View Poll Results: What to do: Black or white tubing!?
Black! 32 43.24%
White! 39 52.70%
No idea, I hate water cooling! 3 4.05%
Voters: 74. You may not vote on this poll
Reply
Thread Tools View Mode
Old 14th Mar 2012, 20:04   #121
peteski
long live the pc
peteski's Avatar
peteski has yet to learn the way of the Dremel
sweet wireing mate +rep to you
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl,
peteski is offline   Reply With Quote
Old 15th Mar 2012, 09:09   #122
xSoMBrAx
Supermodder
xSoMBrAx has yet to learn the way of the DremelxSoMBrAx has yet to learn the way of the Dremel
Thank you peteski!
I'm now planing a custom part that I think it will make it look even better...
More updates soon!
Just want my Aquaero 5 to get home so I can continue working! !
__________________
Latest Project: « «[ Little Angel ]» » (FINISHED!)
Sponsors: *** Aquatuning | Atlas Informática | NZXT ***
*** ProSilentPC | Seasonic | IzarMicro | E22 ***
Follow me on Facebook!
xSoMBrAx is offline   Reply With Quote
Old 15th Mar 2012, 14:51   #123
xSoMBrAx
Supermodder
I just recieved some goodies from one of my sponsors.
Thank you very much ProSilentPC (specially to David)
Some custom stickers, very high quality vinyl, very strong!
40mm Fractal fans... they do look very nice...
30mm M3 screws to replace the bronze screws from the Alphacool radiators
Nothing beats German engineering....
These are custom made by David, you will see what are they used for in the future.
No painting, chemical treatment so it wont peel
Dimastech thermal compound... will test it and see what results do I get
Finally some masterkleer tube to do some tests before final assembly with coloured tubing.
Until the next update!
__________________
Old 15th Mar 2012, 15:54   #124
damien c
Mad FPS Gamer
damien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for president
Really looking good mate.
Awaiting next update.
__________________
Core I7 3930K, Rampage IV Extreme, 16GB Corsair Vengance 1600mhz, GTX 680 SLI, Corsair Force 3 250Gb SSD, Creative Sound Blaster X-Fi Titanium, NZXT Switch 810, XSPC RX 360mm + Alphacool 240mm All Copper, 10x Scythe Kazi Jyuni 1900rpm 5v & And It's Silent!!!!!!!!! .
Market Place Feedback
http://forums.bit-tech.net/showpost....&postcount=104
damien c is offline   Reply With Quote
Old 16th Mar 2012, 09:20   #125
xSoMBrAx
Supermodder
Thank you Damien
Yesterday I could do some work to better handle the cable management:
As you can see there are some cables that need to come through the midplate to reach the Aquaero 5 (fans, sensors, etc).
I didn't want to use the already drilled holes in the Little Devil since the wiring would look strange, I really wanted to have "straight lines" so I decided to mark an area to drill a hole and let the cables pass the midplate.
PSU 24pin connectors and other will be routed just behind the motherboard tray so I'm ok with that
I will try to follow the same pattern as the other drilled holes in the Little Devil so they don't look strange.
I did some measurements and you have 22mm and 20mm holes, so I will go for 20mm size
I just need to finish it with my step drill but I ran out of time, need to earn some money so I can finish this
Will update tonight after the surgery!
__________________
Old 17th Mar 2012, 12:45   #126
ThE_FuR[i]OuS
What's a Dremel?
ThE_FuR[i]OuS has yet to learn the way of the Dremel
fantastic work very well )
I follow with great interest
ThE_FuR[i]OuS is offline   Reply With Quote
Old 17th Mar 2012, 17:13   #127
xSoMBrAx
Supermodder
Thank you Furious!
I'm a little upset because I couldn't find countersunk rivets in my area so I will need to order those somewhere because I had to drill some rivets to get the midplate out and drill the hole for the wire management properly
Will post pics later so you can see
__________________
Old 18th Mar 2012, 08:59   #128
xSoMBrAx
Supermodder
Hello everyone!
Update time... finally I had to remove rivets to get the midplate out so I could drill the hole I needed for the cable management purpose
As you can see I need to find some countersunk rivets since the one I have don't look that great compared to the original rivets used!
Without the midplate and the rivets the case lost all its rigidity
Don't think it twice and just do it!
The "raw" finish...
Final result
I used 20mm step drill bit so I could add bitspower pass through if needed or just will fit some gomets, will see!
__________________
Old 18th Mar 2012, 09:16   #129
peteski
long live the pc
peteski's Avatar
bitspower looks so sweet
__________________
Old 18th Mar 2012, 18:16   #130
Renovatio_Design
Loading...
Renovatio_Design's Avatar
Renovatio_Design has yet to learn the way of the Dremel
Congrats mate!a lot a lot of hard work here!
Renovatio_Design is offline   Reply With Quote
Old 18th Mar 2012, 20:21   #131
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
Looks so good with them on dude
KoSoVaR^ is offline   Reply With Quote
Old 18th Mar 2012, 22:16   #132
xSoMBrAx
Supermodder
Thank you guys, I'm a bit upset because I need to find some countersunk rivets and I think will have to order them online
I really need them so I can have everything ready to install Aquaero 5 and pump + reservoir placement etc...
Will update as soon as I have the rivet thing solved
__________________
Old 20th Mar 2012, 22:01   #133
xSoMBrAx
Supermodder
I have good and bad news!
Good news first... The Aquaero 5 XT is at home!
Bad news... I don't have my countersunk rivets yet so can't continue working without assembling the case
Next step would be to finish the sleeving of the fans and for that I need to place the Aquaero and take final measurements to know exactly what length wire I need until I reach the desired output of the Aquearo...
I did some work with the AQ5, changed the front plate and replaced the original heatsink with a waterblock instead!
And the after:
__________________
Old 20th Mar 2012, 22:20   #134
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Suuuuubbed.
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 20th Mar 2012, 22:44   #135
Stu @ MSD
Multimodder
Stu @ MSD's Avatar
Stu @ MSD is a hoopy frood who really knows where their towel is.Stu @ MSD is a hoopy frood who really knows where their towel is.Stu @ MSD is a hoopy frood who really knows where their towel is.Stu @ MSD is a hoopy frood who really knows where their towel is.Stu @ MSD is a hoopy frood who really knows where their towel is.Stu @ MSD is a hoopy frood who really knows where their towel is.Stu @ MSD is a hoopy frood who really knows where their towel is.Stu @ MSD is a hoopy frood who really knows where their towel is.Stu @ MSD is a hoopy frood who really knows where their towel is.Stu @ MSD is a hoopy frood who really knows where their towel is.Stu @ MSD is a hoopy frood who really knows where their towel is.
Amazing build and attention to detail, really enjoying this topic mate.
__________________
Asus Maximus IV Extreme Z // i7 3770K @ 4.4ghz cooled with Custom loop // 8GB 2133 Corsair Dominator GT // 2x 240GB OCZ Vertex 3 SSD & 1x 512GB Vertex 4 // AMD 7970 HD x3 in TriFire. // XFX Pro 1250w PSU // Windows 7 64 bit.
Stu @ MSD is offline   Reply With Quote
Old 21st Mar 2012, 03:13   #136
LukeDaly
N00b
LukeDaly's Avatar
LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.LukeDaly is a hoopy frood who really knows where their towel is.
Nomnomnom, very good work sir!
__________________
:: Haf-X :: i7 2700k At 4.8Ghz With Custom Water Cooling Loop :: Asus Maximus IV Extreme-z ::
:: 16GB Corsair Vengeance :: 2x Evga Gtx 580 3GB in SLI :: 3x Crucial M4 ::
:: Creative Sound Blaster X-Fi Titanium Hd :: Xfx Pro 1000w Limited Black Edition ::
:: Filco Majestouch 2 Ninja :: Mionix Naos 5000 :: 2x Dell U2711 ::
LukeDaly is online now   Reply With Quote
Old 21st Mar 2012, 15:01   #137
xSoMBrAx
Supermodder
Originally Posted by Nutman View Post
Suuuuubbed.
Thank you Nutman, I just checked your new worklog and the sketch looks promising
Subbed of course
Thank you!
I think I'm going to put some standard rivets while I wait for the countersunk to arrive, so that way I can continue working and at least will be able to finish my sleeving of radiators / fans / aquaero and power adjust modules...
I can also start to think about sensors placement and other stuff
__________________
Old 21st Mar 2012, 21:39   #138
Nutman
Nutman's Avatar
Subbed of course
Hehe, yeah. Saw that. Thanks.
Did you get a chance to play with the Aquaero yet?
__________________
Old 21st Mar 2012, 22:15   #139
xSoMBrAx
Supermodder
No chance to play with the Aquaero yet... I did order the countersunk rivets but while I wait I installed some bolt screws so that way I can keep doing some work.
What I did today was to measure some of the fan cables so they can reach the Aquaero connectors and also the wire routing etc...
Tomorrow will try to finish with the radiator fan sleeving at least!
__________________
Old 21st Mar 2012, 22:34   #140
Nutman
Nutman's Avatar
Did you try an older version of the Aquaero? I used an Aquaero 3.07 for "Project: Nutman" and now I got a Aquaero 4 for my next mod - but I'm wondering if upgrading to Aquaero 5 LT would make any sense? (LT since I don't need neither display nor any buttons)
__________________
Reply
Tags
little devil, white build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
