600]
tranc3 is offline   Reply With Quote
Old 13th Oct 2011, 07:41   #92
phinix
phinix's Avatar
I finally tried it yesterday, it doesn't look that bad I guess.
However I found one thing annoying - every time I move fast to the left or right or other direction, textures are low res and first half a second or so, then change to high - like loading it slowly or something. Did anyone notice it too? Why is it happening, is it hdd too slow? Should I install it on ssd?
__________________
Old 16th Oct 2011, 01:58   #93
thehippoz
Banned
just beat it.. pretty short ending really
would have liked to have seen a little more.. but the bfg was nice to see up close.. it was almost as big as supermonkeys toys
can try this.. the textures load in once at the start, but after that it should be good
http://forums.steampowered.com/forum....php?t=2154053
Old 16th Oct 2011, 18:55   #94
scott_chegg
It's a tool.
scott_chegg's Avatar
scott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for presidentscott_chegg should be considered for president
Good find thehippoz. The hq high spec file has completely elimated the texture pop in.
__________________
My System: i5 2500K @ 4.7Ghz | MSI P67A-GD65 (B3) | 16GB Crucial Ballistix Sport 1600MHz | Corsair H-50 Push-Pull with Silent Eagle 2000's | Silverstone Raven RV03 | EVGA 670 FTW | Dell SP2309W | Antec 750W TruePower Blue | Win 7 x64 | Crucial 64GB C300 for OS | Samsung 830 256GB for Active Games & a 1TB Samsung for Steam. Perphiperals: Roccat Kone+ Max V2 | CMStorm Quickfire Pro with Cherry Reds | Cyborg F.L.Y 5 stick for flying and a Logitech DF GT for driving.
scott_chegg is offline   Reply With Quote
Old 16th Oct 2011, 20:48   #95
Pete J
Pete J's Avatar
Finished it.
VERY disappointed by the ending. The story was all over the place and I still don't know why I had to do any of the objectives.
Luckily I'm in an indifferent kind of mood so I'm not too upset. The combat was more or less solid, though the melee should've had a wider area of effect.
__________________
Old 17th Oct 2011, 04:18   #96
mav2000
In Training
mav2000 has yet to learn the way of the Dremel
I like the gameplay, but I am just at the begining of the game as of now...seems to be fun though, nothing in the story seems to fit in right now...I wish the tasks were more than go here go there types.
But all in all, I am enjoying it right now. BTW< whats the best driver for ATI and this game? Tried 11.9, but having all types of screen tearing issues.
mav2000 is offline   Reply With Quote
Old 28th Oct 2011, 11:15   #97
phinix
phinix's Avatar
Cheers, I will try that.
Been playing it for a while and like it. Not love it, but like it. gameplay is nice, it "calls me back" every day when come back home, so its good
So far I like it, will see what happens...
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
