Reply
Thread Tools View Mode
Old 1st Dec 2011, 17:41   #101
Angel OD
Pump Killer
Angel OD's Avatar
Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.
Originally Posted by bulldogjeff View Post
That blocks just to much, looks brilliant, possibly the nicest I've ever seen.
Thanks a lot! Much appreciated kind words sir!
Originally Posted by Achron View Post
Make a baffle out of smoked plexi.
Great minds think alike! I just wish I was one of them!
I think I'm gonna have to take a look at what I can find in the scrap pile at work... I just need it to be the right thickness... I'll get back to you on that tomorrow!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nominee
WII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee
Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse
http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee
The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
Angel OD is offline   Reply With Quote
Old 1st Dec 2011, 18:02   #102
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
Originally Posted by Angel OD View Post
Well, I use a hose with a 6mm inner diameter. And I can get the fittings in both 1/4" and 1/8"... The bore is 5mm on both fittings!
1/4, have bigger diameter than 1/8 its a big difference :S?
KoSoVaR^ is offline   Reply With Quote
Old 1st Dec 2011, 18:35   #103
Angel OD
Pump Killer
Angel OD's Avatar
Depends on the hole inside!
__________________
Old 1st Dec 2011, 18:47   #104
KoSoVaR^
KoSoVaR^'s Avatar
ahaa you mean the inner diameter ?
Old 1st Dec 2011, 19:53   #105
Angel OD
Pump Killer
Angel OD's Avatar
Ja fan!
The ones I use for the 6/8mm hose, I can get with 1/4" or 1/8" thread. But they both have a 5mm hole in them!
__________________
Old 1st Dec 2011, 20:04   #106
p0Pe
gief cake?
p0Pe's Avatar
p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!
Haha I am so glad you changed that top Missed the last update, and when I just went trough the recent updates I saw the "toe" block and instantly thought of:
__________________
p0Pe is offline   Reply With Quote
Old 1st Dec 2011, 20:12   #107
Angel OD
Pump Killer
Angel OD's Avatar
YAY!
But no, you may not!
__________________
Old 2nd Dec 2011, 14:12   #108
Angel OD
Pump Killer
Angel OD's Avatar
Unfortunately I didn't have the time to make a new insert in smoked plexi. I didn't even get around to see if I could find any...
But I DID get around to another thing.
I've been fiddling with the thought of the fittings for a while.
In all honesty I am aware that the standard fittings I use aren't the prettiest ones. But they cost around 1/7 of the bitspower fittings!
I was looking around for some stanless tube to cover them up, but that's gonna be expensive as well. I was thinking about making the from scratch, but again it's a good amount of money to start them up. I could probably sell some, but I want my own stuff!
So I went with the easy and quick sollution.
This is the standard boring one:
So... I threw it in the lathe and turned just enough off it so it was round all the way. Then I used the tool that gives the surface that "non slip" surface. (Dunno what it's called in english! )
Gonna have to make a tool to set them up on when I turn the whole lot after I order them, but you get the idea.
Then I painted it black, and voila!
The color can be whatever, depending on what I want.
IF I was to make the from scratch, I would have made them bulgier, but I think the result is quite good!
Hope you like it!
That's it for now, catch you on the flipside!
__________________
Old 2nd Dec 2011, 15:56   #109
Throbbi
I Mod, Therefore I Own
Throbbi's Avatar
Throbbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpit
It's a Diamond Knurler
__________________
Steam - Throbbi ::WoT -Unpainted_Target ::BF3 - Throbbi
Phenom IIX4 B60 (core unlockedX2 560 @ 3.9ghz) - 2x4GB 1333DDR3 - 1.8TB Storage - XFX GTX260 kindly loaned by Lancer778544! rep him! Relix commands you! (he does, honest, told me yesterday)
::The rig made possible ONLY by this great community!
Share And Enjoy!
Throbbi is online now   Reply With Quote
Old 2nd Dec 2011, 16:32   #110
p0Pe
gief cake?
p0Pe's Avatar
Cool I like it! Clever work there mate
__________________
Old 2nd Dec 2011, 17:35   #111
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
What he said
AnG3L is offline   Reply With Quote
Old 2nd Dec 2011, 19:10   #112
Angel OD
Pump Killer
Angel OD's Avatar
Thx! Not only is it useful, it also has a cool name!
Thank you my kindred danish spirit!
Originally Posted by AnG3L View Post
What he said
And thanks also to you, my far away buddy!
__________________
Old 6th Dec 2011, 08:24   #113
SunkiiSh
Minimodder
SunkiiSh has yet to learn the way of the Dremel
Just read your worklog, I really like the custom WB! I'll be checking out this mod for sure!
+Subscribed!
+5!
Case mod in progress: Black&White (N' some blue)
SunkiiSh is offline   Reply With Quote
Old 6th Dec 2011, 13:16   #114
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Oh awesome transformation of plain old nuts, pretty simple tweak I guess but increases the niceness hugely +rep.
DIY BP fittings .
Waynio is offline   Reply With Quote
Old 6th Dec 2011, 13:36   #115
Paslis
Supermodder
Paslis's Avatar
Paslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run Crysis
Nice 1 dude simple move and it looks great with the cpu block.
Paslis is offline   Reply With Quote
Old 6th Dec 2011, 16:41   #116
RedManc
Supermodder
RedManc's Avatar
RedManc has yet to learn the way of the DremelRedManc has yet to learn the way of the Dremel
seriously... custom fittings now!!
get a life :P oh wait no don't!! keep on modding the block and fittings look superb!
__________________
RedManc is offline   Reply With Quote
Old 6th Dec 2011, 16:43   #117
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
You know, when I read that someone knurled their nuts round, I would think that would be bad...
@Renmanc - He has a life. Fortunately, he doesn't let it get in the way of entertaining us.
Cheapskate is offline   Reply With Quote
Old 7th Dec 2011, 19:01   #118
Angel OD
Pump Killer
Angel OD's Avatar
+Subscribed!
+5!
Thanks man!
DIY BP fittings .
Thanks! I was going for something like that! As I mentioned, they are not as bulky as BP fittings, but I'll see how it looks in the final build. If I don't like it, I'll make some other top-pieces to fatten them up!
Thank you!
Nah... Modded fittings, not custom! And thanks a lot!
I would have expected nothing less from you!
I don't know if modding my GF's pc is called having a life... But I'm cool with it, you guys like it and the GF's gonna love the mod. Can't beat that though!
I've got designers block right now! I made several designs for HDD mounts, but I just can't get my head around the final version. It's somewhat put on hold until I get the Case. All the drawing in the world can't make up for having the product in front of you!
So blame Dennis Publishing for the slow progress atm!
__________________
Old 12th Dec 2011, 18:42   #119
coolamasta
Folding@Home CC Captain 2010/11/12
coolamasta's Avatar
coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.coolamasta is a hoopy frood who really knows where their towel is.
You are the milling machine MAN! Both stunning blocks but the CPU block is a work of art, respect where it is due!
__________________
My Main Rigs:~ H2O'd i7 3770K @ 4.5 - 16GB - H2O'd GTX 670 | Asus Z9PE-W8, EP-Xeon 2670 @ 3.2 - 16GB
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ |
coolamasta is offline   Reply With Quote
Old 13th Dec 2011, 08:06   #120
Angel OD
Pump Killer
Angel OD's Avatar
Thx a lot man! Always nice to hear that others like what I do!
Still awaiting the arrival of my case, so I can get on with the show! And I just bought a butt-load of leds for this, so that should be sorted for now!
__________________
Reply
Tags
42, it's this mod!
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
