Reply
Thread Tools View Mode
Old 11th Oct 2011, 15:07   #1
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.
Corsair 400 Case Mod Project: "Tribute to SERENITY firefly" ...
This Case Mod was done by bit-tech's MOTM Sponser, Mnpctech!
Customize your PC or window with custom Stickers from Mnpctech HERE
The "Tribute to SERENITY firefly" PC will be at Corsair's Suite at 2012 CES
Here are some misc graphics/labels designed for Serenity, these were displayed on cargo, equip or interior features of the ship. Some of these should look really cool distressed on the case.
This case mod will be a tribute to the "firefly" Sci-fi series and SERENITY movie. I will draw my inspiration from interior shots of the "firefly" ship. Imagining if the PC was field equipment used by the characters. The case I'll be using is Corsair's 400R mid tower. Here is their product page, http://www.corsair.com/pc-cases/carb...ower-case.html
Made switch box for mounting a pair of fighter pilot toggle switches, this will be mounted on the top handle of the corsair 400R
Bending toggle switch box
Switch plates for Red Fighter Pilot Switches, http://www.mnpctech.com/spdprtToggle.html
Update: 10/14/11
Sorry! to anyone anticipating this to look like the ship, or see a model of the serenity glued on top. My tribute is inspired by visual elements from both the movie and series that appeal to me, in particular "Our Mrs reynolds" episode, which has great scenes of Serenity's bridge. (and christina hendricks) To me, the charm of the Serenity is the mixture of Old West and industrial tech, and sometimes these elements look hobbled together. You can tell the Set builders delved into Ebay for salvaged Electronic and Ham Radio parts. I also love how everything is distressed from use and weathered. The ship's control panel is a mess...lol
It will be colored to match the panels from firefly's deck, then distressed and weathered with Copper accents, graphics from interior of firefly will be airbrushed.. side panel was created from interior of an old Dremel carry case, with wire loom, 5" conduit, 3.5" fan controllers, misc wires, misc LEDs bulgin panel LED...
Round Modders Mesh for the grills in the side.
http://www.mnpctech.com/moddersmesh.html
Bare with me on this part, it will make more sense when I've taken more pictures of the panel. I'm making a junction box for the panel, from an old bezel top.. imagining the box suffered damage from some type of accident and caught on fire.. Gumdrop LED is cracked, one of the black wire looms will be disconnected with have melted wires exposed.. I'm still deciding on what looks right, as I go along.. I plan to head over to Home Depot's Plumbing aisle tomorrow for some copper pipe, hopefully I can get .25" diameter, maybe buy a pipe bender, (probably don't need one) and emulate whats I'm only guessing is coolant or misc fluid lines? (it's all pretend..lol) from lower right panel in this photo. I keep telling myself "need more copper implemented)
after heating and bending the plastic into box... I reflected to myself "Make due with what you have on hand, and improve your skills"
Dremel had a snack... The effect of having caught on fire at one time will be added with paint later
One of the black wire looms will be disconnected with have melted wires exposed..
@GA, moddin on the cheap
Copper tubing and fans installed...
link
http://www.mnpctech.com/xbox_360_win...m_molding.html
Updated 11/4
Access panel progress
with mangled vent ..heh
...Did you ever see the episode "Our Mrs Reynolds?" ....Christina Hendricks sabotaged the control panel on the Bridge, the wiring was pretty bad...lol
progress work on top panel on 11/11/11... the tape over the switch will be cherry on top, when everything is assembled
The 240 "Serenity" in Kanji grill for the top panel, will be cnc milled from 1/4" Copper.. I may try "Flame Coloring" it like this photo...with Oxygen acetylene torch
I'll be using Sophisticated Finishes surface effect products to add some rust to areas of the exterior. I used this on the District-9 PC.
Next step is fine tuning the weathered and distressed effects with an Airbrush
I went over my initial weathered and distressed paint effects with an Airbrush. Anything that contrasted a lot, I muted with Matte Black, like the fan blades, copper tubing, decals, shiny toggle switches on the fan controller and screw heads. I also airbrushed the edges of Silver Aluminum paint, which I used to created the chipped and scratched paint beneath.
Going over areas of the right side panel with airbrush, using Flat Black, over saturated with Thinner.. to weather or "mute" some of coloring in the decals, wiring, and smaller copper tubing
and check out Mnpctech's new fan grill for 200mm / 230mm cooling fans, http://www.mnpctech.com/200mm_230mm_fan_grill.html
The "Serenity" Kanji 2x 120mm fan grill is cnc milled from 1/4" thick Copper. It was Flame colored with Acetylene Torch.
__________________
My GPU support brackets We Ship International Orders!
mnpctech is offline   Reply With Quote
Old 11th Oct 2011, 15:11   #2
RedManc
Supermodder
RedManc's Avatar
RedManc has yet to learn the way of the DremelRedManc has yet to learn the way of the Dremel
Already love it! i'm not familiar with the sereinty but ill be watching
__________________
RedManc is offline   Reply With Quote
Old 11th Oct 2011, 15:12   #3
Xtrafresh
It never hurts to help
Xtrafresh's Avatar
Xtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run CrysisXtrafresh can run Crysis
Ooooooo another one! *grabs popcorn*
these switches are excellent, love 'em
__________________
Think of how stupid the average person is, and realize half of them are stupider than that.
- George Carlin
Xtrafresh is offline   Reply With Quote
Old 11th Oct 2011, 15:56   #4
flame696
Terminating People Since 1980....
flame696's Avatar
flame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyan
God bill how many projects have you got on the go?? Not that I mind as it gves me ideas
__________________
flame696 is offline   Reply With Quote
Old 11th Oct 2011, 16:02   #5
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.
FIREFLY!
Definitely following this one.
__________________
stonedsurd is offline   Reply With Quote
Old 11th Oct 2011, 16:04   #6
Blarte
Moderate Modder
Blarte's Avatar
Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!
I do like toggle switches its like being back in the driver seat of the tank ..
__________________
Watering down PC's since 2009....
Blarte is offline   Reply With Quote
Old 11th Oct 2011, 16:14   #7
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
Looking forward to this one!
Subbed.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170|32GB|256GB M.2|500GB SSDs|8TB NAS|980 Ti|3007WFP-HC|Parvum S2.0
David is offline   Reply With Quote
Old 11th Oct 2011, 17:49   #8
IanW
Grumpy Old Git
IanW's Avatar
IanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming Saiyan
Hmmm, I wonder if you could get this onto "Castle" as Nathan Fillion's home PC?
He's already used his Mal Reynolds outfit as a Hallowe'en costume on the show.
__________________
i7 4770K@3.9GHz / Corsair H100i / Asus Maximus VI Gene / 16GB Corsair Vengeance 2133 /
Asus Strix GTX1080 Advanced / 500GB Samsung 840 Evo / 1TB 2.5" HDD / BeQuiet! 1kW /
Aerocool Dead Silence / Dell U2713HM / Corsair K70 RGB / Logitech Performance MX / Win10 / Ubuntu 16.10
IanW is offline   Reply With Quote
Old 11th Oct 2011, 18:06   #9
improprietary
FT03 is a bitch to watercool
improprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremelimproprietary has yet to learn the way of the Dremel
You do know that by using the firefly theme for your pc you are going to be under extreme scrutiny by your peers right? You don't mess with this fandom :P
by the way, it needs more warning stripes and rust.
improprietary is offline   Reply With Quote
Old 11th Oct 2011, 19:01   #10
Hannes
Design | Art | Performance
Hannes's Avatar
Hannes has yet to learn the way of the DremelHannes has yet to learn the way of the DremelHannes has yet to learn the way of the Dremel
Finally! :-D
Hannes is offline   Reply With Quote
Old 11th Oct 2011, 20:32   #11
Gentleman_Dingo
Supermodder
Gentleman_Dingo's Avatar
Gentleman_Dingo is definitely a rep cheat.Gentleman_Dingo is definitely a rep cheat.Gentleman_Dingo is definitely a rep cheat.Gentleman_Dingo is definitely a rep cheat.Gentleman_Dingo is definitely a rep cheat.Gentleman_Dingo is definitely a rep cheat.Gentleman_Dingo is definitely a rep cheat.Gentleman_Dingo is definitely a rep cheat.Gentleman_Dingo is definitely a rep cheat.Gentleman_Dingo is definitely a rep cheat.Gentleman_Dingo is definitely a rep cheat.
Swwweeeetttt... please tell me there will be an interjected Chinese cuss word. +Sub'd
Gentleman_Dingo is offline   Reply With Quote
Old 11th Oct 2011, 23:37   #12
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Yay! Something left limbo.
Are you sure you don't want to do the rig based on exterior designs? I'm bummed you won't be strapping charred action figures to the front.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 12th Oct 2011, 12:06   #13
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
i dont like the switches at all, why dont you implement them under instead?
KoSoVaR^ is offline   Reply With Quote
Old 12th Oct 2011, 13:23   #14
Roboduck
01110001 01110101 01100001 01100011
Roboduck's Avatar
Roboduck can run CrysisRoboduck can run CrysisRoboduck can run CrysisRoboduck can run CrysisRoboduck can run CrysisRoboduck can run CrysisRoboduck can run CrysisRoboduck can run CrysisRoboduck can run CrysisRoboduck can run CrysisRoboduck can run Crysis
Subbed!
Can't wait to see where this one goes!
Roboduck is offline   Reply With Quote
Old 12th Oct 2011, 20:46   #15
Knighthammer
Multimodder
Knighthammer has yet to learn the way of the Dremel
Originally Posted by stonedsurd View Post
FIREFLY!
Dito!!
Knighthammer is offline   Reply With Quote
Old 12th Oct 2011, 22:06   #16
Karrek
Multimodder
Karrek's Avatar
Karrek has yet to learn the way of the Dremel
I'm a fan of firefly and Serenity - look forward to see your progress. I also agree with Cheapskate that some charred action figures would be awesome... oh well.
Karrek is offline   Reply With Quote
Old 12th Oct 2011, 22:26   #17
xMathiasD
<Title></Title>
xMathiasD's Avatar
xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.
Awesome dude!
__________________
i rep - do you?
xMathiasD is offline   Reply With Quote
Old 13th Oct 2011, 16:49   #18
Cheapskate
Cheapskate's Avatar
@Kosovar -His theme is essentially rusty Russian military surplus with Asian warning signs. I expect exposed wires and maybe even some plumbing will be involved.
Speaking of... Any chance some nixie tubes could get in the setup?
__________________
Old 14th Oct 2011, 17:04   #19
mnpctech
bit-tech sponsor
mnpctech's Avatar
Thanks for tuning and commenting everybody! Yes, I'm juggling between projects again...lol ...in preparation for CES, January 10 -14 , and I'll be there as well, showing some of my products and previous work. So please let me know if you're attending, so I can finally meet you in person.
Ok, back to this project. Sorry! to anyone anticipating this to look like the ship, or see a model of the serenity glued on top. My tribute is inspired by visual elements from both the movie and series that appeal to me, in particular "Our Mrs reynolds" episode, which has great scenes of Serenity's bridge. (and christina hendricks) To me, the charm of the Serenity is the mixture of Old West and industrial tech, and sometimes these elements look hobbled together. You can tell the Set builders delved into Ebay for salvaged Electronic and Ham Radio parts. I also love how everything is distressed from use and weathered. The ship's control panel is a mess...lol
Yes, the circa 60s Muscle car hood scoop style panel hump is being removed.. btw: Great for cable management behind MB tray.
__________________
Old 17th Oct 2011, 08:07   #20
LooseNeutral
Hypermodder
LooseNeutral's Avatar
LooseNeutral has yet to learn the way of the Dremel
Man, you gotta put a bro on a mailing list or something when you start these things! Last I heard of this was on the FB page how long ago... Glad to see you went with it and a nice curve ball choosing this case imo. Just don't go cutt'n your ear off for your art... or other pieces for that matter.. Switches are bitc.....N! Can't wait to see the guts and gore of this one Are you gonna give a nod to the bad little hottie too?
LooseNeutral is offline   Reply With Quote
Reply
Tags
corsair 400 window, firefly pc, serenity case mod
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
