Go Back   bit-tech.net Forums > Partner Forums > Scan Computers
Reply
Thread Tools
Old 6th Oct 2011, 18:48   #1
Ralphy
What's a Dremel?
Ralphy has yet to learn the way of the Dremel
Is Incompatibility a Fault, Scan say not
To cut a long story short I bought a Corsair gt 60 gig ssd
Have been trying to get it to work now for a good 2 weeks there are issues with these drives and my marvell controller, its well documented and Corsair know about it but havent yet got a fix.Wish id known before I bought it
Scan are usually good but on this occasion they refuse to RMA my drive for a refund or a swap, they say there is no fault.
I have spent hours on this problem have applied all the updates , flashed the bios, updted the firmware on the drive, Corsair sent a list of things to try which I did, its better now than it was but still I get blue screens and crashes. its is unusable and I have had enough.
So it looks like I am left with an expensive doorstop
and Ill think twice about buying from Scan again
Ralphy is offline   Reply With Quote
Old 7th Oct 2011, 08:37   #2
ChrisP
Retail Sales Manager
ChrisP's Avatar
ChrisP can run CrysisChrisP can run CrysisChrisP can run CrysisChrisP can run CrysisChrisP can run CrysisChrisP can run CrysisChrisP can run CrysisChrisP can run Crysis
Ralphy
Incompatibility is not a fault it means it does not work with product x but may work with product y.
A Fault would mean the product does not function with any product.
For example if you use the wrong brand memory used with a certain chipset would cause the memory not to be recognised, this is incompatible. However when the same memory used with a different chipset, would work then the product is clearly not faulty as it is working.
All of the Firmware issues with the Corsair SSD's should have been resolved.
If you can confirm your RMA number we can look into the issue and confirm your options.
Best Regards
__________________
"A Customer is not simply an invoice but a welcome addition to the Scan family"
ChrisP is offline   Reply With Quote
Old 7th Oct 2011, 13:22   #3
Ralphy
What's a Dremel?
Thanks Chrisp
I have no RMA but I have the query
Query 0965587 - {3931E839-9677-4F80-8C12-A8B873AA1FA4}
Old 11th Oct 2011, 15:53   #4
AlphaAngel
I'm not half arsed, I'm an arsehole
AlphaAngel's Avatar
AlphaAngel is almost as Godly as yodasarmpitAlphaAngel is almost as Godly as yodasarmpitAlphaAngel is almost as Godly as yodasarmpitAlphaAngel is almost as Godly as yodasarmpitAlphaAngel is almost as Godly as yodasarmpitAlphaAngel is almost as Godly as yodasarmpitAlphaAngel is almost as Godly as yodasarmpitAlphaAngel is almost as Godly as yodasarmpitAlphaAngel is almost as Godly as yodasarmpitAlphaAngel is almost as Godly as yodasarmpitAlphaAngel is almost as Godly as yodasarmpit
Ralphy,
I have sent you a PM. Have a look and PM me if you need more help.
(I think you need to read the posts in reverse order)
AA
AlphaAngel is offline   Reply With Quote
Old 11th Oct 2011, 19:58   #5
Ralphy
What's a Dremel?
AA Thank you
Unfortunatley I cant PM you as I havent qualified yet due to my post count
But I have taken on board your advice
Old 15th Oct 2011, 15:00   #6
Ralphy
What's a Dremel?
No answer from Chrisp then
Old 17th Oct 2011, 08:27   #7
ChrisP
ChrisP's Avatar
Ralphy
Wesley's e-mail from the 5th confirms the following:
I can confirm we cannot issue an RMA for the item as you have clearly stated the device is operating fine on the different controller, the item does not contain a hardware fault but a compatibility between the item and the controller you are trying to run it from, this is not covered under warranty as warranty does not cover compatibility.
__________________
Old 17th Oct 2011, 11:42   #8
Ralphy
What's a Dremel?
Chrisp
The drive is operating on a Sata2 I bought it to run on a Sata3
so it runs at half speed
Old 17th Oct 2011, 15:49   #9
Fizzban
Reformed Grumpy Sod..kinda
Fizzban's Avatar
Fizzban - it's over 9000!!!!!!!!1!1!1!!!Fizzban - it's over 9000!!!!!!!!1!1!1!!!Fizzban - it's over 9000!!!!!!!!1!1!1!!!Fizzban - it's over 9000!!!!!!!!1!1!1!!!Fizzban - it's over 9000!!!!!!!!1!1!1!!!Fizzban - it's over 9000!!!!!!!!1!1!1!!!Fizzban - it's over 9000!!!!!!!!1!1!1!!!Fizzban - it's over 9000!!!!!!!!1!1!1!!!Fizzban - it's over 9000!!!!!!!!1!1!1!!!Fizzban - it's over 9000!!!!!!!!1!1!1!!!Fizzban - it's over 9000!!!!!!!!1!1!1!!!
With things like compatibility issues you need to send the item back within 7 days of purchasing, I believe.
__________________
-Banana in disc drive error-
To win the battle, is to be prepared to die - Miyamoto Musashi
Fizzban is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
