Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 3rd Oct 2011, 06:46   #1
whiterook6
Minimodder
whiterook6 has yet to learn the way of the Dremel
Front headphone jack doesn't recognize headphones
Hi. I just finished building my computer and installing Windows 7 (thanks to no small help from this forum). The only things that currently isn't working are the front audio jacks.
The cable from the case front has both an HD audio plug and an AC'97 plug, both of which fit into the motherboard. The motherboard itself says "JAUD1" which doesn't tell me which I should use, although the motherboard's driver dvd says HD Audio Drivers.
Anyways, I've installed and reinstalled the drivers on the disk and then the HD Audio drivers from Realtek's website. I'm running Windows 7 64bit. The motherboard is an MSI P67A-G45. The front USB ports work, as does the rear audio jack. I've tried both plugs on that cable. I don't know what to try next.
Thanks.
whiterook6 is offline   Reply With Quote
Old 3rd Oct 2011, 07:22   #2
fdbh96
I *am* a Dremel
fdbh96's Avatar
fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.
Just use the hd audio and there shoul be a specific slot for it. Unistall the ac97 driver and leave the hd one.
fdbh96 is offline   Reply With Quote
Old 3rd Oct 2011, 13:19   #3
rv88uk
Multimodder
rv88uk has yet to learn the way of the Dremel
I think they include both plugs to ensure support with older tech, HD Audio is the better of the two so stick with that. I'd check in the bios to make sure it's not disabled (although it should be enabled by default) and perhaps look in device manager to make sure it's detected with drivers installed (by the way, never use drivers off a disc, always get the latest online, you can grab all the drivers from MSI's website here)
__________________
i7 6700k | Asus ROG Max VIII Hero Z170 | 16GB Corsair Vengeance DDR4-3000 | Noctua NH-D15 | MSI GTX980Ti Twin Frozr V | Arcam irDac + Graham Slee Solo SRGII + Focal Elear | 512GB Samsung 850 Pro | 1TB WD Black | 2x 2TB WD Green | Seasonic X-750 | Fractal Design Define R5 w/ 3x Noctua NF-A14 | Asus PCE-AC68 Wireless Adaptor | Razer Black Widow + Logitech G500s | Dell U2713HM
rv88uk is offline   Reply With Quote
Old 4th Oct 2011, 01:15   #4
whiterook6
Minimodder
HD Audio was indeed enabled in the BIOS. I've uninstalled the audio drivers and installed the drivers from the MSI website. The device manager doesn't show any warnings or missing drivers.
Curiously, there are NVidia High Definition Audio devices in the Device Manager. Is that normal?
Old 4th Oct 2011, 11:07   #5
rv88uk
Multimodder
Try opening up the playback devices menu (control panel -> Hardware and Sound -> Under Sound select Manage Audio Devices), can you see any options for front panel audio/headphones?
I've disabled motherboard audio so I'm not exactly sure what options will be there, but hopefully it'll be obvious if there is a front panel option.
__________________
Old 4th Oct 2011, 15:06   #6
whiterook6
Minimodder
When I open the Manage Audio Devices window, I don't see anything that mentions the front panel--only Speakers, Realtek Digital Output, and Realtek Digital Output(Optical), and in recording, Microphone and Line In.
Old 5th Oct 2011, 02:23   #7
whiterook6
Minimodder
I uninstalled all the audio drivers I had installed (there were a couple NVidia ones, though in retrospect those were probably just for the HDMI) and reinstalled the HD audio drivers from the msi website. I still get no front headphone jack or microphone detection.
Any other thoughts?
Old 5th Oct 2011, 11:30   #8
rv88uk
Multimodder
If you have the realtek drivers installed (high definition audio driver) open the 'Realtek HD Audio Manager', look for 'Connector Settings' and uncheck 'disable front panel jack detection' (there's a guide image here).
It may also be worth checking you've fitted the cable correctly, making sure the missing pins line up, and it's connected to jaud1 (bottom left of mobo by the looks of it).
__________________
Old 13th Oct 2011, 22:28   #9
whiterook6
Minimodder
thanks for all the replies. I have tried all of the above, including disabling and re-enabling the front audio jack detection, and installing/removing all sorts of drivers. At which point should I cave and buy a sound card, or send it to the shop to be fixed?
Old 15th Oct 2011, 15:05   #10
Sarneus
Minimodder
Sarneus has yet to learn the way of the Dremel
I just finished building my new PC 2 days ago, and I'm having the same exact problem, I have the MSI Z68-GD55, I plugged in the HD Audio connector coming from the front panel (I have a HAF922 case) but when I plug a mic or headphones they dont get recognized and no sound comes out (or goes in). I checked the connector three times already and i'm sure its properly plugged in so I'm not really sure what else I can do to fix it.
Sarneus is offline   Reply With Quote
Old 15th Oct 2011, 17:33   #11
whiterook6
Minimodder
My friend gave me a great idea yesterday: he suggested running an Ubuntu Live disk and see if it manages to automagically detect the front headphone jack, which would tell me if it's the hardware or my windows installation that's keeping it from working.
Old 16th Oct 2011, 16:58   #12
whiterook6
Minimodder
I tried running the Ubuntu Live disk and the drivers didn't recognize it there, either. My last test is using my friend's computer with my HD Audio cable, and then his HD Audio cable with my computer. This will show if the cable works, or if the motherboard works, or both.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
