Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 24th Oct 2011, 13:57   #1
Claave
You Rebel scum
Claave's Avatar
Claave has yet to learn the way of the DremelClaave has yet to learn the way of the DremelClaave has yet to learn the way of the Dremel
AMD Bulldozer B3 Stepping Due
BIOS and kernel documentation has already named a B3 revision for the FX-8150.
http://www.bit-tech.net/news/hardwar...stepping-due/1
Claave is offline   Reply With Quote
Old 24th Oct 2011, 14:12   #2
aRkangeL
MegaRUSH
aRkangeL's Avatar
aRkangeL has yet to learn the way of the Dremel
I hope some good news!
__________________
Intel i5 3570K @ 5Ghz | Asrock Z77 Extreme 6| Kingston HyperX Beast 2133 16Gb | Asus GTX580 DirectCU II | Kingston HyperX 3K 120Gb | Corsair AX860i | XSPC H2 @ Full WC|
Projects: Purple Li | Dragon Beast | Fractal uP Gaming | Pande Benchtable
aRkangeL is offline   Reply With Quote
Old 24th Oct 2011, 14:16   #3
PCBuilderSven
Multimodder
PCBuilderSven has yet to learn the way of the Dremel
Hopefully AMD will pull themselves together and get something decent out, we need some competition.
PCBuilderSven is offline   Reply With Quote
Old 24th Oct 2011, 14:32   #4
.//TuNdRa
Resident Bulldozer Guru
.//TuNdRa's Avatar
.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan
Bulldozer just outright needs to get into the marketplace. Scan's had them overdue on Pre-order since the release, which isn't exactly helping those of us that are silly enough to buy them anyway.
Hopefully the B3 stepping will fix things, at least. I see no reason to release it as "AMD FX-8150 MK2" when they can just slap B3 on the box instead if it is a massive shake-up of Single-threaded performance.
__________________
Overdue Upgrades: AMD R7 1700 | Thermalright Archon IB-E | Asrock Taichi 370X | 16GB (4x4GB) Corsair Vengeance LPX | Asus Strix Soar | Gigabyte Windforce 670 | Silverstone ST1000-PT | Silverstone Raven RV-02B V1.7 | 2x Hynix SL301 250GB RAID0 | 2x WD 3TB RED RAID0 | Lite-on Blu-ray ROM
Dell U2913WM | Sennheiser HD 518s | Microlab Solo8C Speakers | Logitech G13 | Ducky Legend (MX Blues) | Logitech G503
.//TuNdRa is offline   Reply With Quote
Old 24th Oct 2011, 14:50   #5
Tyrmot
Supermodder
Tyrmot's Avatar
Tyrmot has yet to learn the way of the Dremel
I was waiting for these chips but now, as I suspect many others have, already bought the 2500k after the benchmarks came out, a shame as I was really hoping they would be more competitive with intel.
Tyrmot is offline   Reply With Quote
Old 24th Oct 2011, 14:58   #6
Mraedis
Multimodder
Mraedis has yet to learn the way of the Dremel
It's still more "bang for buck" to buy a new AM3 processor for me, seeing how I already have a high-end motherboard, so a 2600K would cost me double that of the best AM3-FX.
__________________
Mraedis is offline   Reply With Quote
Old 24th Oct 2011, 14:58   #7
TMhat
frupsie bumsies
TMhat has yet to learn the way of the DremelTMhat has yet to learn the way of the Dremel
First link says ArsTechnica but links to an Anandtech post?
TMhat is offline   Reply With Quote
Old 24th Oct 2011, 15:08   #8
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyan
The million dollar question how much will it fix? I said it in a post elsewhere on the forums, hat maybe the 8170 will be the one that sorts it all out as they've got a bit of time to play with it and hopefully get it right and then there's Pile driver, when ever that arrives. If it could deliver 990X performance with higher overclocking potential, then it'll be going in the right direction.
Edit: I think I'm being the eternal optimist where AMD are concerned so lets hope they can sort it out.
bulldogjeff is offline   Reply With Quote
Old 24th Oct 2011, 15:24   #9
Panos
Supermodder
Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.Panos is a hoopy frood who really knows where their towel is.
I am happy with my 1090T@4.4Ghz on a FX990 motherboard. I will wait for a year or more to upgrade on the new AMDs.
Panos is offline   Reply With Quote
Old 24th Oct 2011, 16:30   #10
Marvin-HHGTTG
CTRL + SHIFT + ESC
Marvin-HHGTTG's Avatar
Marvin-HHGTTG is almost as Godly as yodasarmpitMarvin-HHGTTG is almost as Godly as yodasarmpitMarvin-HHGTTG is almost as Godly as yodasarmpitMarvin-HHGTTG is almost as Godly as yodasarmpitMarvin-HHGTTG is almost as Godly as yodasarmpitMarvin-HHGTTG is almost as Godly as yodasarmpitMarvin-HHGTTG is almost as Godly as yodasarmpitMarvin-HHGTTG is almost as Godly as yodasarmpitMarvin-HHGTTG is almost as Godly as yodasarmpitMarvin-HHGTTG is almost as Godly as yodasarmpitMarvin-HHGTTG is almost as Godly as yodasarmpit
Definitely. If it's a simple power-reduction, and thus a small increase in OC headroom, it'll be essentially worthless, whereas if we see major improvements in key areas (single thread performance, more consistent mutli-thread performance), B3 will be immense. Bulldozer is already competitive for certain workloads, but its weaknesses are too glaring for the majority.
Marvin-HHGTTG is offline   Reply With Quote
Old 24th Oct 2011, 16:36   #11
technogiant
Supermodder
technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.technogiant is definitely a rep cheat.
Yeah they only have to increase their performance/clock/core by 100% and they will equal the 2500k and 120% to match the hyperthreaded 2600k.....way to go AMD.
The only BANG from your buck you'll get out of a bulldozer is the sound of your PSU busting under the strain when you try to get a oc out of it......lol.
technogiant is offline   Reply With Quote
Old 24th Oct 2011, 17:00   #12
azazel1024
Supermodder
azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.
Well some workloads it is really great, but power per watt efficiency, even in these workloads, appears to be way below Intel. So not only are they going to need to improve single thread and low multithreaded performance, but they are going to need to improve power efficiency at the same time (significantly).
I think that is where a huge knock comes in the server market place. These chips seem like the server version is going to be a lot more competitive with the kind of workloads servers face compared to Intel chips...but the compute efficiency per watt looks like it is still going to be WAY below Intel in most/all circumstances.
That is a big issue when a major cost is your electric bill for running your servers as well as power constraints in racks and HVAC. Even if the chips in most of their workloads turn out to be faster, if the performance per watt is a lot lower, don't expect to see a lot of sales. If I am footing the bill I could careless that my new rack server cost me $1000 less and performs 5-15% better than the competition in most workloads I am going to throw at it...if it is costing me $200-300 more in electric per year, plus upping my HVAC costs to cool that rack (probably by $100-200 a year) and my density is lower because of all the extra heat...that is going to make me think more than just twice about implementing it.
__________________
Core 2 Duo E7500, MSI P43-C51, 2x2GB G.Skill Eco DDR3 1600 Cas 7, OCZ Vertex 60GB, Vertex 30GB, Samsung F3 500GB, Samsung F4 2TB, Powercolor Go Green ATI 5570
azazel1024 is offline   Reply With Quote
Old 24th Oct 2011, 17:24   #13
Action_Parsnip
Hypermodder
Action_Parsnip's Avatar
Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!Action_Parsnip - it's over 9000!!!!!!!!1!1!1!!!
New Stepping? ........Well, duh!
A new stepping was always gonna come. Most likely within 3 months of launch, which is as soon as is reasonably possible.
Piledriver is far more worth waiting for however.
__________________
"Ooh he card read good!"
Q6700@3.475ghz 9x386mhz, Asus P5-B Deluxe WIFI-AP, 2x2gb Kingston 1066 @965mhz 5-5-5-15, western Digital Caviar Black 1tb HDD, Titan Fenrir, PC Power&Cooling 750w, XFX 4890
Action_Parsnip is offline   Reply With Quote
Old 24th Oct 2011, 19:23   #14
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.
Waiting on Bulldozer B4 stepping, codename Garbageshovel.
__________________
The Box:i7 2700K@5.3GHz|EK Supreme LT+Coolstream XT 360|16GB HyperX DDR3@1866MHz|EVGA GTX780 ti+EK FC780ti|MSI P67A-GD55||M5 512|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Perixx MX2000 + Intuos 4M
Audio: PC->TosLink->TEAC UD-501->Fostex TH600|InEar LivePro 3|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Old 24th Oct 2011, 20:41   #15
kzinti1
Multimodder
kzinti1's Avatar
kzinti1 has yet to learn the way of the Dremel
From the 14 posts I've read here, what everybody is actually saying is, AMD needs to design and build a new cpu. Bulldozer is nothing but Bullcrap.
I am honestly disappointed in AMD. Intel needs some serious competition so they don't begin to slack off.
I'm still no fanboy of Intel or AMD. Or AMD/ATI and Nvidia gpu's for that matter. I just want the best I can afford. It appears that I'll be sticking with Intel/Nvidia for quite a long time to come.
A damned shame. I like saving money, too. Unfortunately, buying into AMD/ATI is just a complete waste of money, and even worse, our valuable, irreplaceable time.
kzinti1 is offline   Reply With Quote
Old 24th Oct 2011, 20:53   #16
Tangster
Tangster's Avatar
I like AMD graphics cards a lot. Unfortunately I use CUDA a lot and until OCL is mature enough to replace it I'll be unlikely to switch over.
__________________
BT Feedback
Old 24th Oct 2011, 21:01   #17
Marvin-HHGTTG
CTRL + SHIFT + ESC
Woah, AMD GPUs are great, don't bundle them together. If you want a competent multi-monitor, or high res single monitor system, 6950 2GB Crossfire is unmatched by anything Nvidia has for the same money. Also, with 6870s at ~120-130 now, with near GTX560 Ti levels of performance, that's a ton of bang for buck right there.
The only market Nvidia has nailed right now is the absolute maximum performance required market, as 3/4 GTX580s will be faster than 3/4 6970s, which is hardly a large market.
/off topic
I really hoped Bulldozer was going to be good, as I much prefer AMD's platforms (not the half-assed no USB3/limited SATAIII move of Intel, not to mention better chipset PCI-E lane support for multi-cards, not x8/x8 max without an additional chip), but the lack of refinement kills it for me.
Old 24th Oct 2011, 21:43   #18
technogiant
Supermodder
AMDs gpu's are great.....trouble is if the AMD ship sinks because of this bulldozer debacle then it will all go down together......no more competition in both cpu and gpu arenas.......very bad day for computing indeed.
Old 24th Oct 2011, 21:57   #19
KayinBlack
Toxophile
KayinBlack's Avatar
KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.
AMD will not sink on this one. For one, in the server realm (which is actually where BD was aimed) it's being used in supercomputers by all major companies, companies who had silicon from BD and SB-E early and chose BD. Just because Win7 doesn't have any optimizations for its new code path (though Win8 is showing some surprising ones) doesn't mean it's a dead duck, especially as the desktop is an afterthought.
I really wish people would look at where AMD is actually making their money on this one and realize they're fine.
KayinBlack is offline   Reply With Quote
Old 24th Oct 2011, 22:25   #20
Senilex
Not a Troll. Honest.
Senilex's Avatar
Senilex has yet to learn the way of the Dremel
this.
Senilex is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
