View Poll Results: What to do: Black or white tubing!?
Black! 32 43.24%
White! 39 52.70%
No idea, I hate water cooling! 3 4.05%
Voters: 74. You may not vote on this poll
Reply
Thread Tools View Mode
Old 18th Jan 2012, 13:44   #61
damien c
Mad FPS Gamer
damien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for president
Originally Posted by Maximilian View Post
This is my favourite build log on bit tech atm, Im checking 5 times a day for updates, but its taking tooo long for more progress!!
Let us know what your plans are for hardware!
3x nVidia 680 ?
SR-3 ?
Rampage 4 extreme?
3x 480 Rads?
The possibilities are endless with this awesome case!
Yeah the case is amazing and I keep changing my mind about my case for my next build, currently have 4 in mind.
The little devil case which is the one used in this mod
The Coolermaster Cosmos 2
The Silverstone TJ11
And last I think it's called the XZPC HS1 Cube, as that will take the 5x 360mm rad's I am potentially going to use for my next build, dependant on what the temp's are like on the hardware I buy.
__________________
Core I7 3930K, Rampage IV Extreme, 16GB Corsair Vengance 1600mhz, GTX 680 SLI, Corsair Force 3 250Gb SSD, Creative Sound Blaster X-Fi Titanium, NZXT Switch 810, XSPC RX 360mm + Alphacool 240mm All Copper, 10x Scythe Kazi Jyuni 1900rpm 5v & And It's Silent!!!!!!!!! .
Market Place Feedback
http://forums.bit-tech.net/showpost....&postcount=104
damien c is offline   Reply With Quote
Old 18th Jan 2012, 14:14   #62
DJ101010
Minimodder
DJ101010's Avatar
DJ101010 has yet to learn the way of the Dremel
Awesome looking build mod! Can't wait to see the finished build! I'm literally drooling over here!
Will be checking this one regularly
DJ101010 is offline   Reply With Quote
Old 20th Jan 2012, 08:06   #63
xSoMBrAx
Supermodder
xSoMBrAx has yet to learn the way of the DremelxSoMBrAx has yet to learn the way of the Dremel
- Sponsors -
Aquatuning España / Atlas Informática / NZXT
ProSilentPC / Seasonic / IzarMicro
Gracias a todos los sponsors por colaborar en el proyecto.
Many thanks to all the sponsors for the support given to this project
3x nVidia 680 ?
SR-3 ?
Rampage 4 extreme?
3x 480 Rads?
I'm going to have 3 x 480 Rads for sure, and LGA 2011 processor for sure... everything else I'm still deciding, can't reveal everything right
I love the Little Devil just bare in mind that there are like 100 screws all around and open/close the case is the worst part, everything else is great
Thanks my friend, will try to make it worth the visits
I've been busy these days with a lot of planing show I'm just going to show you my cardboard 480 rads
I've been planing the tube routing with all the elements inside but since I didn't have the rads I needed to see the whole picture and I just realized that It will be hard to find a proper place to install the valve (and make it look nice). May end up using a piece of tubing with a stop fitting at the end
2 x Coolgate 480 Rads will be placed down there, as you can see they fit great but not much space to link them together + fans + valve etc...
A third radiator will be placed at top.
I like the Coolgate because of the 4 threads and how they are mounted, gives me a lot of mounting options... a picture to show you what I'm talking about.
What do you guys think?
__________________
Latest Project: « «[ Little Angel ]» » (FINISHED!)
Sponsors: *** Aquatuning | Atlas Informática | NZXT ***
*** ProSilentPC | Seasonic | IzarMicro | E22 ***
Follow me on Facebook!
xSoMBrAx is offline   Reply With Quote
Old 20th Jan 2012, 10:57   #64
DoOb's
Overclocker/Modder
DoOb's's Avatar
DoOb's has yet to learn the way of the Dremel
Surely that many radiators esp size wise isnt going to make any much big of a difference once you've reached your ambient water temp.
Like the difference will be around 5 degrees or so... ?
Lovely case though...F!!!!!
__________________
Intel Core i7 Sandy Bridge - 3.4ghz//MSI P67A GD80(B3)//8gigs Kingston Hyper X DDR3 1600//Antec TruePower Trio 650WATT//Seagate 320gig SATA2//Seagate 500gig SATA2//Kingston 128gig SSDNOW V100 SATA2//Samsung 1TB x 2 SATA2//CM Stacker 810// Watercooling
Project : Infinity CM Stacker
DoOb's is offline   Reply With Quote
Old 20th Jan 2012, 13:00   #65
damien c
Mad FPS Gamer
I know when I do my build I will be using around 5 360mm rad's.
1 for the cpu
1 for each graphic's card
Possibly 1 for the motherboard dependant on if the board's need cooling that are around when I do mine.
That may be what the OP is planning on 1 for graphic's, 1 for cpu and 1 for mobo.
__________________
Old 22nd Jan 2012, 17:43   #66
xSoMBrAx
Supermodder
Yes i know what you mean but overkill is good haha.
Also I will be runing 3 cards and probably ram blocks aswell..
Im having trouble deciding which mobo to buy that has block available.
I dont want rog or gigabyte and asrock, msi and others dont have blocks available makes me feel baaaad :-(
__________________
Old 23rd Jan 2012, 03:38   #67
DoOb's
Overclocker/Modder
DoOb's's Avatar
True :P
__________________
Old 23rd Jan 2012, 06:35   #68
damien c
Mad FPS Gamer
What cpu are you going to be running in it?
There are places that sell the board's pre watercooled so you don't void the warranty by removing the heatsink's.
You could also go for any board and paint the waterblock's to match the colour scheme you are going for.
I know the one that I will be going for eventually will match the colour scheme anyway as it's going to be based around a Asus ROG board, which will be Red & Black.
__________________
Old 24th Jan 2012, 19:58   #69
xSoMBrAx
Supermodder
Will go for 3930K for sure...
Everything else not sure yet
Some minor update
Wires anyone?
Artic Silver 5... the best
20mm drill bit so I can destroy the Little Devil easier
More stuff coming soon... hopefully!
__________________
Old 25th Jan 2012, 09:18   #70
damien c
Mad FPS Gamer
I've found that the Arctic MX-3 stuff gave me better temp's than the Arctic Silver 5 since I switched.
Even tried it on my last pc, and found something rather strange which I cannot for the life of me explain but when I put the Artic Silver 5 on my 2600K the pc would not boot but I switched back to the MX-3 stuff and the pc booted.
Still looking very good this build though and cannot wait for it to be finished.
__________________
Old 26th Jan 2012, 11:20   #71
matt...
Slacker
matt...'s Avatar
matt... has yet to learn the way of the Dremelmatt... has yet to learn the way of the Dremelmatt... has yet to learn the way of the Dremelmatt... has yet to learn the way of the Dremelmatt... has yet to learn the way of the Dremelmatt... has yet to learn the way of the Dremel
Found where to get one from but it aint cheap and it's not the LE edition, but Specialtech.co.uk has them for £72 might order one on payday.
Hey Damien, was tempted by these myself - Aquatuning.co.uk have the HD at £68 and the LE for £90... very pretty but very pricey
__________________
"I have not failed. I've just found 10,000 ways that won't work," Thomas Edison
matt... is offline   Reply With Quote
Old 1st Feb 2012, 10:32   #72
xSoMBrAx
Supermodder
Really strange to see a computer not booting because of the AS5!
Will take care thanks for saying
I need your help now... I'm trying to find a pattern to sleeve my 24 pin cables and this is what I ended up with (I did other combinations but not liking them much)
Any other suggestions? I've added white but doesn't look good, I think big change of colours hehe
I personally like the first one because of non-symetrical style and it looks more black than gold but not sure :S
__________________
Old 1st Feb 2012, 12:17   #73
damien c
Mad FPS Gamer
Yeah me and my dad both couldn't figure out why it wouldn't boot when I used the AS5 but my dad's pc did boot fine and has been working fine since.
As for the pattern to be honest, it will be which ever you think look's best as it's your pc and you will be looking at it.
For me I would use the 2nd one as I don't like thing's like that not looking symetrical, simply because I would prefer it to look the same all the way through.
As I say it's your pc so it's your choice really.
But keep it up I cannot wait to see this all finished (No Rush)
__________________
Old 1st Feb 2012, 15:20   #74
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run Crysis
I'm thinking along the lines of the first, but put the 3 gold next to each other with out the space?
So looking top down:
BGGGBBBBBBGB
BGBBBBBBGGGB
Just a thought I don't really like the every other of the last one myself either.
__________________
Mosquito
Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC
Case Mod: Definition: Server | IBM PC AT Reborn
Mosquito is offline   Reply With Quote
Old 1st Feb 2012, 17:03   #75
xSoMBrAx
Supermodder
Thanks damien, I'm really happy to know that people is waiting for my updates and following the work. Thank you for the support!
BGGGBBBBBBGB
BGBBBBBBGGGB
Hello Mosquito, I've tried your combo and then I used the concept to make some other concepts... here we go
This one is following 2 different patterns depending on the front or the back of the connector... I'm very happy with the result, and you?
This one maybe? (Mosquito's suggestion!)
And finally and much cleaner version of old concept
__________________
Old 1st Feb 2012, 17:19   #76
Mosquito
Hypermodder
Mosquito's Avatar
Shoot, now I can't decide which one I like more
__________________
Mosquito
Old 1st Feb 2012, 23:36   #77
xSoMBrAx
Supermodder
That's good and bad lol
I think I will wait for the hardware to be here and then decide which one looks better since it's getting very hard to get a vote on one of them...
__________________
Old 2nd Feb 2012, 22:50   #78
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
The third choise is the best one !
KoSoVaR^ is offline   Reply With Quote
Old 3rd Feb 2012, 06:40   #79
damien c
Mad FPS Gamer
I like the 1st and 2nd more the 2nd though.
Again though as it's your pc I would say go with whichever you prefer.
__________________
Old 4th Feb 2012, 07:29   #80
xSoMBrAx
Supermodder
Thanks everybody for the nice feedback! Will post pictures when sleeving is done and I hope you like it!
__________________
Reply
Tags
little devil, white build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
