Reply
Thread Tools View Mode
Old 8th Nov 2011, 23:24   #41
jrs77
theorycrafting
jrs77's Avatar
jrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for president
Originally Posted by Zesti View Post
Thanks nagyizom and jrs77.
jrs77, I got a piece of 5mm aluminum just laying in the garage for a few years. Originally I got it free from a friend to use in my combot. It ended up being too thin for a modern combot and was hence left to dust.
Rautasoini in Hervanta has sometimes good pieces of scrap aluminum, but it's really a question of luck.. Most of the time their aluminum is useless (cheese-quality, wrong sized pieces and so on).
Thanks for the info, I've bought my aluminum at Mansen Levytyö so far which is aswell in Hervanta, as they're cutting and bending smaller things on the go. A little bit more expensive tho I guess.
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB]
jrs77 is offline   Reply With Quote
Old 10th Nov 2011, 16:35   #42
Zesti
Multimodder
Zesti's Avatar
Zesti has yet to learn the way of the DremelZesti has yet to learn the way of the DremelZesti has yet to learn the way of the Dremel
Time for a smallish update.
Started to build IO-panel.. PSU mount first.
I'll cut motherboard and graphic card openings later when this part is mounted into the mobotray.
__________________
Current system: ZOE
Current project: Eterne - MOTM November '12 Nominee!
Zesti is offline   Reply With Quote
Old 10th Nov 2011, 17:39   #43
Razer2007
Building Proxima
Razer2007's Avatar
Razer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the Dremel
Wow what a beautiful cutout! what finish is that? It doesn't look just like raw aluminium.
I also love the photos. +rep for everything
__________________
Razer2007 is offline   Reply With Quote
Old 10th Nov 2011, 18:20   #44
Archer
Talga Vassternich - Deserve Victory
Archer's Avatar
Archer has yet to learn the way of the DremelArcher has yet to learn the way of the Dremel
Some very nice metalwork going on in here
Originally Posted by Razer2007 View Post
Edit: How about some sweet stainless steel countersunk screws?
Aluminium + stainless steel = galvanic corrosion, not a good idea.
__________________
Planning: Multi Hex MKII
Complete: Project Multi Hex
Archer is offline   Reply With Quote
Old 10th Nov 2011, 18:28   #45
Razer2007
Building Proxima
Razer2007's Avatar
Oh. :\ but SS is an Alloy isn't it? Still corrosion?
__________________
Old 10th Nov 2011, 18:31   #46
Zesti
Multimodder
Zesti's Avatar
Thanks guys.
Aluminum is anodized.. I ordered normal aluminum sheets, but they came with anodized surface. I'm not complaining about that. It's really a shame to ruin nice surface finish with cutting and painting..
Screws will be countersunk and changed to more classier, but they also won't be visible when I finish.
__________________
Current system: ZOE
Old 19th Nov 2011, 17:34   #47
Zesti
Multimodder
Zesti's Avatar
Sorry for the lack of updates, I've been really busy lately.
But anyway, I got some work done. Motherboard tray is rough cut, made some slots to attach it and IO-panel together. Also cut some L-profile for mounting.
Quick picture of the progress (with Tape Mounting ™):
I'll write a proper update at some point with more pictures.. Too tired to do that now.
__________________
Current system: ZOE
Old 19th Nov 2011, 17:51   #48
Achron
Cad Pro Quo
Achron's Avatar
Achron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the Dremel
Unless I'm not reading the back-story for this part...which I may not be...but galvanic corrosion really needs some sort of conductor between the two materials to take off.
"Galvanic corrosion is an electrochemical process in which one metal corrodes preferentially to another when both metals are in electrical contact and immersed in an electrolyte."
Air is not a good electrolyte.
__________________
Completed: Acronym
Achron is offline   Reply With Quote
Old 19th Nov 2011, 19:01   #49
Razer2007
Building Proxima
Razer2007's Avatar
Thanks!! I were getting worried! +rep
__________________
Old 20th Nov 2011, 15:51   #50
JA12
Minimodder
JA12 has yet to learn the way of the Dremel
A bit strange. Are you sure they were anodized and not just nice pieces?
I'm asking because aluminum grows a thin natural oxide layer when exposed to air and anodizing is just an electrochemical process to grow that oxide layer thick. If you want some other surface finish then that might need extra steps to remove the oxide layer. That could be a real PITA if you're removing it yourself and it's a large or oddly shaped part.
Do you need to remove anodizing before painting and have you considered re-anodizing with color?
JA12 is offline   Reply With Quote
Old 20th Nov 2011, 17:22   #51
Archer
Archer's Avatar
Unless there is water in the air, like when someone lives near an ocean, like Razer does? Which makes things worse since its salt water, meaning the water is an even better electrolye.
__________________
Old 20th Nov 2011, 18:02   #52
Razer2007
Building Proxima
Razer2007's Avatar
gaaa great I got stainless screws in prox, and it will be anodized alu. What will happen/what do I do?
__________________
Old 20th Nov 2011, 21:49   #53
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
give us more pics!
KoSoVaR^ is offline   Reply With Quote
Old 21st Nov 2011, 19:31   #54
Zesti
Multimodder
Zesti's Avatar
More pictures you say?
Well, here's some.
Those pictures might need some explaining (?). IO-panel is on top of the case, PSU is in the front and window will be 'left-handed'. So this design has 90° rotated motherboard just like SS Raven 2 etc. - or in fact I'd prefer to call it 95° micro-ATX.
Until next time.
__________________
Current system: ZOE
Old 22nd Nov 2011, 07:45   #55
Achron
Cad Pro Quo
Achron's Avatar
OK I hate to hijack, but this needs to be straightened out. A little chemistry lesson, shall we:
Galvanic corrosion happens, as said before, when there is a difference in the electrochemical potential between two materials within the presence of an electrolyte (something that contains free ions, which can conduct electricity easily). The greater this potential, the higher the voltage, thus more corrosion.
Here (http://hyperphysics.phy-astr.gsu.edu.../electpot.html) is a table of electrochemical potentials. See aluminum near the top? -1.66V. Where's copper? Down towards the bottom, at 0.34V. This is why copper + aluminum + electrolyte = bad news for the aluminum.
Now take a look at iron and chromium (the main elements in stainless steel). Chromium is at -0.74V, whereas iron is at -0.41V (or -0.04V). Much less disparity than with the copper.
For all intents and purposes, if you're worried about corrosion between stainless and aluminum in a computer (that isn't watercooled); don't be. It will take years to begin to corrode, even more so with anodized aluminum. Not to mention that screws have a very small surface area to begin with, further limiting the ability to corrode.
Hope that helps.
__________________
Completed: Acronym
Old 22nd Nov 2011, 11:49   #56
Razer2007
Building Proxima
Razer2007's Avatar
Thank you very much! Rep rain on your house. We are buys what oxidation/reduction in chemistry at school, but not so complex yet that we work with different electrolytes.
__________________
Old 26th Nov 2011, 12:08   #57
Zesti
Multimodder
Zesti's Avatar
Hi guys.
Today I sanded most of the parts.. Example:
Gah, can't really see anything. Reminds me that I'd have to buy a macro lense. But I'd call surface finish smooth.
Then I took one meter long 15x15x1mm aluminum L-profile and cut a bit off it for bending. The bending itself went pretty easily:
I'm also happy how L-profile ends go together with other parts.
More bending.. And the sun is also starting to go down. Days are way too short when winter is coming..
And then we were ready to do some gluing. I used quite strong glue that can hold 18kg / cm^2.. Should be plenty for a computer case.
And now I can just wait - it will take full 24 hours to cure completely.
Oh, and I ordered CPU cooler - Antec H2O Kühler 620. Got it for a pretty good price and I've been happy with it in my last build. But this time I'm thinking some modifications for it..
__________________
Current system: ZOE
Old 26th Nov 2011, 12:22   #58
Razer2007
Building Proxima
Razer2007's Avatar
That's a nice idea! * remembering it for future reference*
__________________
Old 26th Nov 2011, 16:05   #59
KoSoVaR^
KoSoVaR^'s Avatar
Thats a good idea, what type of glue is that ? 2K epoxy ?
Old 26th Nov 2011, 20:56   #60
yassarikhan786
Ultramodder(Not)
yassarikhan786's Avatar
yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.
I agree. A very good idea .
__________________
|| Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: Gigabyte GTX 580 Super OC || Memory: Mushkin Blackline 8GB || SSD: Corsair Force 3 120GB || HDD: WD Caviar Black 2TB || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v || Keyboard: Logitech G510 || Mouse: Razer DeathAdder
yassarikhan786 is offline   Reply With Quote
Reply
Tags
cheesecake photography
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
