#1 |
Margon Man
HDD space has vanished
This is really baffling me, yesterday I had more than 100gb spare on my H: drive, now i dont.
![]() windirstat is still showing that i should, but the disk properties isnt, as far as i can see on the disk, there isnt stuff on there, and I certainly haven't added 100gig of stuff. Any ideas?
__________________
i7 920 - 12GB - 5870 Keycool 87 Modded Clears - Cougar Attack Reds - KBT Oni Browns - Ducky DK1087 Blues - Cherry G80-3700 Blacks |
#2 |
I've been away far too long
Failing hard drive maybe? I had one once that was slowly failing and gave stupid readings like that.
__________________
AMD A4 5300 @ 4GHz | | 4GB 1600 Patriot | 128GB SSD | 500GB Samsung HD501LJ | 320GB Hitachi 2.5" | CX430 PSU |
#3 |
Ultramodder
You got system restore switched on for the drive?
#4 |
Margon Man
nah system restore isnt on for the drive. The drive is only about 2 or 3 months old, its not old at all.
__________________
#5 |
Panda have Guns
There's lots of data in the 'user' folder, someone else used it and downloaded a shed load?
__________________
|Fractal Design Define R3, Black Pearl (Case)|ASUS P8P67 Deluxe (Motherboard)|Intel® Core™ i5-2500K (Processor)| |G-Skill 8GB DDR3 1600mhz Sniper 1.25v (Memory)|ASUS GTX 670 / Gigabyte GTX 670 (SLI Graphics)| |Corsair Professional Series Gold AX 850W (Power Supply Unit)|Asus Xonar D2X PCI-Express (Sound Card)| |OCZ Vertex 3 120GB (Solid State Drive - Boot)|OCZ Vertex 3 240GB (Solid State Drive - Games)|
#6 |
Run SeaTools to check it isn't failing, even if it is brand new doesn't mean it can't fail. Other than that, possibly something wrong with the SATA port? Very unlikely but not a lot else I can think of.
__________________
#7 |
Margon Man
Nah, im the only user of this pc, you're right there is alot there, but its about 130gb music, bt still if you add up all those numbers, is no where near close to what properties says it is.
__________________
#8 |
Margon Man
![]() so far has passed all the tests, just running the long test. Any idea why that drive is orange? Its the one with the "missing" space, all the others are grey.
__________________
#9 |
Different make of hard drive, Maxtor and Seagate apparently use gold ones, whereas everything else is grey.
__________________
#10 |
<?php echo "follow the white...";?>
possibly a virus duplicating data, I have had this on my last machine at one point, I ran down the directories until I found the files causing the problem, then deleted them, first time it crashed my system, second attempt worked but it took ages and I had to leave the pc while it did it, then after a few days there was no space again.
Did a system wipe and reinstalled the operating system and this fixed the problem.
__________________
Two Systems identical specifications - AMD Phenom II X6 2.8 GHz - Asus MB - 4GB Ram - 1TB HHD - KFA2 GeForce GT520 1GB - Scout CM Storm Case - Win7 Hom Prem - 4 Hanns-G Monitors(two on each system).
http://i1084.photobucket.com/albums/...icture033a.jpg |
#11 |
Hypermodder
Try running windirstat as administrator.
#12 |
I *am* the guy with two left hands
For example i managed this with FRAPS. I enabled desktop monitoring and then hit the recording key - so i ended up with my SSD full of desktop videos
__________________
Cerberus Core i7-2600K Asus P8Z77-I Deluxe GSkill RipjawsX 2x8GB DDR3-1600CL9 watercooled EVGA GTX670 Samsung 830 256GB Bitfenix Prodigy Seasonic X-460 Windows 8 Pro Prometheus Xeon E3-1235 Asus P8B WS GSkill RipjawsX 2x4GB DDR3-1333CL7+2x8GB DDR3-1333CL9 Coolink Corator DS Force 3 240GB+4xWD30EFRX+2xWD20EARS+6xWD20EARX Nanoxia DS1 Seasonic X-460 Ubuntu 12.04 |
#13 |
Elitist
Have you been playing around with symlinks?
Windows doesn't behave well when it comes to calculating disk space on drives where symbolic links are in use, as it tends to subtract the storage space of both the actual file and the file pointed to by the symbolic link (ie; the same file) when calculating disk usage. This may have been fixed since I last checked, but I remember that being an issue sometime in the past where, for example, someone made a symbolic link to a 300Gb Steam folder and saw their free disk space plummet by 300Gb as reported by the OS, but without actually losing the space. Have you Chkdsk'd the drive? Also this.
__________________
Main: CM Cosmos II <-> Core i7 920 @ 4GHz <-> EVGA GTX 580 <-> GA-EX58-UD5 <-> 6GB DDR3 <-> Samsung 840 Pro <-> Crucial M4 <-> Xonar D1 <-> Dell U2410 <-> HP ZR24w Laptop: Core i7 2670QM<-> GTX 570M <-> 8GB DDR3 <-> Crucial M4 <-> XMG P511
#14 |
Infrastructure Specialist
Are shadow copies enabled on that drive?
Could well be previous versions that's using that amount of space
__________________
If what I've said helps you please remember to hit the rep button on the left Missing the old meeting place? Find us here |
#15 |
Multimodder
Google a app. By the name of "sequoia tree", it will create a visual map of everything on your selected drive, organised by size.
Good luck. Sent from Bittech Android app |
#16 |
I have no idea what's going on
TreeSize also shows you what files and folders are the largest on your hard drive, hopefully showing you where this space is being lost.
__________________
Main Box: Intel Core i5-3570K // Gigabyte GA-Z77-D3H // 16GB Corsair Vengeance DDR3 // XFX HD7850 1GB OC // Crucial M4 256GB SSD // 4TB Storage // Antec Kuhler H2O 620 // CM690 II // Corsair CX600W // Sidewinder X8 // 2x19" Dell & BenQ G2222HDL
Server: Intel Core 2 Quad Q6600 // 6GB Crucial DDR2 // Sapphire HD5670 1GB OC // 500GB HDD // JGM Software Development, Web, Consultancy: www.jgmsoftware.co.uk |
#17 |
Margon Man
I opted to move everything onto another hdd and format this one, problem solved. I cannot still work out what had happened. I tried using various space diag programs, that would show all the folder/file sizes, yet none of them would equal the size properties said was on the disk. Bizarre, well its all happy days again now. Thanks all for input
__________________
| Thread Tools | |
