Reply
Thread Tools View Mode
Old 13th Oct 2011, 08:39   #1
Attila
still thinking....
Attila's Avatar
Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.
Arrakis
Welcome to Arrakis (dancer). This is a small HTPC project I was supposed to start about four months ago. Last Sunday, while standing in my workshop staring at cor leonis (as I have been doing a lot) trying to solve the problem of the top of the case/side panels and how to make the hinging mechanism, I decided it was best if perhaps I stopped thinking about this build for a while and did something else (or at least hope that a solution would just pop into my head if I was thinking about something else). So I just spun around, grabbed some 1.2mm sheet and started building Arrakis.
This is going to be a very simple, very small PC that will sit next to our TV. It will consist of two main parts. A compact chassis housing all the components and a pretty wooden shell.
The first thing I did was to hunt down all the parts I collected for this at the start of the year.
I quickly stacked everything on top of each other to see how all the parts can be arranged. Made some measurements and marked up the main part of the chassis on some 1.2mm sheet.
Cut it and filed it and then used some bits of alu and a couple of clamps (and a hammer) to bend it into shape.
The stanoffs were fitted to the board and the i/o plate taped into position. Then the position of the i/o plate was roughly marked.
Once that was done, more accurate measurements were taken and the cut lines marked up on the back panel.
And the waste was removed very carefully. I say carefully because there is not much left at the side and this will bend and buckle easily.
And the fit is good.
Now some braces need to be made for the sides.
In the next photo you can see that one brace is made from 8mm plate and the other from 6mm plate. There just was not enough room on the right hand side.
To work out where the holes for standoffs go. Firstly place the board where it will go. Mark the standoff positions with a pencil. Remove the board and place some masking tape where the pencil marks are. Put the board back and press down firmly on each of the standoffs. This will leave an imprint on the tape. Mark the center of the imprint and then with a pointy tool, make a mark through the tape onto the sheet. Drill holes.
Everything should fit exactly.
At the start of the year I played around with this board for a while to see if it could actually run 'fanless'. Just performing minor tasks took the temp up to 86 degrees and just resting a fan on the heatsink dropped this temp dramatically to usable levels. So I've decided to run a fan on this even though this kills my ambitions of a totally silent machine. I'm thinking I can play with the fan speed once the build is complete and with a shell, intake grille and filter, this should dampen the db's still further. I'm actually hoping it will be very close to silent.
So I need to mount a fan. I'm using anything I have laying around the workshop. The only thing I will have to buy extra for this is some wood for outside.
Some fan mounts.
And that's it.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 13th Oct 2011, 08:40   #2
Attila
still thinking....
Attila's Avatar
Here is the TV card I will be using. It is reasonably compact but will be too high to sit on top of the board.
So a PCI extender will be used and the card mounted under, and parallel, with the mobo. It's too big for my needs though, so some is cut off.
This PC is powered by a plug in module and an external power brick. So the 12 volt input is fitted to the back panel.
As all the components (Optical drive, hard drive and TV card) will be mounted beneath the mobo, the wiring needs to be routed underneath.
And that's reasonably tidy for now.
The next job is to fit all the rest of the components here.
Cor Leonis was feeling hungry . This gives you an idea of size (and a bit of fun).
__________________
stillthinking
Old 13th Oct 2011, 08:52   #3
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
nom nom nom ... smallness beauty. Are you going to build a wooden sheel like marantz used on their 1970's amplifiers (their golden age IMHO) ?
GuilleAcoustic is offline   Reply With Quote
Old 13th Oct 2011, 12:03   #4
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyan
Ultra neat and tidy from you as usual Attilla. It's tiny sitting inside the chassis of the other build, but that also gives an indication of how big that is..
Some times it's makes sense to step back and do some thing else, clear the mind and wait for a flash of inspiration to hit you from out of the blue. I should probably take that advise myself, instead of crashing through stuff. Once I get the head on I just to see it finished.
Any way, looking really good, Top modding dude.
bulldogjeff is offline   Reply With Quote
Old 13th Oct 2011, 16:31   #5
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
There's nothing more refreshing than taking an ITX build break. Your internal work way too clean.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 13th Oct 2011, 17:18   #6
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
Another one gets his hands dirty with mITX....
We'll get you all addicted to these one day
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 13th Oct 2011, 18:18   #7
GuilleAcoustic
Ook ? Ook !
I was wondering when you'd get sneaking around here
Old 13th Oct 2011, 18:41   #8
Yariko
Supermodder
Yariko's Avatar
Yariko is definitely a rep cheat.Yariko is definitely a rep cheat.Yariko is definitely a rep cheat.Yariko is definitely a rep cheat.Yariko is definitely a rep cheat.Yariko is definitely a rep cheat.Yariko is definitely a rep cheat.Yariko is definitely a rep cheat.Yariko is definitely a rep cheat.Yariko is definitely a rep cheat.Yariko is definitely a rep cheat.
As always, simple project, but you still manage to make it look way too awesome! \o/ _b
Yariko is offline   Reply With Quote
Old 13th Oct 2011, 20:23   #9
Livio
Minimodder
Livio's Avatar
Livio has yet to learn the way of the Dremel
Oh yes, an other Attila project!
Nice and precise metalwork as usual and I can hardly wait the woodwork part of it.
Subd of corse.
Livio is offline   Reply With Quote
Old 13th Oct 2011, 21:04   #10
Razer2007
Building Proxima
Razer2007's Avatar
Razer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the Dremel
Geese to much cheese.... cake.
How do you go about making sure the holes in the thick aluminium and plex are 90 degrees to the surface? Do you use a drill press?
__________________
Proxima - MOTM Feb 2012 Winner
CAGE - MOTM Sept 2010 Winner
Razer2007 is offline   Reply With Quote
Old 13th Oct 2011, 21:17   #11
peteski
long live the pc
peteski's Avatar
peteski has yet to learn the way of the Dremel
very smart looking Attila i love the size and the idea.same sort of thing id like to build one day but as a newbe to this i dout it would look like yours
subscribed
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl,
peteski is offline   Reply With Quote
Old 13th Oct 2011, 21:29   #12
Crossing
Modder
Crossing's Avatar
Crossing is a hoopy frood who really knows where their towel is.Crossing is a hoopy frood who really knows where their towel is.Crossing is a hoopy frood who really knows where their towel is.Crossing is a hoopy frood who really knows where their towel is.Crossing is a hoopy frood who really knows where their towel is.Crossing is a hoopy frood who really knows where their towel is.Crossing is a hoopy frood who really knows where their towel is.Crossing is a hoopy frood who really knows where their towel is.Crossing is a hoopy frood who really knows where their towel is.Crossing is a hoopy frood who really knows where their towel is.Crossing is a hoopy frood who really knows where their towel is.
I love the creativity that people have with mATX even if it's just a very clean design. Great work so far!
Crossing is offline   Reply With Quote
Old 13th Oct 2011, 23:03   #13
Nealieboyee
Packaging Master!
Nealieboyee's Avatar
Nealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming SaiyanNealieboyee is a Super Spamming Saiyan
I remain useless in comparison.
Nice work oldnewby. Your attention to detail is astounding as usual!
__________________
BONNIE
AMD x4 750K @ 4.4GHz | Gigabyte GA-F2A88XM-DS2 | 4GB Kingston HyperX | HD 6670 | Sandisk Pulse 64GB | Corsair CX430 | Cooler Master Hyper 412S
Nealieboyee is offline   Reply With Quote
Old 14th Oct 2011, 00:39   #14
craig - toyoracer
Supermodder
craig - toyoracer's Avatar
craig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysis
First off glad you are up and about modding again.
Nice way to use up leftover material. Have you decided on a wood?
Any ideas pop up yet
__________________
octTower
Electrocutous Orchid
craig - toyoracer is offline   Reply With Quote
Old 14th Oct 2011, 04:45   #15
PureSilver
E-tailer Tailor
PureSilver's Avatar
PureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpitPureSilver is almost as Godly as yodasarmpit
Your ultra-rapid build is already cleaner and more impressive than many in-depth multi-month monsters. I look forward to some more of your carpentry! Also...
... this is the truth.
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE, Asus P6T Deluxe V1, Corsair 12GB (6x2GB) 1600Mhz C8 @ XMP,
EVGA GTX-680, Corsair AX760, 2x Samsung SpinPoint F3 1TB, Lian-Li V1020R with 3x Noctua NF-P12 & 3x NF-P14FLX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB Samsung SSD
PureSilver is offline   Reply With Quote
Old 14th Oct 2011, 09:05   #16
[ZiiP] NaloaC
I Mod, Therefore I Own
[ZiiP] NaloaC's Avatar
[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan
Mini Attila kit Huzzah!
Looking awesome, again, as expected
__________________
ZiiP Gaming Community
Sui Generis: i7 5820K, Corsair H105, 16GB Kingston 2133, ASUS X99-S, Samsung 950 Pro 512GB M2, Samsung 850 1TB EVO, Corsair F3 120GB SSD & Samsung EVO 250GB SSD, MSI GTX 970, Corsair HX850W, Corsair Obsidian 800D, AOC 34", Logitech G15, Shogun Bros Ballista Mk-1, Corsair 1500.
[ZiiP] NaloaC is offline   Reply With Quote
Old 14th Oct 2011, 09:28   #17
yassarikhan786
Ultramodder(Not)
yassarikhan786's Avatar
yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.
Amazing. I love all of your work and I'm definitely subbing .
__________________
|| Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: Gigabyte GTX 580 Super OC || Memory: Mushkin Blackline 8GB || SSD: Corsair Force 3 120GB || HDD: WD Caviar Black 2TB || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v || Keyboard: Logitech G510 || Mouse: Razer DeathAdder
yassarikhan786 is offline   Reply With Quote
Old 14th Oct 2011, 09:34   #18
Zorndar
Multimodder
Zorndar has yet to learn the way of the Dremel
Your eye for details and craftsmanship always amazes me. Great work up to now!
__________________
i3770k @ 4GHz - Gigabyte Z77 UP7 - Corsair 16Gb 1600Mhz - 780Ti Sli - Samsung 850 Pro 256 GB + 850 EVO 512 GB - 4TB WD Black
Zorndar is offline   Reply With Quote
Old 14th Oct 2011, 12:49   #19
Attila
still thinking....
Attila's Avatar
Well I'm hoping to build something a little more elaborate. But yes, it will be mostly wood.
Speaking of Marantz. The only product of theirs I ever owned was a power amp in the late seventies. I used it for monitoring in my home studio (read bedroom).
It packed a punch but unfortunately I blew it one day by using it as a guitar amp into one channel. It was left at a high end hi-fi store for a long time while they tried to find parts. One day I got a phone call telling me that they had located the parts and I asked what the price of the repair was likely to be. I didn't go back to collect it.
Before I destroyed it, the amp was fed by a Phase Linear pre amp.........
.......as part of the studio (and listening to music of course).
These amps weren't bad but the best amp I ever heard (and I owned plenty and listened to a lot more), were these little units by BGW.
I won nine hundred bucks in the lotto in 1979 and after collecting the money, headed straight over to the local distributor for BGW. Nine hundred didn't buy a heck of a lot of high quality gear (even in 79 ), so I settled on the 100B power amp and a pre amp I cant remember the model number of. The 100B was rated at only 45 watts per channel but a signed test sheet showed 69 watts in one channel and 70 in the other. Anyway, I knew that I could get away with low power amps because I was using super efficient EV sentry III's at the time. These amps, particularly the 100B were a revelation. Running the CD player straight into the 100B (and skipping the pre amp) produced sound unlike I've heard before or since.
An interesting bit of fluff. I used to read all the hi-fi mags and I was following the development of the compact disc a couple of years before it became commercial reality. I taped all my records and sold the whole collection about six months before the first CD players were released locally. In the photo above you can see the first player available here in oz. That player cost over thirteen hundred bucks and for me to own it I took out my first ever loan. No more hiss, crackles or pops.
Thanks jeff. Yep I do need a rest. My bwain hurts.
Thanks.
You gotta love these things. All the parts are small and all the work is so much quicker and easier.
Thank you.
Subd of corse.
Thanks.
subscribed
Thank you.
Thanks.
Thanks.
Thanks Craig. No I haven't looked for wood yet and I'm not thinking about CL at the moment.
Thanks. Yeah I'm really enjoying this at the moment. It's coming together very quickly and that keeps the interest level high.
Haha, thanks Ziip.
Thank you.
Thank you.
__________________
stillthinking
Old 14th Oct 2011, 13:18   #20
Yemerich
I can has PERSUADETRON?
Yemerich's Avatar
Yemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpitYemerich is almost as Godly as yodasarmpit
Heya Attila, great work as always!
Nice to see you again in a project, better yet in a HTPC.
I was wondering, isn't this a good time to update your guides at your personal home page? I am sure that people here would love to see that happening!
Pleaaaaaaase?
BTW, I saw ARRAKIS, the I was mentally saying:
"Planet Arrakis, land of sand. Home of the SPICE..."
I didn't know that there was another meaning for "Arrakis"...
Cheers mate!
__________________
----------------------------- Yemerich -----------------------------
Hephaestus (best design Windows Vista Magazine - 2007, MotM nominee 2008)
Odinn (CCE best design in CP-Brazil 2008)
Hades (Best advanced casemod design CP-Brazil 2010)
Take a look on my projects here.
Yemerich is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
