View Poll Results: What to do: Black or white tubing!?
Black! 32 43.24%
White! 39 52.70%
No idea, I hate water cooling! 3 4.05%
Voters: 74. You may not vote on this poll
Reply
Thread Tools View Mode
Old 16th May 2012, 09:02   #221
Winkston
Minimodder
Winkston has yet to learn the way of the Dremel
excelent working.
And great PSU's btw.
Winkston is offline   Reply With Quote
Old 17th May 2012, 21:07   #222
xSoMBrAx
Supermodder
xSoMBrAx has yet to learn the way of the DremelxSoMBrAx has yet to learn the way of the Dremel
Originally Posted by Winkston View Post
excelent working.
Thanks!
And yes, Seasonic PSU's are great
I've just recieved the hardware from Izar Micro, so after a year I can finally tell you what I'm going to put inside my Little Angel
"Little Angel" Hardware List
I will try to post also the final watercooling parts aswell
__________________
Latest Project: « «[ Little Angel ]» » (FINISHED!)
Sponsors: *** Aquatuning | Atlas Informática | NZXT ***
*** ProSilentPC | Seasonic | IzarMicro | E22 ***
Follow me on Facebook!
xSoMBrAx is offline   Reply With Quote
Old 19th May 2012, 09:43   #223
xSoMBrAx
Supermodder
The last radiator has been installed!
I will add more detailed picture to show how the fans of that radiator are connected to the Aquaero.
I think it looks much better with the little caps also give some contrast against the white.
Getting close!
__________________
Old 19th May 2012, 18:57   #224
Raikkok
Multimodder
Raikkok's Avatar
Raikkok has yet to learn the way of the Dremel
Hey Sombra!
Is there anymore to do it or just wait for the new superhard?
See you
__________________
"Raikkenstein Mod" http://forums.bit-tech.net/showthread.php?t=215645
MOTM January 2012 Winner
Raikkok is offline   Reply With Quote
Old 20th May 2012, 08:57   #225
xSoMBrAx
Supermodder
Originally Posted by Raikkok View Post
Hey Sombra!
See you
Hey Raikkok, there is still a lot to do I'm afraid...
You always find something that doesn't match or something else goes wrong and you have to rethink the whole assembly hehe
I'm having trouble with the Aquaero 5 + PA2 module + CD Drive + Top radiator setup.
The top radiator goes all the way to the front and uses half of the 5 1/2 bay so there is not much space to connect everything.
Also I need to connect the radiator with the AQ5 to watercool it and with tubing is going to be a very tight fit but all my loop depends on that connection.
Today I'm going to show you the pumps I'm going to use for the setup:
Swiftech Dual 35X with their new top
Here is how I plan to connect reservoir + pump. (Please mind the foam... I'm not going to place it like that, will show you later )
First thing I have to do is some custom wiring + sleeving
What I'm going to do is connect each pump directly to the PSU. Each pump on different 12v rail...
The other wires you see are for adjusting the pump speeds via PWM, and that will be managed by Aquaero 5.
I will first bridge the PWM cables from each pump and then make a unique connection to the Aquaero, that way both pumps will work at same speed all the time (based on the Aquaero 5 settings)
More soon...
__________________
Old 21st May 2012, 19:47   #226
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
That block is RAD!
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 21st May 2012, 21:15   #227
Noob?
Dremel?
Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.
The build is astonishing!
Those Seasonic PSU's are class!
Noob? is offline   Reply With Quote
Old 22nd May 2012, 11:07   #228
xSoMBrAx
Supermodder
Originally Posted by Nutman View Post
That block is RAD!
Yes, very well built and awesome performance (and heavy too! )
I've been doing some sleeving to the 24 pins that are going to be plugged to the dual PSU starter I have.
Check the picture but this is not going to be the final result, you will have to wait some time to see the end result
Custom length wires ready!
Each wire sleeved individually and because of the custom length of each wire the sleeving was a bit of a pain in the.... fingers. A lot of measurement going on!
Finally because of the personal way to start the PSU's I had to measure each wire individally since I didn't want end up having some short cables and other long cables once plugged into PSU and PCB.
As already said, still waiting for some other parts to make all this more eye-candy hehe
__________________
Old 22nd May 2012, 12:26   #229
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
Im not a fan of individually sleeved cables, but very nice work on getting the wires the correct size, good attention to detail
Mankz is offline   Reply With Quote
Old 25th May 2012, 22:15   #230
samfgr
techno : my life
samfgr can run Crysissamfgr can run Crysissamfgr can run Crysissamfgr can run Crysissamfgr can run Crysissamfgr can run Crysissamfgr can run Crysissamfgr can run Crysissamfgr can run Crysis
looks really good looking foward to new picture
samfgr is offline   Reply With Quote
Old 25th May 2012, 22:32   #231
Nutman
Nutman's Avatar
What is the alternative, if you want to sleeve e.g. the 24-pin ATX cable?
__________________
Old 26th May 2012, 12:45   #232
xSoMBrAx
Supermodder
Thank you guys for the kinds words
I've just finished sleeving the pump, so let me show you the "almost finished" product
First thing I had to do was to solder extensions to the original wires and get rid of the molex type of connector since I'm going to plug the pumps directly to the PSU (Molex out, 6 pin connector in!)
Green and blue wires are used to send the PWM signal to pumps
To have both pumps at same speed at the same time I just had to connect the PWM wires in series.
I also replaced the white connector with 4 pin black connector.
This is how I decided to route the cables to the lower section and onto the PSU.
I think they look good and will be hidden aswell
Motherboard connections will also have black & vanilla color combination, just not sure about the pattern
And this is how I left everything last night.
I like the routing but needs to be improved, maybe will have to add some other clips to keep the sleeved cables stretched instead of this spaghetti style
__________________
Old 27th May 2012, 23:36   #233
wratterus
Minimodder
wratterus's Avatar
wratterus has yet to learn the way of the Dremel
Awesome work with the sleeving, the PSU starter cables look great!
wratterus is offline   Reply With Quote
Old 28th May 2012, 08:50   #234
xSoMBrAx
Supermodder
Thank you very much wratterus
I think the dual PSU starter is one of the challenges I had during this setup (because of how do I had to sleeve and measure each single wire lol)
Today It's my day off, so I'm already doing some work on the motherboard.
I took some pictures last night, just wanted to share them with you
The bullets don't look that bad once the board is installed but is something that I don't like and will have to do something about it...
I will update later!
__________________
Old 28th May 2012, 09:40   #235
damien c
Mad FPS Gamer
damien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for president
Looking great still.
I think the best bet for the board would be to see if you can get water blocks to cool it if you don't, like the block's already on it.
I cannot wait to see the finished result's though.
__________________
Core I7 3930K, Rampage IV Extreme, 16GB Corsair Vengance 1600mhz, GTX 680 SLI, Corsair Force 3 250Gb SSD, Creative Sound Blaster X-Fi Titanium, NZXT Switch 810, XSPC RX 360mm + Alphacool 240mm All Copper, 10x Scythe Kazi Jyuni 1900rpm 5v & And It's Silent!!!!!!!!! .
Market Place Feedback
http://forums.bit-tech.net/showpost....&postcount=104
damien c is offline   Reply With Quote
Old 28th May 2012, 09:47   #236
amagriva
Multimodder
amagriva's Avatar
amagriva has yet to learn the way of the Dremel
[quote=
I will update later![/QUOTE]
Yes! Totally agree! Out with the bullets in with the...whatever you like!
amagriva is offline   Reply With Quote
Old 28th May 2012, 11:32   #237
Nutman
Nutman's Avatar
I don't think it's too bad with those bullets. Their colour matches the gold parts of the rest of the build and also the vanilla sleeving.
But OK, if you still want to do something about them and if you can't get a water block (yet?) for the motherboard, how about if you simple painted the bullets black?
__________________
Old 28th May 2012, 23:03   #238
Mizugetsu
Multimodder
Mizugetsu's Avatar
Mizugetsu has yet to learn the way of the Dremel
I can't stand those faux bullets have you though about maybe adapting a Waterblock for the bit or
Mizugetsu is offline   Reply With Quote
Old 28th May 2012, 23:05   #239
xSoMBrAx
Supermodder
I was hoping to have more options for watercooling the board lol
Waterblock would be the only answer
Thing is the bullets don't look that bad once you have the board at home, and also the color matches the build.
I hope to watercool it anytime soon
More updates from today!
I've been doing some wiring and crimping today.
This board has 2 4pin connectors instead just 1 as we can usually see in other motherboards.
I think that it looks quite nice!
Tomorrow I will finish the routing of cables and will crimp the other side of the connectors aswell.
I still need to measure each wire so once connected they still look nice, and then jump to the sleeving!
__________________
Old 29th May 2012, 01:58   #240
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
There are waterblocks for the MSI BBXPII, the mofsetblock is already done and out in EKWB store, the SB is soon finished ;D
KoSoVaR^ is offline   Reply With Quote
Reply
Tags
little devil, white build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
