Reply
Thread Tools View Mode
Old 20th Oct 2011, 19:08   #21
jeckulz
Supermodder
jeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on youjeckulz - may the hammer of Bindi be bestowed on you
Originally Posted by RedManc View Post
Well I first need to be able to get the thing working and then ill decided if I should learn how to overclock as well
plus I don't know if i need to overclock for minesweeper hehehe
Youre building on a 2600k right?
With an Asus board?
Dude the EFI in these new boards makes OCing SOOOOOO easy.
THe fact that your chip in UNLOCKED gives you the hint that OCing is intended. If youre not OCing then why buy a K chip in the first place?
Are you trolling?
jeckulz is offline   Reply With Quote
Old 20th Oct 2011, 19:15   #22
RedManc
Supermodder
RedManc's Avatar
RedManc has yet to learn the way of the DremelRedManc has yet to learn the way of the Dremel
genuinly never overclock and had no intention of doing so but .... I guess ... ok ill do a little.
more to the point am I going to need another radiator!>?!?!
I'm still not convinced ill be able to turn it on
__________________
RedManc is offline   Reply With Quote
Old 25th Oct 2011, 23:47   #23
RedManc
Supermodder
RedManc's Avatar
So heres five little photos for you ... warning they are garbage due to the fact it late and my lighting is terrible but I hope you enough anyway
I've been working on the Power Supply sleeving for a few day. Erm warranty voided
Remember to mark your wires BEFORE you start removing them no matter how excited you are about it!
The tools i've uesd to sleeve
TADA!!
I'm 97% happy with how this has turned out I love the sleeve, just waiting to see if the power supply still works and I think I need to heatshrink again after a little more practice
__________________
Old 25th Oct 2011, 23:55   #24
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Canardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the Dremel
Pretty nice for a first time!!! Good continuation!!
Don't worry, there is a first time for everything!!
Canardwc is offline   Reply With Quote
Old 26th Oct 2011, 17:23   #25
RedManc
Supermodder
RedManc's Avatar
Thankyou!
Yeah, just been out to the shop and picked up a psu tester.
Good News - PSU Tester Works!
Bad News - PSU Doesn't Work!
Looking into the manual now ... looks like it wired back up wrong which is odd as my drawings suggest differently but then again the manual is probably right!
__________________
Old 26th Oct 2011, 21:02   #26
RedManc
Supermodder
RedManc's Avatar
So after 4 hours +, 5 new crimps, more shrink, 1 Lamptron modding tool atx pin remover.
I took these pictures!1
Oh the big blue light means its working!!!
__________________
Old 27th Oct 2011, 22:27   #27
dmcgrath
Master of Pancakes
dmcgrath's Avatar
dmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremel
Following this one now. Always fun to see a first mod come together. And you're doing yours a LOT faster than I pulled mine together.
dmcgrath is offline   Reply With Quote
Old 28th Oct 2011, 11:27   #28
Blarte
Moderate Modder
Blarte's Avatar
Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!
Originally Posted by bulldogjeff View Post
If you look down through the pics I think that 5,6,7 and 10 are good shots across the board giving some depth, but the side on shot of the blocks and the ram is good also.
That said they are all nice and clear which is the main thing.
I'm probably not the best one to offer advice on photography, I've got a decent camera and a tripod and I'm still crap with it....lol
What you lack in photographic skills you gain in BLING ADDING though
__________________
Watering down PC's since 2009....
Blarte is offline   Reply With Quote
Old 28th Oct 2011, 11:34   #29
Blarte
Moderate Modder
Blarte's Avatar
Hi Red Nice work ..
I was looking through your intro and noticed the bit about adding a second rad, I have the same cpu / mobo / 8gb of ram(air cooled not wet) and two 580's watered down and oc'd slightly, in series through a 360 rad I just added three phobia spacers between the lower set of fans and the temps are great.
You probably won't require a second rad.
Like the log ... looking forward to your update
__________________
Old 28th Oct 2011, 11:37   #30
Nutman
Never stuck with stock
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Very good for a first mod - going to follow this one.
Oh, some advice, coming from my own "mistake": sleeve 1 wire at a time - in that way you'll never have to put markings on the wires to see where they belong. Muuuuuch easier that way, trust me...
__________________
Best regards, Nutman
Projects: Nutman - Hampen - F.O.B. T.C. - BabyShark - The Scratchbench
Nutman is offline   Reply With Quote
Old 28th Oct 2011, 17:55   #31
RedManc
Supermodder
RedManc's Avatar
Thanks for taking the time to have a look and comment, although I guess you have bags of free time now Should have an update soon.
Originally Posted by Blarte View Post
Hi Red Nice work ..
Thanks for the help, I think ive decided against the second radiator if it isn't enough which by the sounds of it it might be more than enough I could always aircool the ram ... Mhmm nah not shiny enough!
Advice is always appreciated however late I think I figured out how I ballsed it up so much, seems I numbers the wires up looking at the front of the connector and reinserted then looking at the back whilst also upside down .... yeah it didnt go well
I have done some work on the case over the last few days and Ive been naughty again and not taken many photos but i'm going to try and get some up in the next hour or so
Thank you for watching and commenting!
__________________
Old 28th Oct 2011, 20:49   #32
RedManc
Supermodder
RedManc's Avatar
Got a little bit carried away as Ive said with the installation of things so thought id post some pictures before I finished it and you saw nothing
I hate that I have had to used anti-kink springs but that pipe just wouldn't stop kinking not matter what length it was cut to!!!
Ive moved the BLu-Ray to the bottom 5 1/4" bay so make room for the radiator fittings and because disc drives at the top are sooo predictable
Ive installed two of the HDD's with scythe HD stabilizer II's but think i might purchase some hiromu or whatever they are called as they look a lot better, also want one for the SSD (over kill but i'm worth it )
Whilst being VERY tired last night I was messing around with tubing and for some reason which now makes no sense what so ever to me I came up with this superb idea !!
Removed the Res from its temporary home, I'm going to install it underneath the 5 1/4" bays with the oulet dropping vertically into the pump. Also going to buy a 90deg fitting for the radiator outlet to attach to the res.
As you all know I'm new to this world and I am a little concerned about fittings, when the hose is installed should the compression fittings close flush to the screw fitting or should there be a little gap...
Thanks for looking and commenting again
__________________
Old 29th Oct 2011, 05:12   #33
Nutman
Nutman's Avatar
This reminds me of another great piece of advice: get a PSU tester. No matter how hard you try, you'll **** it up eventually.
__________________
Old 29th Oct 2011, 05:42   #34
OC Maximus
Modder
OC Maximus's Avatar
OC Maximus has yet to learn the way of the Dremel
Looking very nice so far. Nice job mate!
OC Maximus is offline   Reply With Quote
Old 29th Oct 2011, 09:39   #35
mav2000
In Training
mav2000 has yet to learn the way of the Dremel
Nope they will not close flush. There will be a small bit of thread still showing.
mav2000 is offline   Reply With Quote
Old 7th Nov 2011, 22:51   #36
RedManc
Supermodder
RedManc's Avatar
I will live each day by this motto Nutman ... I want to buy more PSUs to test now
Thank you for the praise Maximus its nice to know whos watching
Thanks for the help mav, should have asked this much earlier ive scratched a fitting trying to use needle nose plyers to shut them nevermind!
So guys and girls, im waiting for a couple of new deliveries.
One from our Slovenian friends at EK and another from the guys over at Scan .. should should have picked this one up but I free delivery through bit-tech for the wins!
Not a massive update but I haven't been completely ideal this past week or so.
Yukky stock cables...
... mhmm another shot of yukky cables!
Ahhh MDPC goodnessS!
All sleeved and shrunk! I also painted the connectors with the trusty sharpie!
Got a fan controller, mounts and some adaptor fittings on route!
__________________
Old 9th Nov 2011, 17:53   #37
Nutman
Nutman's Avatar
Neat. However, you're doing the same "mistakes" as me: on some of the wires the sleeving isn't close enough to the plug - and the heatshrink isn't the same lenght.
But all that is kinda hard to master - it ONLY comes with practice.... and it's kinda nit-picking.
__________________
Old 11th Nov 2011, 00:01   #38
RedManc
Supermodder
RedManc's Avatar
I going to spend more time this weekend hopefully sleeving some other cables So hopefully ill get it even better this time. But in the mean time .. UPDATE!!
Sleeved my dads glasses and my own ... sweeet!
Got my fan controller .. bit disappointed that the brushed effect goes horizontal and the case it goes vertical but I might have semi solution when it comes to fitting it.
Got my adaptors from EK shame they don't do black nickel adaptors yet but I don't think the difference to noticable to the untrained eye.
Shocking photo of the leak test which is going on behind me but it almost midnight and im tired!
__________________
Old 11th Nov 2011, 01:42   #39
Throbbi
I Mod, Therefore I Own
Throbbi's Avatar
Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.
Glasses sleeving is genius! Awesome mod too. White, black and hint of red is always good and sometimes great
__________________
Steam - Throbbi ::WoT -Unpainted_Target ::BF3 - Throbbi
AMD FX-6300-Gigabyte 990AX-UD3-EVGA 660Ti Signature 3GB-Momentus XT-be quiet! E7-600W-Avexir 2x4GB 1600
Share And Enjoy!
Worklog - The Amputer!
Throbbi is offline   Reply With Quote
Old 13th Nov 2011, 20:32   #40
RedManc
Supermodder
RedManc's Avatar
Thank you Throbbi! My dad has stolen sleeve for his glasses ... hope I can finish the build
I have just reconnected the pump to carry on testing and it seems the pump is broken!!
Instead of continuously spinning It is pumping in short and irregular bursts
__________________
Reply
Tags
asus maximus iv extreme-z, atcs 840, ek waterblocks, first build, water cooled
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
