Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 11th Oct 2011, 12:24   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Gigabyte GA-Z68AP-D3 Review
It's a Z68 motherboard that costs just 82. What's not to like?
http://www.bit-tech.net/hardware/mot...ap-d3-review/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 11th Oct 2011, 13:24   #2
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
"they only have Crossfire X certification - there's no SLI."
Oh...great, give us the inferior dual card system, why dont you.......
If your only going to give us one, then at least let it be Nvidia's, which seems to be a far more stable and reliable dual card system.
Seriously Gigabyte....i do wish you'd used SLI
Hustler is offline   Reply With Quote
Old 11th Oct 2011, 13:44   #3
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
Z68 boards have been just a tenner or so more expensive than the comparable P67 boards, I really can't hear this
"it doesn't add many useful features over Intel's P67 chipset, despite the extra cost."
anymore.
Fast response (and sometimes encoding on the iGPU) for very little more. How is this not a win?
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 11th Oct 2011, 13:49   #4
favst89
Supermodder
favst89's Avatar
favst89 has yet to learn the way of the Dremelfavst89 has yet to learn the way of the Dremelfavst89 has yet to learn the way of the Dremelfavst89 has yet to learn the way of the Dremelfavst89 has yet to learn the way of the Dremelfavst89 has yet to learn the way of the Dremel
I guess more features without much added cost is good and maintaining the overclocking ability.
As for the x-fire SLI. I have not tried either so as to which is better I can't comment.
I believe SLI certification requires 2 slots with x8 lanes each. Whereas x-fire only requires x8 and x4. I assume this means extra cost for components/wiring of some form. It may also cost gigabyte a fee to have the certification in the first place.
__________________
[CENTER]i5 760 @ 4.2Ghz (200*21) | Gigabyte GA-P55A-UD3 | 2x4GB Sasmung Green C9 2000Mhz | M4 128GB | R0 Spinpoint F3 | GTX970 | XFX 850 Black | H80i | Asus xonar DX | 3 x U2212HM | Antec 300
favst89 is offline   Reply With Quote
Old 11th Oct 2011, 14:56   #5
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
SLI or Crossfire on Sandy Bridge is not as good as it could be simply because I don't think any of the board's will give it true 16x for each slot.
I know when I was running SLI'd GTX 580's when I installed the Nvidia Driver's I alway's got the message that the bottom card was running, slow because it wasn't in a high speed slot.
As for this board not having SLI it could put people off buying it who may want to SLI some cheap Nvidia card's, like the GTX 560's but what it offers is fine for those who decide to use 2x ATI card's or a single GTX 590.
Seem's like a decent board for someone on a budget but for someone with enough cash to buy something decent like a SLI rig they need to spend, more on a board and unless you can get a board that will give both card's the 16x speed then I think they should look, at the X58 setup's as they will give each card the full speed available to them.
Good Job Gigabyte keep it up!
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is online now   Reply With Quote
Old 11th Oct 2011, 15:57   #6
hurrakan
Modder
hurrakan has yet to learn the way of the Dremel
Why weren't the benchmarks for the "Asus Maximus IV Gene-Z" included in the charts in this review?
hurrakan is offline   Reply With Quote
Old 11th Oct 2011, 16:01   #7
hurrakan
Modder
"The one useful feature the more expensive chipset has is Intel Smart Response"
This comment is misleading. It's only true for people who only have a single, small-capacity SSD. For people with lots of SSDs, Smart Response is the most useless feature.
Old 11th Oct 2011, 17:43   #8
Christopher N. Lew
Folding in memory of my father
Christopher N. Lew's Avatar
Christopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for president
Does Smart Response make a difference in the real world?
Christopher N. Lew is offline   Reply With Quote
Old 12th Oct 2011, 10:02   #9
Xir
Xir's Avatar
For Smart Response, I think there was a test right here on bit somewhere?
For Virtu-for-transcoding, Check Tom's or Anand (as the bit article tested iGPU and dGPU the wrong way round)
__________________
SN25P
Old 13th Oct 2011, 21:51   #10
phuzz
This is a title
phuzz's Avatar
phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.
Does SLI or Crossfire actually work yet?
As in, does it actually provide faster frame rates than a comparable cost single card system without loads of headaches?
phuzz is offline   Reply With Quote
Old 14th Oct 2011, 05:07   #11
YingKo
Modder
YingKo has yet to learn the way of the Dremel
Seriously, a parallel port?
__________________
There is a hugh difference between being elite and being an elitist.
YingKo is offline   Reply With Quote
Old 15th Oct 2011, 06:38   #12
fluxtatic
Supermodder
fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.
If you're dropping $120 on a mobo, I doubt you really care much about XFire or SLI, honestly....are you honestly going to cheap out on the board and then deal with dual-card headaches on cheap cards? Why not buy a single, better card in the first place? If money was no object to me, I might go in for a multi-card setup, but it seems to be demonstrated over and over again that it doesn't scale as nicely as you might like. Aside from that, it seems that driver issues are a constant pita. Sure, some games will scale monstrously under XF/SLI, but it mostly seems to be an e-peen thing. As to favst89's comment, that may be the case (cba atm), but the board should be able to provide that, since SB does have 16 lanes (or are there other components eating into those lanes?) I would guess he's dead on about the fee part, though. Maybe XFire's just cheap enough that Gigabyte can make it a tick-box feature. Even an enthusiast might think it pretty lame that their shiny new mobo won't do either one, whether or not it matters to them personally. If I could have gotten my new board for a few bucks less without XF, I would have in a heartbeat, if that was the only thing that got dropped. (I do find it funny that mine is quad-GPU certified when they run at x16 x4, though - how well would that even work, shoving two 6990s in there? Not to mention spending 10x the cost of the board on the video cards - yes, I know the 6990s aren't the only dual-GPU AMD cards, but shiny new mobo! Need shiny new video cards!
Word, to YingKo - why the hell would I be buying a Z68 board if I needed a parallel and/or serial port? In most scenarios I can think of, Z68 would gain me no advantage in that sort of setup - better off getting a low-end ASRock or Biostar AMD board and shoving an Athlon II X2 in there - hell of a lot cheaper, too, even for a cheap Intel board. Not counting a CNC controller or similar, I suppose - who was it mentioning their greatly stripped-down XP install running the CNC machine? Total focus on running the CNC control so the part doesn't get hosed by WinUpdate being 'helpful' or the like. Would the superior platform help in that situation?
fluxtatic is offline   Reply With Quote
Old 1st Nov 2011, 22:16   #13
accountlink
What's a Dremel?
accountlink has yet to learn the way of the Dremel
What heatsink/cooler are you using to achieve 4.9GHz with Gigabyte mobo?
I have the Gigabyte GA-Z68AP-D3-B3 w/i5 2500k ...using CoolerMaster Hyper 212+ ...i'm able to overclock to 4.5 GHz no problems.
would like to replicate my successes with 4.9 if possible using the cooler you guys tested with. Thx.
accountlink is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
