View Poll Results: What to do: Black or white tubing!?
Black! 32 43.24%
White! 39 52.70%
No idea, I hate water cooling! 3 4.05%
Voters: 74. You may not vote on this poll
Reply
Thread Tools View Mode
Old 14th Oct 2011, 00:11   #21
xSoMBrAx
Supermodder
xSoMBrAx has yet to learn the way of the DremelxSoMBrAx has yet to learn the way of the Dremel
- Sponsors -
Aquatuning España / Atlas Informática / NZXT
ProSilentPC / Seasonic / IzarMicro
Gracias a todos los sponsors por colaborar en el proyecto.
Many thanks to all the sponsors for the support given to this project
A small update before going to sleep!
I just finisehd removing all speed controller and sleeving from NZXT fans
I left the 2 140mm fans to the end, and I was surprised when I removed the sticker and saw that there was no access to the internal PCB...
I had 2 options. First was to solder the fan controller wires together to avoid reaching the PCB or the second which was make a cut into the plastic of the fan and get to the PCB to remove the wires from the speed controller and link the connector in the PCB
I was afraid to damage the PCB, the body of the fan (more than intended) or even cut the wires!
My dremel had only big discs so I had to cut the plastic really slow
Not the best cut in the world, but at least I didn't damage the PCB, Wires, fan, and since the hole will be covered with a custom sticker I don't care that much
After 24 hours of hard work I ended up doing this cool NZXT logo to cover the hole
Well at least you can imagine how the fan will look once the stickers are ready
__________________
Latest Project: « «[ Little Angel ]» » (FINISHED!)
Sponsors: *** Aquatuning | Atlas Informática | NZXT ***
*** ProSilentPC | Seasonic | IzarMicro | E22 ***
Follow me on Facebook!
xSoMBrAx is offline   Reply With Quote
Old 18th Oct 2011, 22:36   #22
xSoMBrAx
Supermodder
- Seasonic X-850 -
Finally the Seasonic X-850 is at home!
Enjoy the pictures!
Cables / wires come in a very nice bag with Seasonic logo and following the black and gold theme
Usually you get a set of cables with each PSU, but Seasonic kindly sent me spare cables so I can work the custom length wires + sleeving
Thank you very much Seasonic!
Nice black sleeving, but still can see through, we have to change that soon!
WARNING! Fanless mode enabled under 20% LOAD!
100% Modular PSU... my first one!
Really want to start this project as soon as possible and sleeve this beauty
Would like to thank once again to Seasonic for the support!
X-850 Review @ Hardware Secrets
__________________
Old 18th Oct 2011, 23:54   #23
alternativesurfer
What's a Dremel?
alternativesurfer has yet to learn the way of the Dremel
Really looking forward to seeing how this turns out.
Subbed
alternativesurfer is offline   Reply With Quote
Old 19th Oct 2011, 00:20   #24
Luciel
Multimodder
Luciel's Avatar
Luciel has yet to learn the way of the DremelLuciel has yet to learn the way of the DremelLuciel has yet to learn the way of the DremelLuciel has yet to learn the way of the DremelLuciel has yet to learn the way of the Dremel
Great work so far Sombra!! : )
I know the people at Atlas, they are great, used to work with them all the time when I owned a computer shop : )
Luciel is offline   Reply With Quote
Old 19th Oct 2011, 08:14   #25
bruce_rob
Supermodder
bruce_rob's Avatar
bruce_rob has yet to learn the way of the Dremel
Looking good i like the unboxing pics
bruce_rob is offline   Reply With Quote
Old 19th Oct 2011, 08:17   #26
KiiYzOo
Multimodder
KiiYzOo has yet to learn the way of the Dremel
how did you get sponsored?
KiiYzOo is offline   Reply With Quote
Old 19th Oct 2011, 20:56   #27
xSoMBrAx
Supermodder
Subbed
Thanks, will do my best, It doesn't matter how long it takes
Thanks! Yes, Atlas Informática helped me a lot and trusted in the project when I had no more thing than words
Thanks... I try to do my best to thank sponsors for the products
It all started here, very helpful
__________________
Old 20th Oct 2011, 05:31   #28
xSoMBrAx
Supermodder
Now I'm trying to work on a small logo, will keep you guys updated and see what you think!
Also I'm still undecided what to do with the graphic cards... let's see what happens in November if there are any news with Battlefield 3 launch!
Some pictures I forgot to take and upload to finish the unboxing of the PSU...
3 x Plugs with a total of 8 SATA power connectors
3 x Plugs with a total of 8 MOLEX connectors
Molex adapter to floppy type connector...
Additional 8 pin power for motherboard!
The good old 24 pin!
2 x Plugs for graphic cards, each with 2 x 6 to 8 pins.
This is all you need to power your SLI or Crossfire without the need of other molex to GPU adapters
Thanks for watching!
__________________
Old 20th Oct 2011, 21:24   #29
xSoMBrAx
Supermodder
Tiny update!
I know it's not necessary, but I had to change those green o-rings from the bitspower fittings, so I ordered some black Bitspower O-rings to change all of them...
Much better... right?
I don't like the valve I bought, looks tooooooo small compraed to the compression fittings, and also silver does not match the rest of the build... DO NOT USE!
More picture... soon?
__________________
Old 23rd Oct 2011, 22:14   #30
xSoMBrAx
Supermodder
Good night!
I want to show you something guys and tell me what you think
There was something I wanted to do, even before I ordered the case, and was to replace the M3 screws with Thumbscrews, and I just did that... what you guys thinkg?
First thing I removed are the 10 M3 screws that are used by the PCI Covers....
I have to paint them
Here you can see the Little Devil's factory M3 screws
And here replaced with black thumbscrews
Also for the 5 1/2 bays...
When I ordered the Thumbscrews I did not notice but I got half of them M3 and the other half are UNC 6-32 (If I'm not wrong, since those fit in the HDD's!)
As you can see the paint is not very good, I want to repaint all of them but I need some help.. what you guys recommend?
Should I remove the original paint and then apply new paint?
Any special treatment so It lasts longer?
Thanks
__________________
Old 29th Oct 2011, 09:32   #31
p0Pe
gief cake?
p0Pe's Avatar
p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!
Beautiful case, beatiful photography, and beatiful parts This should be good!
The valve you want is THIS one!
+rep
__________________
p0Pe is offline   Reply With Quote
Old 29th Oct 2011, 09:49   #32
improprietary
FT03 is a bitch to watercool
improprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremel
cheap way is to spray paint them, +rep way is to clean them in acid, anodize them and then give it a protective coating
improprietary is offline   Reply With Quote
Old 29th Oct 2011, 15:14   #33
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.
I do like the look of that case, it's got loads of modding potential.
bulldogjeff is offline   Reply With Quote
Old 31st Oct 2011, 06:47   #34
xSoMBrAx
Supermodder
+rep
Thank you for the kind word p0Pe
About the Valve I already decided that I was going to use the same you already posted... it's a beauty!
I think that good pictures is what makes people follow your build aswell and because of the sponsors I have to do my best so I can show the awesome stuff they have!
Anodize would be the best option but not an option for me I'm afraid, can't do it myself and can't find anyone to do it for me so I just painted them I will post results soon but I think they look good
The case is great yes, loooooooooot of space and ideal for massive builds
As for the parts I mentioned in the #1 post I think that about 75% are going to be changed.... I decided to put everything on hold and wait for the first reviews / benchs of the LGA 2011 and the X79 boards, If i don't like what I see I will go for my Sandy Bridge build all the way
__________________
Old 31st Oct 2011, 07:03   #35
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run Crysis
This case is damn gorgeous
GuilleAcoustic is offline   Reply With Quote
Old 31st Oct 2011, 12:58   #36
xSoMBrAx
Supermodder
Finally I decided to paint the thumbscrews since I couldn't find them in M3 thread
These are the M3 thumbscrews I used
I sanded them the best I could and cleaned them to remove any dust.
I applied 3 layers of paint to preserve the color in the best possible way!
Some spray action!
Now the color...
My mom really liked the "stems" I made, she wanted to keep them for the living room
Before and after (like the diet pills!)
Finally the thumbscrews on It's place.
I'm very happy with the results
__________________
Old 31st Oct 2011, 13:14   #37
bulldogjeff
edit. double post
Old 31st Oct 2011, 13:15   #38
bulldogjeff
Thats nice.The colours work well together..The ones on stems look like you're trying to grow them
Old 22nd Nov 2011, 15:09   #39
xSoMBrAx
Supermodder
Thanks for the kind words bulldogjeff
Almost no update for a month, but don't want to let the thread "die" so just wanted to post an update with something I really wanted to add to the Little Devil after I realized how much weight will this thing have!
Lian Li black metal casters... they are very nice as you can imagen coming from Lian Li
Some pictures!
Still a lot of work to do and a lot of things to order... still not decided about the hardware, I'm having a tough time... maybe jump to LGA 2011
__________________
Old 25th Nov 2011, 16:58   #40
xSoMBrAx
Supermodder
Just recieved my order from MDPC-X, and the first thing I did was to replace the internal thumbscrews that I already used to replace the old M3 that were built in when I got the case.
If you remember it used to look like this:
And this is the final result with the new screw and caps...
__________________
Reply
Tags
little devil, white build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
