Reply
Thread Tools View Mode
Old 15th May 2012, 14:50   #161
yassarikhan786
Ultramodder(Not)
yassarikhan786's Avatar
yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.
Nice one man
__________________
|| Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: Gigabyte GTX 580 Super OC || Memory: Mushkin Blackline 8GB || SSD: Corsair Force 3 120GB || HDD: WD Caviar Black 2TB || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v || Keyboard: Logitech G510 || Mouse: Razer DeathAdder
yassarikhan786 is offline   Reply With Quote
Old 16th May 2012, 21:14   #162
shrop
Hypermodder
shrop's Avatar
shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.shrop is a hoopy frood who really knows where their towel is.
Resleeved the pump as it was annoying me, you could see some of the yellow wire through the sleeve. I could have left it but it was niggling me.
I also sorted out the 24 pin extension as it was also looking a bit rough round the edges. Again it was annoying me, I could have left it, but that's not like me.
Finally, I got an Alphacool pump top from Specialtech, it really finishes the pump off nicely, the stock D5 isn't exactly a beaut. I've also been wondering, does anyone know if some 3M double sided mounting tape would be sound for mounting the pump?
Hopefully I should get my new CPU by friday too! So its looking exciting, fingers crossed new GPU next month as well as the last rad, 2 more fans and blocks!
__________________
Pexon PCs
Pexon @ GH
Steel Series 6G v2 w/ MX Black / Noppoo Choc Mini w/ MX Blues / Happy Hacking Keyboard Pro 2 Anthracite
shrop is offline   Reply With Quote
Old 17th May 2012, 03:54   #163
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
Come on Come on Come on ! You are nearly done with it
KoSoVaR^ is offline   Reply With Quote
Old 17th May 2012, 04:39   #164
KayinBlack
I Endure
KayinBlack's Avatar
KayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for president
I've used 3M double sided tape to mount pumps in the past. Not the best vibration dampener, but they sure stay put.
KayinBlack is offline   Reply With Quote
Old 17th May 2012, 10:51   #165
shrop
Hypermodder
shrop's Avatar
OK, thanks man, I think I'll give it a miss.
I know its nearly there!
__________________
Pexon PCs
Pexon @ GH
Old 17th May 2012, 15:42   #166
shrop
Hypermodder
shrop's Avatar
3820 and a CPU cooler to get me running for a few weeks have been ordered and should be here tomorrow. Cant wait!!!!!
__________________
Pexon PCs
Pexon @ GH
Old 17th May 2012, 21:09   #167
shrop
Hypermodder
shrop's Avatar
Little update here... Had a play around with some screws and some spacers to help airflow and noise. Here is how it looks.
The only thing I'm worried about is getting a card with a longish PCB, due to the pump, which will sit underneath the res. I may have to run the GPU in the second PCI 16x slot. Fingers crossed another big update tomorrow with the i7 2011.
__________________
Pexon PCs
Pexon @ GH
Old 18th May 2012, 09:03   #168
yassarikhan786
Ultramodder(Not)
Rad placement looks rad. C whut I did thur XD?
__________________
Old 18th May 2012, 11:35   #169
shrop
Hypermodder
shrop's Avatar
__________________
Pexon PCs
Pexon @ GH
Old 18th May 2012, 16:01   #170
shrop
Hypermodder
shrop's Avatar
Little video of the rad sandwich... just to test how loud the fans are, I'm pretty happy with the result, even at full whack, the Enermax Clusters don't get too loud. When at their lowest speed, when I'd turn them down when idle, they are nearly in-audible, but still throw out a decent amount of air.
__________________
Pexon PCs
Pexon @ GH
Old 18th May 2012, 20:15   #171
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.
Silly question time. With the fitting facing each other how are you planning on connecting it all up.
bulldogjeff is offline   Reply With Quote
Old 18th May 2012, 20:47   #172
shrop
Hypermodder
shrop's Avatar
Ive turned it over now. Ill have to have a play with some 90s to get the tubing ran nicely.
__________________
Pexon PCs
Pexon @ GH
Old 18th May 2012, 21:07   #173
bulldogjeff
Ah, now that akes a lot more sense now . You havd me worried for a while then..lol
Old 18th May 2012, 21:29   #174
shrop
Hypermodder
shrop's Avatar
I could have fitted a single length of 2 inch ish tubing in betweem the two barbs to connect them and worked some magic with some 90s for the input from the pump and outlet to GPU block mind.
__________________
Pexon PCs
Pexon @ GH
Old 20th May 2012, 20:12   #175
shrop
Hypermodder
shrop's Avatar
Boom! Got my 2011 kit up and running after a Windows 7 install nightmare...
And a temporary cooler....
All ready to go for w/cing! Bad news though...
__________________
Pexon PCs
Pexon @ GH
Old 21st May 2012, 17:53   #176
shrop
Hypermodder
shrop's Avatar
__________________
Pexon PCs
Pexon @ GH
Old 21st May 2012, 19:39   #177
SilveR_172
Supermodder
SilveR_172 has yet to learn the way of the DremelSilveR_172 has yet to learn the way of the Dremel
Ouch going to have to respray the front , how much lacquer are you using on the panels ? and what caused the ding ? Also the C/F goes well with that Dark met Blue
SilveR_172 is offline   Reply With Quote
Old 21st May 2012, 23:53   #178
shrop
Hypermodder
shrop's Avatar
2 coats. I've T-Cut them too :/
__________________
Pexon PCs
Pexon @ GH
Old 23rd May 2012, 10:54   #179
chris8224
What's a Dremel?
chris8224 has yet to learn the way of the Dremel
Them fans are beautiful mate, also liking how its all coming together
chris8224 is offline   Reply With Quote
Old 23rd May 2012, 12:36   #180
yassarikhan786
Ultramodder(Not)
Fans look awesome playa
__________________
Reply
Tags
3m di-noc, lian-li, pc a70f, water cool
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
