View Poll Results: What to do: Black or white tubing!?
Black! 32 43.24%
White! 39 52.70%
No idea, I hate water cooling! 3 4.05%
Voters: 74. You may not vote on this poll
Reply
Thread Tools View Mode
Old 25th Feb 2012, 15:54   #101
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.KidMod-Southpaw is definitely a rep cheat.
Good stuff! Now get them in the system!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 25th Feb 2012, 15:56   #102
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
I want more !!!
KoSoVaR^ is offline   Reply With Quote
Old 25th Feb 2012, 17:37   #103
peteski
long live the pc
peteski's Avatar
peteski has yet to learn the way of the Dremel
nice box of bits mate cant wait to see them in side the case
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl,
peteski is offline   Reply With Quote
Old 27th Feb 2012, 23:29   #104
xSoMBrAx
Supermodder
xSoMBrAx has yet to learn the way of the DremelxSoMBrAx has yet to learn the way of the Dremel
- Sponsors -
Aquatuning España / Atlas Informática / NZXT
ProSilentPC / Seasonic / IzarMicro
Gracias a todos los sponsors por colaborar en el proyecto.
Many thanks to all the sponsors for the support given to this project
Originally Posted by KoSoVaR^ View Post
I want more !!!
Thank you guys!
Update for you!
First test with radiators in the bottom section of the Little Devil
There is a lot of space down there... Enough for paralel 19/13 tubing
Taking measurements and starting the work
Just want to keep about 8cm of fan cable!
White tape to get a much pleasent sleeving result
Sleeved and with half heatshrink!
Because of the sleeving we need to cut plastic so the cable will sit on its place
Done!
Just need to cover the fan PCB... soon!
Stage 1 complete!
Stage 2 begins!.
The reason to do the sleeving this way is to keep the fans easy to remove and change in the future. If I just solder all the fans together in series it would be a pain where_you_know to remove or change fans or any other stuff fan related, that's why I created that custom splitter!
Couple of hours after, sleeved splitter!
Finally a connector detail, might remove the extra heathrink with a sharp blade so you will not see that extra shrink
__________________
Latest Project: « «[ Little Angel ]» » (FINISHED!)
Sponsors: *** Aquatuning | Atlas Informática | NZXT ***
*** ProSilentPC | Seasonic | IzarMicro | E22 ***
Follow me on Facebook!
xSoMBrAx is offline   Reply With Quote
Old 28th Feb 2012, 00:13   #105
KoSoVaR^
KoSoVaR^'s Avatar
Very handy and tidy!
I like it alot!
Old 28th Feb 2012, 05:29   #106
peteski
long live the pc
peteski's Avatar
great work mate keep it up
__________________
Old 29th Feb 2012, 14:24   #107
xSoMBrAx
Supermodder
I like it alot!
Thank you both
Working on the 2nd radiator right now, will post pictures when finished and then will start to sleeve the last radiator
__________________
Old 1st Mar 2012, 09:20   #108
xSoMBrAx
Supermodder
Hello everyone!
I would like to introduce you IZAR MICRO , they are my new sponsor!
They helped me a lot since day 1, many thanks to Jon.
Will upload some updates later!
__________________
Old 1st Mar 2012, 16:40   #109
xSoMBrAx
Supermodder
Another small update, just finished sleeving the 2nd radiator, just one more to go
I began this one in the morning...
Finished at night
(I spent 8 hours at work aswell so was quite good )
__________________
Old 1st Mar 2012, 16:41   #110
KidMod-Southpaw
Woah, great job! That looks very neat and tidy!
__________________
Old 1st Mar 2012, 17:10   #111
peteski
long live the pc
peteski's Avatar
keep up the good work mate
__________________
Old 2nd Mar 2012, 16:03   #112
xSoMBrAx
Supermodder
Thanks!
Tonight I will finish the last radiator (hopefully!) and will post pictures
After that will plan the front fan sleeving and other stuff that needs to be sleeved
__________________
Old 2nd Mar 2012, 21:28   #113
Martininho
Minimodder
Martininho has yet to learn the way of the Dremel
Nice work, Could you post some closeups of the ends of the wires? Wondering what you are doing with those. Fairly new to that stuff, hence the question.
Mod overall looking really good!
Martininho is offline   Reply With Quote
Old 3rd Mar 2012, 12:31   #114
xSoMBrAx
Supermodder
Sure have a look:
As you can see I've soldered the positive and negative of each fan in series, that is why I had to make my own splitter of desired length, everything looks much better now
__________________
Old 3rd Mar 2012, 14:45   #115
Martininho
Minimodder
Nice, looks good indeed. Cant wait to see what you turn out with!
Old 3rd Mar 2012, 16:45   #116
xSoMBrAx
Supermodder
Thank you Martininho
Today I recieved something that I did not expect to get so fast...
TEASER!
And finally a making-off shot from the "sleeving nights"
Will have to wait before I can show some progress, need to wait for some stuff but before that I will keep planing and routing things
Have a nice weekend..
__________________
Old 13th Mar 2012, 15:53   #117
xSoMBrAx
Supermodder
Hello guys!
Long time since my last update... I was waiting for some tools and still waiting for my Aquaero 5 so I can finish all the connections (need to measure all the wire lengths depending on the AQ5 final placement)
While waiting I decided to do some wiring of the Power Adjust 2, still need to connect the Aquabus in series, I'm waiting for some black pins
Black screws and black PA2 faceplate...
Black MOLEX connector and pins!
Will get rid of the ULTRA stickers soon, don't worry.
Custom length cables are great but a pain to measure and make them look good hehe. 12V power in series for all PA2
Detail of the final molex connector that will "feed" them
Not going to sleeve any of the PA2 connections since I think they look great with white cable.
Soon more to come!
__________________
Old 13th Mar 2012, 16:02   #118
KidMod-Southpaw
Looking good!
__________________
Old 13th Mar 2012, 16:37   #119
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
This is really fantastic xSoMBrAx I totally agree that the white cables look great just the way they are
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 14th Mar 2012, 10:36   #120
xSoMBrAx
Supermodder
Looking good!
Thanks KidMod
Much appreciated Editor22... I've seen your work and it's amazing, the renders and the custom acrylic work... I'm sending you a PM right now!
I thought that I had no 3 pin connectors but I managed to find some so I could link the Aquabus lines from the PA2
Pins and connectors
My tools for my custom length wires... really need to get some good wire stripper to have all with exactly the same length, that could improve the results even more. Knipex maybe?
BEFORE
AFTER!
Aquaero 5 XT is on it's way as I said yesterday, still need to make 1 more custom connector that will link all the PA2 with AQ5 and make them work as one pice of hardware
__________________
Reply
Tags
little devil, white build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
