#302 |
Tetrep
#303 |
Pump Killer
I decided it was about time to take your dirty dirty minds away from the pump.
![]() I've been thinking about a design for rad-grills for a while, and the final design is done. I was not really sure wether it would hold up in the mill without any support structure to clamp it down on the whole surface, but I decided to give it a go today. I started with the 120mm grill, as it was the easiest/fastest to mill! It turned out to work fine, and all my fears were put to shame! ![]() On with it: The first milling: ![]() Gone through were it's supposed to: ![]() Milling done: ![]() And the leftover pieces taken out: ![]() Looks might deceive as the ripples are not the plexi but the protective film. I'll keep that on until I'm done milling the outline! ![]() C ya soon guys!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nomineeWII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
#304 |
Squid
Love the DNA design on that grill... Asymmetry in grills are not very common. I´m diggin!!
#305 |
Making You Feel Old Since 2010
That's awesome, so very original, and, erm, sciencey.
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - D-Link 320 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#306 | |
Pump Killer
I know it's not really common like that which is why I'm extra happy that it came out like that! ![]() Damn I love you for that sciencey remark!
__________________
#307 |
Multimodder
The DNA helix looks cool for the fan grill, although that's only one of a dozen of your ideas that I am enjoying.
But your comment to the "sciencey" remark triggered me to think about your earlier teaser. Something just triggered me to think about the DNA model. You don't have to answer if you prefer to keep me in suspense, but will the gear project in the earlier pages drive a rotating double helix for this mod?
#308 | |
Pump Killer
Always nice do give people something they want to look at! ![]() That's an easy answer; Nope. The gear won't be used for anything as insane as that!
__________________
#309 |
Professional Sleever & Modder
That grill is very nicely done
#310 |
Hypermodder
That really does look cool. You are starting to make me want a mill (not that I'm going to be able to get one).
__________________
Previous Project: Zenith Antique Radio Scratch Build Current project: Project Quintessence |
#311 |
Tetrep
Looks nice & look forward to seeing it without the protective backing.
#312 |
has finished Blue Horizon
Love the design of the grill, is it gonna be lit up?
#313 | ||
Pump Killer
Thanks man!
![]() Quote:
![]() Thanks! Yup, I've hired a very small person to sit with a lamp and point the light on it 24/7! ![]() Yeah, I'll light the 120mm with red smd's and the 240 with blue smd's!
__________________
#314 |
Pump Killer
Since today is my birthday, I had nothing better to do than stay a couple of hours extra at work to get a couple of little things done, and also to mill the 240mm radgrill.
![]() I was actually going to finish up the 120mm while the other was in the cnc, but forgot the fact that I use the small plane in the cnc while I need it to do the other! ![]() So none of them are finished yet, but they will be tuesday the latest! ![]() On with the show! Milled the 240mm DNA radgrill: ![]() ![]() ![]() ![]() The left-overs. Had you asked me to mill these, I'd have said "no way" ![]() ![]() Finally I decided how/where the rads would be mounted in the case. Blue 240 on one side, the red 120 on the other: ![]() ![]() ![]() That's it for now. Can't wait to get further on this, as it finally feels and looks like something useful!
__________________
#315 |
Shut up and Mod
If you want a more uniform glow, i would use some EL tape instead. The LED's wont disperse well enough to give a glow vs. spots of color.
__________________
Life. Liberty. The pursuit of those who oppose it.![]() Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide @furballzen |
#316 | |
Pump Killer
__________________
#317 |
Fenrir The Wolf
Looks good.
#318 |
Pump Killer
__________________
#319 |
Making a sciencey (
) grill is a great way to spend your birthday because it looks awesome!
__________________
#320 |
The modding head is firmly back on.
Looking sweeeeet. That grill design is well cool...Top modding dude..
| Tags |
| 42, it's this mod! |
| Thread Tools | |
| View Mode | |
