Thread Tools | View Mode |
#81 |
Hypermodder
I replaced the fan and it doesn't spin up, I'm using a PSU testing tool and nothing is lighting up on it. All the crimps are good, I checked them before I sleeved them, all making good contact with the wire and crimped well on the insulation. I have no idea whats going on. There was a slight electrical ticking sound earlier but nothing now.
__________________
Pexon PCs Pexon @ GH Steel Series 6G v2 w/ MX Black / Noppoo Choc Mini w/ MX Blues / Happy Hacking Keyboard Pro 2 Anthracite |
#82 |
'Black Noise'
If the PSU Tester isn't working it does suggest (from my limited knowledge of all the mistakes I've made) that it's the PS On signal. Only thing I can think of is to open up the PSU again and make sure that none of the cables have detached from the circuit board, particularly Pin 16 and if possible check that you've actually got the right cable for pin 16 correctly located in the housing.
I don't know if a PSU Tester checks the voltage on every power supplying cable or just specific ones. Although I've got one and use it for a quick check I now use a multimeter to check the voltage on each of the power cables just to be sure that I'm not going to put 12V through a 5V connector. Also check the fuse in the power lead. |
#83 |
Hypermodder
Thanks for your help mate. I've tried it with several power leads and no good with any of them. Will check all the cables are true inside the PSU tomorrow.
__________________
#84 |
Professional Sleever & Modder
I think that you might have done something wronth with the pinout when putting the cables back in...
HAve you tried to jumpstart the PSU ? Pin nr 16 and ground ? |
#85 |
Hypermodder
yep, done all that, it did'nt work either.
__________________
#86 |
Hypermodder
My new PSU arrived today, so I've got started on that. Obviously, I've got limited sleeve left, so I'm going to have to make do with sleeving a portion with SATA sleeve on the 12v ATX and PCI-E 6+2 and the rest individually sleeved.
![]() One end... ![]() T'uther end
__________________
#87 |
Making You Feel Old Since 2010
Nice job with a limited amount!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#88 |
'Black Noise'
Can't you re-use the sleeving from the old PSU?
#89 |
Hypermodder
Thanks very much mate, much appreciated! Its nice I got some feedback on this project!
![]() Yup, thats what I'm doing, but obviously, I need to chop the ends off, trim them down, melt the ends etc, so I do loose a fair amount, hence having to have a portion of the the wires group sleeved and individually sleeved. They will be out of sight behind the motherboard tray so they wont look too ghastly.
__________________
#90 |
Admit one thing, it seems that you have melt the tops of the sleeve right onto the pin...is that right ?
#91 |
Hypermodder
Yea mate, have you been reading OC3D?
__________________
#92 |
Hypermodder
I had a spare bit of ally, left over after cutting the window out, I started measuring up a blanking panel for the front, where the 5 1/4" drive pay covers normally sit.
![]() ![]() I also wolloped a few holes in the floor, for the intake for the 240mm rads. Fingers crossed, I can get a pair of 140mm fans in the front too, to help get a bit more air into the case, as 2x 120's in the floor, exhausting hot air from the rads, won't be too beneficial. ![]() I'm just not sure how to mount the rads, either on the floor or fans on the floor of the case. Like... ![]() OR....... ![]() As always, cheers for looking.
__________________
#93 |
Hypermodder
Just got the modular 24 pin and 24 pin extensions finished!
I think they look pretty good. ![]()
__________________
#94 |
Hypermodder
Was thinking something like this for the top fan grill? What do you reckon?
__________________
#95 |
Supermodder
I prefer push vs pull but do you have enough room to do both?
The grill looks nice and clean! |
#96 | |
Hypermodder
__________________
#97 |
Hypermodder
Got some primer on, 2 coats actually, wet sanded and ready for spraying, fingers crossed tomorrow is dry I can get the first coat on!
I forgot to upload these pics from last wekk. D'oh!![]()
__________________
#98 |
Ultramodder(Not)
Hello Mr Shrop, I've not been here for a while, but the primer looks good
You better update us sooner or else I'm coming for you.
__________________
|| Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: Gigabyte GTX 580 Super OC || Memory: Mushkin Blackline 8GB || SSD: Corsair Force 3 120GB || HDD: WD Caviar Black 2TB || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v || Keyboard: Logitech G510 || Mouse: Razer DeathAdder |
#99 |
Hypermodder
Just a little updat with some acrylic I've been cutting for some blanking panels. First up, the side of the 5 1/4" drive bay looks a tad messy, just due to the mount holes etc, and as I'm only using a single bay for the fan controller and perhaps a DVD drive, I can cover them up and use the mouting system from the other side, the side you can see!
![]() ![]() ![]() I had a little idea with the front bezel cover. I'm thinking about getting the project name engraved on a piece of acrylic, see below. I can paint the acrylic to match the cover of the case and have a plain, clear piece of acrylic behind it and a strip of LED's to light up the engraved text, I think if I do it subtly the effect will look pretty nice, I've just got to see how much engraving will be, hopefully its not silly money, or if someone on here can do it hit me up! ![]() This is the clear part, I can use some 3M mounting tape, as with the 5 1/4" bay shroud as you wont see it from inside the case. ![]() I also needed to make a blanking plate for the top, the case comes with a PSU mounting plate and a grill cover, but I think it looks a bit poo, so I made a solid infill panel. ![]() ![]() ![]() ![]() As always thanks for looking, any comments appreciated. Cheers!
__________________
#100 |
long live the pc
looking good mate keep up the good work
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl, ![]() |
| Tags |
| 3m di-noc, lian-li, pc a70f, water cool |
| Thread Tools | |
| View Mode | |
