Reply
Thread Tools View Mode
Old 28th Oct 2012, 08:16   #1001
Angel OD
Pump Killer
Angel OD's Avatar
Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.
Reply #1000, and it's MIIIIIINE!
Thanks for all the support guys! You !!!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nominee
WII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee
Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse
http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee
The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
Angel OD is offline   Reply With Quote
Old 28th Oct 2012, 08:18   #1002
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!
Ok,then #1002 is mine.
You also .
__________________
Cosmos S Reaper L.R.E.C. Scorpio
Arya-under construction ROG Crawler-under construction
Pranja is offline   Reply With Quote
Old 28th Oct 2012, 09:32   #1003
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Wake me up when you get to #1336. The next one is miiiine.
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 28th Oct 2012, 10:53   #1004
riekmaharg2
has finished Blue Horizon
riekmaharg2's Avatar
riekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremel
Thats one mighty cool SSD , if your looking for extra brightness you could always connect a mosfet to a 5v source and connect the HDD indicator to its gate pin. That way you get full 5v on the LED's and it will still flash with HDD activity.
__________________
Scratch Builds
Silent Fiberglass PC
Completed * Blue Horizon * - 2012
riekmaharg2 is offline   Reply With Quote
Old 28th Oct 2012, 16:40   #1005
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Jeeze, man, your fingers healed up funny after that lathe accident! Awesome polish on the lenses there. I didn't notice they were in until you pointed out the freaky fingers.
Almost done? What will you do now with winter just starting?
Cheapskate is offline   Reply With Quote
Old 28th Oct 2012, 19:18   #1006
siliconfanatic
Car lover and Speed Junkie
siliconfanatic's Avatar
siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.
__________________
Originally Posted by quizz_kid View Post
Blackalize it!
I *am* the guy who loves too many threads to bump them all.
siliconfanatic is offline   Reply With Quote
Old 28th Oct 2012, 19:43   #1007
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
I agree with the spartan warrior transported through time to be a presenter.
Waynio is offline   Reply With Quote
Old 28th Oct 2012, 21:13   #1008
ZWong
What's a Dremel?
ZWong has yet to learn the way of the Dremel
Incredible work! I need one of those mills...
ZWong is offline   Reply With Quote
Old 28th Oct 2012, 22:20   #1009
Magmatwister
Minimodder
Magmatwister has yet to learn the way of the Dremel
Really awesome stuff. Kinda wish I could afford to do a water cooling loop or two though. Ah well, will have to wait. Also, I can appreciate the skill and workmanship that went into this!
Magmatwister is offline   Reply With Quote
Old 29th Oct 2012, 15:27   #1010
GLA-58
Minimodder
GLA-58's Avatar
GLA-58 has yet to learn the way of the DremelGLA-58 has yet to learn the way of the Dremel
No end of line , please ?!?!
Me wants more
GLA-58 is offline   Reply With Quote
Old 29th Oct 2012, 18:01   #1011
Angel OD
Pump Killer
Angel OD's Avatar
You also .
Thanks!
Probably not gonna happen, and no you're not!
They are actually pretty good as they are. And since it seems they are around 2v, it is actually spot on as it is!
But thanks for the advice!
Freaky fingers! That's me!
I think I will be going to Disney Laaaaaaaand!
Nah, to be honest I have no idea what to tackle next. Right now I just feel like getting this done, and enjoy not lying awake in bed contemplating my next move!
Originally Posted by siliconfanatic View Post
EPIC! Thanks man!
I shall take the compliment!
Buy one, problem solved!
Thanks man!
Someday amigo... Someday you too shall feel the grasp of the water cooling beast!
Thanks a lot man!
Me wants more
I've given you another year of my life... WHAT MORE DO YOU WANT FROM ME!?
Thanks a lot man!
Since history has a funny way of repeating itself, I find it very unlikely that I'm not gonna show up with something else in here!
__________________
Old 29th Oct 2012, 18:29   #1012
avolla
Hackintosher
avolla's Avatar
avolla has yet to learn the way of the Dremel
That'll go down as the coolest SSD mod I've ever seen. Absolutely amazing.
avolla is offline   Reply With Quote
Old 31st Oct 2012, 13:14   #1013
riekmaharg2
Yeah +1 on that
__________________
Scratch Builds
Old 4th Nov 2012, 12:30   #1014
Mechh69
I think we can make that fit
Mechh69's Avatar
Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.
Great Job as always, now what are you going to change next???
__________________
Originally Posted by Deders View Post
What if you touch yourself with kittens?
I7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, BFG 260 GTX Core 216 X3, BFG 9600 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses
Mechh69 is offline   Reply With Quote
Old 16th Nov 2012, 17:37   #1015
Angel OD
Pump Killer
Angel OD's Avatar
Thanks man! I really like it myself as well!
Yeah +1 on that
Thanks a lot!
Thank you sir! To be honest, I have no idea... I still have a little idea of a pc for my kitchen, but right now I'm just gonna get this done, and relax a bit untill the mod-bug bites me again!
__________________
Old 16th Nov 2012, 17:45   #1016
Angel OD
Pump Killer
Angel OD's Avatar
You have GOT to be kidding me... Being lazy enough to NOT do 5 minutes of work earlier, has now resultet in not finishing up today...
Well, good news first. I modded an extension cable so I could use the HDMI output on the gfx for my tv:
The output plate on the pc:
After making a couple of holes for screws to mount it:
All that was left at this point, was to put the plug in the gfx and the mod was done... But as my hand grabbed the plug, my brain interferred... "Don't tell me you decided NOT to make the hole bigger in the backplate for the GFX, when you went from a 9800 GTX with s-video out, to the 580 gtx with the HDMI... Because we DID think about it!"
That's right.. The round hole is not big enough for the mini HDMI...
So now my options are to take the whole thing apart and mill it out, or find a DVI to HDMI female cable... Pretty sure ebay is my next move!
I'll check back with you guys soon!
__________________
Old 16th Nov 2012, 17:50   #1017
sixfootsideburns
modeteer
sixfootsideburns has yet to learn the way of the Dremelsixfootsideburns has yet to learn the way of the Dremel
Angel I'm ashamed of you... don't half ass if when your this close! Take it apart and do it right man, you owe it to yourself and to us.
tisk tisk...
And yes... I did just lecture an amazing modder such as yourself
sixfootsideburns is offline   Reply With Quote
Old 22nd Nov 2012, 12:51   #1018
Angel OD
Pump Killer
Angel OD's Avatar
tisk tisk...
I hate you... A little!
I decided that since I'm a celebrity, I have to set a good example...
Well, I took sixfootsideburns advice. Took out the gfx card:
See the problem?
Problem gone:
Sorry for the quality of the cut, I only had a saw and a huge file at home..
IT WORKED! :
Soo... I guess that's it for this build...
I'll try to see if I can find a camera and some time to take some final pics during the next week.
Thanks for all your help and comments! And also for not bit**ing during my not-so-productive periods!
__________________
Old 22nd Nov 2012, 13:14   #1019
Pranja
Fenrir The Wolf
Pranja's Avatar
Yay!
Finished.
__________________
Old 22nd Nov 2012, 13:46   #1020
siliconfanatic
o.... m... god! the era of awsome acrylic and custom acrylic everything is over! lets hope this horrid absence will be short... best stack up the funds and get the mod bug back bad... ima just startin to feel tha itch to saw a hole in the side of my case and get anoverkill air cooler
__________________
Blackalize it!
Reply
Tags
42, it's this mod!
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
