Reply
Thread Tools View Mode
Old 1st Nov 2011, 12:49   #41
coolamasta
Folding@Home CC Captain 2010/11/12
coolamasta's Avatar
coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.
That is going to be cooool, keep up the good work
__________________
My Main Rigs:~ H2O'd i7 3770K @ 4.5 - 16GB - H2O'd GTX 670 | Asus Z9PE-W8, EP-Xeon 2670 @ 3.2 - 16GB
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ |
coolamasta is offline   Reply With Quote
Old 3rd Nov 2011, 16:47   #42
thechoozen
Hypermodder
thechoozen's Avatar
thechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysis
thx a lot m8´s!!!
today it´s time for an update again
In the last days we spent the most of our time with fibre glass matt and epoxy resin it´s always a big mess...but we made good progress while laminating the first layers of fibre glass to the body and sidepanels...
beside that we finished the polishing of the plexiglas lense and tested it on the other of the eye....
thechoozen is offline   Reply With Quote
Old 3rd Nov 2011, 16:52   #43
jeckulz
Supermodder
jeckulz's Avatar
jeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremeljeckulz has yet to learn the way of the Dremel
MOAR!!!
Loving it mate, keep it up
jeckulz is offline   Reply With Quote
Old 3rd Nov 2011, 20:46   #44
peteski
long live the pc
peteski's Avatar
peteski has yet to learn the way of the Dremel
looking good mate
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl,
peteski is offline   Reply With Quote
Old 8th Nov 2011, 18:19   #45
thechoozen
Hypermodder
thechoozen's Avatar
thx m8´s!!
today i´ve got another update for you
in the last days we spent the most of our time with the next steps of the laminating process, but beside that we also made some progress on the electronics which will be involved...
For the voice of our Sentry we want to use an arduino together with a music shield and a few sensors. We already have a spare arduino in our workspace...so the next thing we needed was a cheap motion sensor to test if it could work like we thought. After a short research we found out that we could salvage one out of those automatic air refreshing room sprays which you can get for 3€ (the same sensor in an electronic shop near to us, cost 10€ )
So we get one of those sprays and disassembled everything so that we could test the sensor with the arduino....
Old 8th Nov 2011, 19:59   #46
Zet
What's a Dremel?
Zet has yet to learn the way of the Dremel
That lense obviously needs red LEDs in them! Sweet work so far: your turret will be filled with more then bullets
Zet is offline   Reply With Quote
Old 9th Nov 2011, 08:58   #47
OmightyOne
Multimodder
OmightyOne's Avatar
OmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the DremelOmightyOne has yet to learn the way of the Dremel
Salvaged electronics ! couldn't build a pc without them.
OmightyOne is offline   Reply With Quote
Old 16th Nov 2011, 14:06   #48
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Originally Posted by thechoozen View Post
I need to get clued up with this side of modding so you can use mad combinations of parts like this, awesome stuff thechoozen .
Waynio is offline   Reply With Quote
Old 17th Nov 2011, 17:57   #49
thechoozen
Hypermodder
thechoozen's Avatar
most of the time it´s just a stroke of luck...this time i found the right instructable to the right moment
Time for a small update again!!
like you could already see on one of the last pics....we already started to bring some bondo onto the body of our turret....we continued the progress in the last days...
.....and we also started to build the first parts of the legs....
Old 17th Nov 2011, 18:16   #50
Waynio
Waynio's Avatar
Shaping up nicely .
Old 17th Nov 2011, 19:46   #51
Luciel
Multimodder
Luciel's Avatar
Luciel has yet to learn the way of the DremelLuciel has yet to learn the way of the DremelLuciel has yet to learn the way of the DremelLuciel has yet to learn the way of the DremelLuciel has yet to learn the way of the Dremel
Simply epic!! will it say something if you push it over?
Luciel is offline   Reply With Quote
Old 17th Nov 2011, 22:59   #52
Cleveland216
Carbon Fiber King
Cleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the Dremel
good work!! I'm subscribed
Cleveland216 is offline   Reply With Quote
Old 18th Nov 2011, 06:24   #53
thechoozen
Hypermodder
thechoozen's Avatar
Sure!!! thats one of the most important features we want to integrate (beside the laser pointer eye and the side panels)....atm we´re already tinkering on a solution based on a arduino shield....but that will follow later....
Old 18th Nov 2011, 10:02   #54
Noob?
Dremel?
Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.Noob? is the Cheesecake. Relix smiles down upon them.
tabbed!
Noob? is offline   Reply With Quote
Old 18th Nov 2011, 10:24   #55
yassarikhan786
Ultramodder(Not)
yassarikhan786's Avatar
yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.
Loving the concept. Can't wait to see the end product . Subbed and +rep
__________________
|| Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: Gigabyte GTX 580 Super OC || Memory: Mushkin Blackline 8GB || SSD: Corsair Force 3 120GB || HDD: WD Caviar Black 2TB || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v || Keyboard: Logitech G510 || Mouse: Razer DeathAdder
yassarikhan786 is offline   Reply With Quote
Old 18th Nov 2011, 13:11   #56
Sarakon
The German
Sarakon's Avatar
Sarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run Crysis
This is awesome!! cant wait for further updates!!
__________________
Obsidian 650D | Asus P8P67 EVO | Intel i5 2500K | OCZ Vertex 4 | Corsair Vengeance 16GB | MSI GTX 660Ti PE OC | Cooler Master 850W Silent Pro M
World Of Tanks: Sarakon | BF3: SarakonGT
Sarakon is offline   Reply With Quote
Old 28th Nov 2011, 18:12   #57
thechoozen
Hypermodder
thechoozen's Avatar
thanks m8´s!!
in the past 2 weeks we spent a lot of time in the progress of the legs....but now we´re really near to complete the outer shape
and here are a few pics of the progress we made....
we started with 2 layers of plywood and between them 3-4 layer fibre glass material
and then we added foam, just to gain a bit more size to work with....
beside that we started to overwork the dimensions of the gaps between the sidepanels and the main body.....
Old 28th Nov 2011, 19:46   #58
[ZiiP] NaloaC
I Mod, Therefore I Own
[ZiiP] NaloaC's Avatar
[ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!!
Very nice work on sealing up the lines.
__________________
ZiiP Gamestore
[ZiiP] Gaming Community - IW BlackMailers and loonies abound!
Sui Generis: i7 920, Corsair H50, 6GB Dominator C7 1600, EVGA x58 SLI LE, Corsair F3 120GB SSD, Samsung F3, Sapphire 5870 Vapor-X, Corsair HX850W, Corsair Obsidian 800D, Iiyama 26" Prolite, Logitech G15, Logitech G5, Sennheiser PC350.
[ZiiP] NaloaC is offline   Reply With Quote
Old 28th Nov 2011, 20:31   #59
peteski
long live the pc
peteski's Avatar
looking good mate
__________________
Old 29th Nov 2011, 04:08   #60
Jipa
Avoiding the "I guess.." since 2004
Jipa's Avatar
Jipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run Crysis
I remember wondering why nobody had done this before Although I was thinking if I should try to modify a webcam to look like a miniature turret...
Looking good, should be awesome when finished!
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2
Jipa is offline   Reply With Quote
Reply
Tags
babetech.de, bt-custompc, mini itx, portal, sentry turret
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
