Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 2nd Oct 2011, 11:44   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Roccat Kova+ Review
Can the refresh of the ambidextrous Kova provide pointer nirvana for righties and lefties?
http://www.bit-tech.net/hardware/201...-kova-review/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 3rd Oct 2011, 11:37   #2
Farfalho
Supermodder
Farfalho's Avatar
Farfalho has yet to learn the way of the Dremel
So the Kova+ has the warning sound and its size as cons? In case of a leftie, would you really recommend it or just point to him as an option?
Farfalho is offline   Reply With Quote
Old 4th Oct 2011, 15:23   #3
Tyinsar
6 screens 1 card since Nov 17 2007
Tyinsar's Avatar
Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.
As a lefty I appreciate ambidextrous mice. As for the size I tend to be a more of a fingertip user (rather than palming the mouse) so the size might not be an issue. I'll have to keep my eye out for this.
Thanks for the review.
__________________
Regardless of what you believe there is someone at least as smart, or smarter, than you who believes something you think is stupid (and it's not just because you know something they don't).
Tyinsar is offline   Reply With Quote
Old 27th Oct 2011, 15:07   #4
fingerbob69
Hypermodder
fingerbob69's Avatar
fingerbob69 has yet to learn the way of the Dremelfingerbob69 has yet to learn the way of the Dremel
Because I won't buy something like a mouse with out trying it for size first, I found myself in Currys last night. Their gaming selection wasn't quite as comprehensive instore as online
http://www.currys.co.uk/gbuk/gaming-...-criteria.html
but they did have, in the under £40 bracket -my budget- the CM Storm, the Razor Abyssus and this Roccat.
The Cm was too long for my smallish hands.
The Razor was too low profile.
This Roccat felt great and has in the very short time I've had it, been excellent.
__________________
Antec 902, Asus P6T se, i7-920 D0 oc@3.6ghz, Asaka Nero S, 6gb Corsair, Thermaltake 750w Evo Blue, MSI R9-280 OC @1065/1315, Asus Xonar DS, 2x 500gb Seagate HDD, Win7 hp, NEC ea231wmi, MS X4, Roccat Kova+
Cordless Mouseman optical ...deceased
XFX 4890 + Artic Twin Turbo Pro ...retired 26.10.2014
fingerbob69 is offline   Reply With Quote
Old 27th Oct 2011, 16:43   #5
Fishlock
.o0o.
Fishlock's Avatar
Fishlock is the Cheesecake. Relix smiles down upon them.Fishlock is the Cheesecake. Relix smiles down upon them.Fishlock is the Cheesecake. Relix smiles down upon them.Fishlock is the Cheesecake. Relix smiles down upon them.Fishlock is the Cheesecake. Relix smiles down upon them.Fishlock is the Cheesecake. Relix smiles down upon them.Fishlock is the Cheesecake. Relix smiles down upon them.Fishlock is the Cheesecake. Relix smiles down upon them.Fishlock is the Cheesecake. Relix smiles down upon them.Fishlock is the Cheesecake. Relix smiles down upon them.Fishlock is the Cheesecake. Relix smiles down upon them.
I've owned this mouse for some time. I have neither big or small hands and the mouse is very comfortable. The software that it comes with is brilliant. The only downside I would say is that the buttons on your little finger aren't easy enough to press for the strength in that finger, if that makes sense...
Fishlock is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
