Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 19th May 2012, 14:02   #101
Spanky
Multimodder
Spanky's Avatar
Spanky is a hoopy frood who really knows where their towel is.Spanky is a hoopy frood who really knows where their towel is.Spanky is a hoopy frood who really knows where their towel is.Spanky is a hoopy frood who really knows where their towel is.Spanky is a hoopy frood who really knows where their towel is.Spanky is a hoopy frood who really knows where their towel is.Spanky is a hoopy frood who really knows where their towel is.Spanky is a hoopy frood who really knows where their towel is.Spanky is a hoopy frood who really knows where their towel is.Spanky is a hoopy frood who really knows where their towel is.Spanky is a hoopy frood who really knows where their towel is.
Rfactor with realfeel is really nice. I race 99% of the time on that sim, cant say i like Iracing, tried it but im not taken with it. The costs are insane also.
This is what im wetting my knickers about latey, i think its gonna be really really good.
http://www.assettocorsa.net/?lang=en
__________________
P8P67PRO - 2500K - 8G C8 Vengance - 120g Vertex Agility 3 - XFXDD7950 - H50 Cooling - Antec P183
Spanky is offline   Reply With Quote
Old 19th May 2012, 14:06   #102
feathers
Banned
feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.
Originally Posted by Showerhead View Post
Realfel was the plugin name. Think half the problem is that some logitech wheels report ffb backwards compared to every other wheel on the market including some of their own. I guess most games detect this and reverse ffb for them but not rfactor.
So logitech and fanatec both report reverse FFB? So why is it only an issue with fFactor then? Never had probs with any other racing game.
feathers is offline   Reply With Quote
Old 19th May 2012, 17:34   #103
Showerhead
Ultramodder
Showerhead's Avatar
Showerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run CrysisShowerhead can run Crysis
Never heard of fanatecs having a problem. It's certainly a problem with rfactor as it dosen't check which direction force feedback works like other games do.
Showerhead is offline   Reply With Quote
Old 19th May 2012, 17:51   #104
feathers
Banned
Well it's just rFactor so it's not a problem cos that is so old I don't play it. Just that when I tried it again recently to see why the game is so hyped, I totally don't get it. I would have to disable FF in order to play it and it just ain't worth it. It's not the fanatec with the problem though as I said. I have a logitech wheel and fanatec and rfactor behaves the same insane way with both. Basically wheel centring is reversed so the wheel is actually repelled as it gets near the centre.
Old 19th May 2012, 19:32   #105
Canon
0.003s faster
Canon's Avatar
Canon should be considered for presidentCanon should be considered for presidentCanon should be considered for presidentCanon should be considered for presidentCanon should be considered for presidentCanon should be considered for presidentCanon should be considered for presidentCanon should be considered for presidentCanon should be considered for presidentCanon should be considered for presidentCanon should be considered for president
Never had any such problems. I think rFactor is more popular amongst single seater/open wheeler sim fans because just about every other sim managed to balls it up. Even project cars hasn't got the formula cars right yet, but much better than some of the others so far.
__________________
Canon is offline   Reply With Quote
Old 19th May 2012, 19:59   #106
feathers
Banned
I guess no one plays it with FF on...
Also the problem with it I describe has also been talked about on forums.
Old 20th May 2012, 10:42   #107
Spanky
Multimodder
Spanky's Avatar
I use realfeel FFB with rfactor. Admittidly some times i have to reverse the FFB but its very easy to identify what needs doing on. The FFB overall is very very good, just dont use the standard FFB
I have no such dramas with Rfactor, its a very easy to use sim, mountains of really great mods and tracks and have used it for the past 5 years. Atm Rfactor 2 isnt even as close to being as good as Rfactor 1 with the expection of the FFB which in Rfactor 2 is just amazing. Running a G27 wheel and pedal set,Obutto rig with triple screens and really hoping i can afford the Fanatec Clubsports to go with the Logitech wheel.
Any of you guys use/ever have Race2play.com?? I run on there as Simon Shepherd.
__________________
Old 20th May 2012, 15:09   #108
bdigital
Is re-building his PC again
bdigital's Avatar
bdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpit
Do you have the wheel software installed? Check for a setting that reverses the wheel feedback. (i forget the technical term!)
Also check the game control menus for an option that inverts it.
It's certainly not like that for me and most probably works fine for most so there should hopefully be a setting somewhere you can change
Sent from my HTC Wildfire S A510e using Tapatalk 2
__________________
My photography website: http://www.polarityphoto.co.uk Please share! || Follow me @polarityphoto on Twitter|| My Flickr ||
Check out my Apline White TJ07 - Case Mod and Water cooled build. http://www.flickr.com/photos/6188486...7631486959032/
bdigital is offline   Reply With Quote
Old 21st May 2012, 00:27   #109
Gabkicks
Minimodder
Gabkicks has yet to learn the way of the Dremel
rfactor + historx (realfeel) and other mods that use realfeel give me better ffb than pcars, currently. Hopefully that won't be the case much longer.
__________________
Intel i7 920 4ghz + Xigmatek DK| ASRock X58 Extreme | OCZ Gold 6GB 1600ram | Gigabyte GTX 670 Windforce |
640gig+1tb WD 7200rpm sata 3 | Antec Twelve Hundred|OCZ 780watt modular
Samsung 2494LW monitor | CreAtive X-Fi XtremeMusic | Fanatec Porsche 911TS wheel Logitech g500. OCZ Elixir
Gabkicks is offline   Reply With Quote
Old 26th May 2012, 00:41   #110
Canon
0.003s faster
Canon's Avatar
Offtopic post but can we please have a hotlaps server for rfactor?, I really want to put my laps against some users here, there seems to be a good few of you with rfactor and i'd love to compare setups on some mods.
I'm playing F1 1991 league edition atm, it was the first mod I played competitively and at magny cours 1992 config.
__________________
Old 6th Jun 2012, 20:29   #111
Cleggmeister
Of reasonable knowledge...
Cleggmeister's Avatar
Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.Cleggmeister is a hoopy frood who really knows where their towel is.
Originally Posted by M0dMaSt3r View Post
Slightly Mad Studios Announce Ford Licensing Agreement
Here is the Carlist :
  • 1966 Mustang 2+2 fastback
  • 1967 Ford MK IV (GT40)
  • 1972 Escort RS1600
  • 1980 Capri (Group 5 – Team Zakspeed)
  • 1988 Sierra RS500 Cosworth (Group A)
  • 1997 Mustang Cobra (SCCA Trans-Am)
  • 2012 Fusion NASCAR Stock Car
  • 2012 Focus ST
  • 2012 Focus ST (BTCC)
  • 2013 Falcon FG (Australian V8 Supercar Car of the Future)
  • 2013 Ford Shelby GT500
Three new Videos :
Project CARS - Build 226 | Caterham SP/300.R @ Bathurst ( Hazy )
Project CARS - Build 226 | Asano X4 @ Harrison Pike Raceway ( Night )
Project CARS - Build 226 | Caterham SP/300.R @ Sakitto
I'll forgive them missing the MkIII Escort 1.6GL, my first car and first love
Really enjoying the videos, though more racing and less hotlaps for me please!
Thanks,
/Cleggy
__________________
Pooting: Antec 300, P6T SE, i7 920 (3.20), Corsair F120SSD, 3x1TB HDD, 9Gb (1600XMP), GTX560Ti 2Gb (880/1760/2100), Win7 x64.
Grooving: Linn LP12, Klimax DS, Klimax Kontrol, Aktiv Akurate x 10 with Aktiv 242's.
Watching: WDTV Live to 50" Panasonic.
Serving: HP Proliant Microserver N40L running Openmediavault.
Cleggmeister is offline   Reply With Quote
Old 12th Jun 2012, 19:00   #112
Elton
Proud Model M User
Elton's Avatar
Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.Elton is the Cheesecake. Relix smiles down upon them.
I see no RS200.
__________________
There's good ideas and then there's terribly great ideas.
Elton is offline   Reply With Quote
Old 15th Jun 2012, 06:33   #113
Pookeyhead
It's big, and it's clever.
Pookeyhead's Avatar
Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.
  • 2012 Focus ST
No S197 Mustang? That's unusual. The Falcon is a good call, as is the Sierra.... but no Boss 302, or Shelby? WTF? At least they picked a 66 and not the obligatory 68.
Awaits M0dMasT3r's videos
__________________
MAIN RIG |Intel i7 3960X @ 4.7GHz ¦¦ Asus Rampage IV Extreme ¦¦ 16Gb Mushkin DDR3 2133 ¦¦ 512GB Samsung 830 SSD ¦¦ 4TB of HDD Storage ¦¦ 4GB EVGA GTX670 Superclocked SLI ¦¦ Corsair 650D ¦¦ Eizo ColorEdge CG303W & Dell 2007FP ¦¦ Logitech Z623
EARTH| Celeron E3200 ¦¦ Gigabyte G31M-ES2L ¦¦ LSI SAS8704EM2 ¦¦ 3TB RAID5 ¦¦ Headless - VNC administered
MOON | Thecus N3200pro 3TB RAID5
Pookeyhead is offline   Reply With Quote
Old 15th Jun 2012, 21:58   #114
bluespider42
Supermodder
bluespider42's Avatar
bluespider42 has yet to learn the way of the Dremelbluespider42 has yet to learn the way of the Dremelbluespider42 has yet to learn the way of the Dremelbluespider42 has yet to learn the way of the Dremel
Bunch of classic Lotus cars have been announced
1962 Lotus 25 (Formula One car)
1965 Lotus 40 (open-top sports car)
1965 Lotus 38 (Indy 500 winner)
1967 Lotus 49 & 1970 Lotus 49C (Formula One car)
1967 Lotus 51 (Formula Ford car)
1970 Lotus 72 (Formula One car)
1977 Lotus 78 (Formula One car)
1986 Lotus 98T (Formula One car)
__________________
Steam/GFWL/BFBC2/BF3/Autolog: bluespider42
i7 920 - HR-02, X58A-UD3R, GTX580, 6GB XMS3, Seasonic X750, 128GB Crucial 300, 240GB Vertex 2, Silverstone FT-02, U2711 + P1911
bluespider42 is offline   Reply With Quote
Old 16th Jun 2012, 09:57   #115
cookie! nom nom
Supermodder
cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!
cant wait to get the new rig up for this game :P what card do i need to look at to run at high (1080p)
cookie! nom nom is offline   Reply With Quote
Old 16th Jun 2012, 10:25   #116
AlexB
Web Nerd and WC Addict
AlexB's Avatar
AlexB is a hoopy frood who really knows where their towel is.AlexB is a hoopy frood who really knows where their towel is.AlexB is a hoopy frood who really knows where their towel is.AlexB is a hoopy frood who really knows where their towel is.AlexB is a hoopy frood who really knows where their towel is.AlexB is a hoopy frood who really knows where their towel is.AlexB is a hoopy frood who really knows where their towel is.AlexB is a hoopy frood who really knows where their towel is.AlexB is a hoopy frood who really knows where their towel is.AlexB is a hoopy frood who really knows where their towel is.AlexB is a hoopy frood who really knows where their towel is.
Anyone else losing all of their controller settings?
__________________
Whenever I smell asphalt, I think of Maureen. That's the last sensation I had before I blacked out; that thick smell of asphalt. She said she'd fix my bike. Free. No strings attached. I shoulda've known then that things were never that simple. Yeah, when I think of Maureen, I think of two things: Asphalt, and trouble.
1: Intel I7 2600k, ASUS P67 Pro, 16gb Corsair, AMD 7970 (3gb), Corsair 256gb SSD
2: Intel I7 2600k, ASUS P67 Pro, 16gb Corsair, Nvidia 680GTX (4gb)
AlexB is offline   Reply With Quote
Old 16th Jun 2012, 10:29   #117
bluespider42
Supermodder
Each time you play or after each new patch?
__________________
Old 16th Jun 2012, 10:34   #118
feathers
Banned
I kind of feel some of the tracks lack scenery.
Old 16th Jun 2012, 10:50   #119
feathers
Banned
Formula Rookie ( Formula Ford ) on Watkins Glen
Project CARS - Build 234 | Formula Rookie @ Connecticut Hill GP
That track has scenery.
It's a shame Project cars doesn't support 3d glasses. Adds enormously to a racing sim.
Old 16th Jun 2012, 13:35   #120
feathers
Banned
Nice lighting, I like the dusk sky and the car lighting effects.
Reply
Tags
c.a.r.s, dx11, game, racing, sms
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
