Reply
Thread Tools View Mode
Old 9th Oct 2011, 01:02   #1
RedManc
Supermodder
RedManc's Avatar
RedManc has yet to learn the way of the DremelRedManc has yet to learn the way of the Dremel
outcaster - Updated 30/11/11
Now then!!
I caught the custom pc bug a few months back when I was considering whether or not I needed a new computer, so after deciding I should probably save my money I started putting a list of parts together Which ill go through below.
Things which are not excuses but good to know for those people who are looking at all these mods and thinking WOW! i wish i could do that.
  • I have NEVER built a PC
  • I DO NOT own a dremel
  • Zero experience with modding
  • Hardly anytime with work and college
  • This WILL be the greatest thing I have ever created
So the parts list would be a nice place to start I guess ... wheres that invoice
SYSTEM
  • [Case] Coolermaster ATCS 840
    [CPU] Intel i7 2600k Unlocked
    [Motherboard] Asus Maximus IV Extreme-Z
    [Memory] 2x4gb Corsair Dominator
    [Hard Drive] Corsair 120gb Force GT (SSD)
    [Graphics Card] Gainward 1280mb GTX570 Phantom
    [Power Supply] BeQuiet Dark Power 850W
    [Optical Drive] LG Blu-ray Drive
    [OS] Windows x64 7 Pro
COOLING
  • [CPU] EK Supreme HF Nickel
    [Motherboard] Air cooled due to lack of stock
    [Memory] EK Dominator Nickel
    [Hard Drive] Air cooled due to lack of money now (see list above)
    [Graphics Card] EK FC5X0 GTX Plexi + Nickel & EK 5x0 GTX Backplate
    [Radiator] EK Coolstream RAD XT 360 (probably going to add an additional 2x240 ina second loop)
    [Pump] Laing DDC w/ EK X TOP-V2 & Red ORing when I come around to shopping again
    [Reservoir] Phoyba 150 Balancer Nickel/Silver
Queue some TERRIBLE photos, but be patient I have listened and my tripod is on the way to the office!
Unboxing...
MY FIRST EVER MOD!!!
Getting a little braver..
MUST NOT LOOSE ANY SCREWS!
__________________
RedManc is offline   Reply With Quote
Old 9th Oct 2011, 14:03   #2
xSoMBrAx
Supermodder
xSoMBrAx has yet to learn the way of the DremelxSoMBrAx has yet to learn the way of the Dremel
That's a good start.
Best you could do is take everything out of the case so It will be much easier to work!.
Is it easy to disamble the ATCS?
Nice water cooling parts!
Which HDD block would you use if you had the money? I'm curious!
__________________
Latest Project: « «[ Little Angel ]» » (FINISHED!)
Sponsors: *** Aquatuning | Atlas Informática | NZXT ***
*** ProSilentPC | Seasonic | IzarMicro | E22 ***
Follow me on Facebook!
xSoMBrAx is offline   Reply With Quote
Old 10th Oct 2011, 01:02   #3
Device Unknown
Multimodder
Device Unknown's Avatar
Device Unknown has yet to learn the way of the DremelDevice Unknown has yet to learn the way of the Dremel
These are the mods I love to watch. Exciting to watch a new modder do his first MOD. Just be weary, everyone and their brother will be trying to tell you how you "should" do things. You obviously did your homework. Stick with it.
Device Unknown is offline   Reply With Quote
Old 10th Oct 2011, 09:19   #4
RedManc
Supermodder
RedManc's Avatar
Thanks xSoMBrAx, yeah the case was simple to dismantle, only problem ive hit it the motherboard tray. The bottom runner which has ballbearings in, I don't havea screw driver which will fit so i'm on the look out for an offset screwdriver today. As for the HDD, I haven't even look if im honest its just I know I have already spent what money I have left for this puter
Thanks Device Unkown, ill take all the advise and critisims anyone has to throw at me but like you say there are a million and one ways to do different things just finding the ones which work best for me I guess.
Anyway I picked up some primer uesterday and im going to give the inside of the case a bit of a face lift if I can today, other than that I've jumped the gun and assembled the gpu and other bits and bobs
Pictures to follow....
__________________
Old 10th Oct 2011, 15:14   #5
towelie
How do I Internet!!
towelie's Avatar
towelie has yet to learn the way of the Dremeltowelie has yet to learn the way of the Dremel
I will be watching this build never really modded anything myself don't own all these awesome tools and my cable managment sucks a**hole.When my current rig gets older and i think of replacing it, i will try this and that(mod wize) but at the moment its my only rig so do not want to try anything risky.
Even went for the lazy corsair H80 for a Water cooling.
Good luck dude Inspire me to grow some LOL
__________________
CPU:Intel I7 930(Bloomfield) @2.80GHZ CPU Cooler:Under water
MOBO:Asus P6t SE Graphics Card: Palit 980GTX 4GB EVGA OC
RAM:12GB Corsair XMS3 1600mhz 9-9-9-24 PSU:Corsair HX 750W
Hard Drives128GB SSD Corsair Force GS/1TB WD Green 7200RPM
Case:NZXT 810 Switch Black
towelie is offline   Reply With Quote
Old 10th Oct 2011, 21:38   #6
RedManc
Supermodder
RedManc's Avatar
So I ripped apart a great looking graphics cards and made it look even better
And ive played with the motherboard a little bit
I'm not sure im convinced with apperance of the 2 Corsair modules under such a big block, so I have three options.
  1. Buy 2 more RAM Modules
  2. Buy the EK RAM-Dominator x4 (Saw this days after getting my block )
  3. All of the above
__________________
Old 10th Oct 2011, 21:53   #7
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyan
Buy more ram, it's so cheap these days it would be rude not to...looking good by the way.
bulldogjeff is offline   Reply With Quote
Old 11th Oct 2011, 15:05   #8
RedManc
Supermodder
RedManc's Avatar
Thanks for watching Towelie, I don't own a load of awesome tools so there nothing to stop you. I have a set of screw drivers, an idea as well as unlimited amounts of blind faith!
I'd take some time looking and learning from other logs taking ideas into your own build one day. Ive seen some things which I will use from other peoples builds because they are great ideas, imitation is the greatest form of flattery after all.
I wouldn't say the H80 is lazy its just ugly
Think that might be the best idea, just waiting for some to come into stock
Anyway on with an little update. I got a tripod yesterday and ive finally used my camera for more than christmas and holidays
I'm waiting for the rain to stop to carry on with some painting mods but for now please let me know what you think of these hardware shots.
__________________
Last edited by RedManc; 11th Oct 2011 at 15:07. Reason: removed duplicate pictures ;)
Old 11th Oct 2011, 15:20   #9
bulldogjeff
If you look down through the pics I think that 5,6,7 and 10 are good shots across the board giving some depth, but the side on shot of the blocks and the ram is good also.
That said they are all nice and clear which is the main thing.
I'm probably not the best one to offer advice on photography, I've got a decent camera and a tripod and I'm still crap with it....lol
Old 11th Oct 2011, 22:07   #10
Yeoo
Supermodder
Yeoo's Avatar
Yeoo has yet to learn the way of the DremelYeoo has yet to learn the way of the DremelYeoo has yet to learn the way of the DremelYeoo has yet to learn the way of the DremelYeoo has yet to learn the way of the DremelYeoo has yet to learn the way of the DremelYeoo has yet to learn the way of the Dremel
Looking very nice!
__________________
CPU: AMD Athlon II x2 250 3.0GHz / MOBO: ASUS M4N68LE-M V2 / RAM: 4GB DDR3 1333MHz / HDD: Samsung F3 1TB / GPU: Sapphire Radeon HD 6750 / CASE: Fractal Arc Mini
My First custom build......Next Build: i5 2500k
Yeoo is offline   Reply With Quote
Old 13th Oct 2011, 16:56   #11
RedManc
Supermodder
RedManc's Avatar
Thanks for the comments guys.
I have started a shopping basket for some new RAM its in there but so far the total is £200+ thanks to other bits and pieces I like the look of
Update: Let there be PAINT!!
Well primer if we are being picky.
Took me a couple of hours to make some room in my shed so that I have somewhere to paint the inside of my case in peace. Unfortuneately I have forgotten the before picture but nevermind I could always take one when its a mess again.
I have now applyed 2 coats of primer to all the pieces which I want white or red which have come off the frame of the case.
Motherboard tray and the alternate psu cover plate.
Top fan mesh panel, fan mount, bay converter and psu plate
quick release buttons for the hdd cage, these might become red or white not sure
The next order of business is to give the motherboard tray a little sand and apply a few coats of white paint to these pieces. When they are all done and safely bubble wrapped, I am going to mask the top panel of the case itself and get that painted, should be done by sunday with any luck
__________________
Old 14th Oct 2011, 15:05   #12
mav2000
In Training
mav2000 has yet to learn the way of the Dremel
Nice....how many rads do you plan to put in there?
mav2000 is offline   Reply With Quote
Old 14th Oct 2011, 19:09   #13
RedManc
Supermodder
RedManc's Avatar
Two radiators, I havea 360 sat on my desk which I am going to put in the stock location, and Im buying a 240 rad probably next weekend now which will go where the quick-swap bays should be with a fan grill on the side panel for its ventilation.
I would like a second loop but only if I can get a motherboard block and that would require a rethink
__________________
Old 16th Oct 2011, 20:22   #14
RedManc
Supermodder
RedManc's Avatar
A shameless sunday bump
So today I spent some time doing a final primer and first coat of paint on some items.
Also put my hand to wet sanding the already primered motherboard tray and It will be ready for painting over the next few days.
Hopefully the weather doesn't turn too bad
__________________
Old 17th Oct 2011, 05:20   #15
mav2000
In Training
That motherboard tray is strong as **** man.....I was planning to drill some holes in there, but decided I would be better of leaving it stock.
Old 17th Oct 2011, 17:43   #16
peteski
long live the pc
peteski's Avatar
peteski has yet to learn the way of the Dremel
grate start to your first mod RedManc one day i shall be that first time modder cant wait i got plenty of ideas its just not the right time to start yet
subscribed
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl,
peteski is offline   Reply With Quote
Old 20th Oct 2011, 15:08   #17
RedManc
Supermodder
RedManc's Avatar
Got a nice package from friend of modders worldwide Nils the other day and I've been playing around for a few days with it ...
Sleeved the power/reset switches and the hhd/pwr leds ... the heat shrink will need to be redone.
A quick bit of cable management
An attempt at that super sleeving shot I see so many of.
So far I have painted the inside aluminum frame with a few the final bit of white paint.
The finish is ok for my first spray painting operation. Although next time I need a bigger shed.
Painted the top mesh panel also I love the look of this now!
And finally a half way shot I really do like the look of this puter now I just hope I can get it working
I have a few issues to figure out with regards to the loop.
If anyone is reading this ... HELLO? ... Would a 360 Radiator be enough for this loop or should I add another rad to the mix (120/240) ?? Thanks for any help. The system will not be overclocked it will run run at stock levels.
Also im having great difficulty plugging the usb and audio headers onto the motherboard they just wont budge!!
Oh and the systems name will not be outcaster as voted for or suggested by my gaming outfit.
Keep on Modding!
__________________
Old 20th Oct 2011, 17:01   #18
jeckulz
Supermodder
jeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on you
Wait, for a second there it sounded like you said you wont be over clocking?
Youre pouring all this money into this build and youre running stock frequencies?
Thats a crime man.
jeckulz is offline   Reply With Quote
Old 20th Oct 2011, 17:15   #19
RedManc
Supermodder
RedManc's Avatar
Well I first need to be able to get the thing working and then ill decided if I should learn how to overclock as well
plus I don't know if i need to overclock for minesweeper hehehe
__________________
Old 20th Oct 2011, 18:25   #20
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for president
Thats a crime man.
http://www.kitcars.com/Classifieds/A...ified_id=23072
like that looks like a Ferrari, runs like a Fiero
Looking good though
Mosquito is offline   Reply With Quote
Reply
Tags
asus maximus iv extreme-z, atcs 840, ek waterblocks, first build, water cooled
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
