#1 |
stop your grinning and drop your li
Modded Corsair H60 with reservoir - still testing
right as title suggests i have modded my h60 to include a swiftech. pretty straight forward.
temp wise im still testing/bleeding the system will update shortly
__________________
Bitfenix Prodigy / Asus p8z77-I deluxe / 2700k@5.2 / Samsung 2x4gb @ 2400mhz / Hx1050 (overkill) / Gtx570 (soon to be 690) / 2x64gb M4 / WD 3tb book / BenQ 2410t G19 / G27 / and some watercooling for good measure |
#2 |
Panda have Guns
You really do have lots of time to burn don't you! Nice work though, I'll watch this with interest.
__________________
|Fractal Design Define R3, Black Pearl (Case)|ASUS P8P67 Deluxe (Motherboard)|Intel® Core™ i5-2500K (Processor)| |G-Skill 8GB DDR3 1600mhz Sniper 1.25v (Memory)|ASUS GTX 670 / Gigabyte GTX 670 (SLI Graphics)| |Corsair Professional Series Gold AX 850W (Power Supply Unit)|Asus Xonar D2X PCI-Express (Sound Card)| |OCZ Vertex 3 120GB (Solid State Drive - Boot)|OCZ Vertex 3 240GB (Solid State Drive - Games)|
#3 |
i wish theres not enough hours in the day.
just doing some more leak testing and bleeding as i speak. i have removed it from the case to do this
__________________
#4 |
Co-Mumble Ruler!!
Hmmm looking good there dude, though I'm jelous I want a 2nd GTX 570!!
__________________
i5 2500k @ 4.5ghz | P8P67 | 8gb Corsair Vengeance 1866mhz | EVGA GTX670 SC | LGIPS231 | K/B Filco Majestouch 2 | Mouse R.A.T 3 | Phones Sennheiser HD 598
#5 |
Smiles are free-Use 'em :D
Why? :s
Whole advantage of a prebuilt sealed loop is to not have a res
__________________
Meow ![]() Quaacck on Steam/BF3/Xbox Laiiveee |
#6 | |
petrolhead
Whether the difference in quantity is large enough to produce a temp difference is yet to be seen.
__________________
Steam: Cerberus90 | Q6600 @ 3.2GHz | Asus P5K Premium | 4GiB Patriot 1000MHz | 256GB Samsung 830 | | Gigabyte GTX460 @ 830/2000 | Fractal Core 3000 | 24" BenQ G2420HD | |
#7 |
Technophile(and yes, thats 724Mb/s)
I'll be suprised if it makes any difference really.
__________________
i5 3570k @ 4.6GHz (1.28v) on custom water loop/ Watercooling how-to, Asus Maximus 5 Gene, 16GB Corsair Vengence 1600MHz (2 black, 2 red), Sapphire Radeon HD 5870, 128GB Crucial M4, 3 x Samsung F1 1TB in RAID 5, Xigmatek Elysium, Enermax Revolution 85+ 850W, Corsair K60, Corsair SP2500 speakers, Dell U2311H & Asus VK222W. |
#8 |
Undercooked chicken giver
I think its been noted in past mods it helps a few degrees
__________________
One//i5 3570K 4.5Ghz//Z68X-UD4-B3//8gb DDR3//EVGA 670 F.T.W.//HX850W//CM690ii//2x128 V200 SSD//Xonar DG// Two//i5 2500K 4.5Ghz//Assrock Z68 Gen3//8gb DDR3//MSI 7970//TX750W//Akasa Mirage//128 Vertex+ SSD//Xonar DG//
#9 |
Is it really worth it though?
__________________
#10 |
Does not play well with others.
Bit of fun, shave off a few degrees - isn't that the point of tinkering with PCs anyway?
That is not the spirit! |
#11 |
right after initial testing idle temp is down to 27c from 32c. stressed temp is 50c down from 63c. so yes it has dropped the temps a bit. but as im going fully watercooled i thought what the heck chop it up. used the original fluid that was in the corsairr loop along with distilled water. with the loop and res i estimate twice the fluid was used.
__________________
#12 |
What's a Dremel?
Would you be able to tell me which port out of the waterblock is the in port and which is the out port. I'm going to do this mod to add liquid cooling to a video card block and I'm wondering which is the input and output of the pump on the cpu block.
#13 |
Output on top mate
__________________
#14 |
Avoiding the "I guess.." since 2004
Oh wow how didn't I think of this! I drained my H100 not so long ago and been wondering how on earth do I get it filled back up again
Adding a small res should sort it, and while I'm at it some custom length hoses wouldn't hurt, either.
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2 |
#15 |
Banned
Interesting.
My res is 500mm heatsink choob from XSPC. A monster that sits vertically by window next to radiator. |
#16 |
Mr I Dont Know What I Want
Haha you've given me a crazy idea... Instead of RMA'ing my h60 make a cycling reservoir of mayham particulate fluid external to my case on my desk
just for fun haha*maybe*
__________________
i5 2500K l P8Z68-V LX l 6870 l 8GB 1600MHz l OCZ Vertex 3 l 750W OCZ Giff Gaff Monthly Sim Card - £10 a Month, 250Min, Unlimited Data and Text.
#17 |
What's a Dremel?
Can you please be more specific on which is the input and which is the output barb on the heatsink. Perhaps edit a picture showing the flow pattern. I'm going to do a ridiculously small form factor case liquid cooling mod with this unit tomorrow. I'll post some pics after I'm done.
#18 |
How do I Internet!!
Wow thats pretty cool, Jizzwizard(love the name and DP by the way) do you know whether the pump is attached to the radiator or the CPU socket?
__________________
CPU:Intel I7 930(Bloomfield) @2.80GHZ CPU Cooler:Corsair H80 MOBO:Asus P6t SE Graphics Card: Palit 670GTX 2GB OC RAM:12GB Corsair XMS3 1600mhz 9-9-9-24 PSU:Corsair HX 750W Hard Drives:50GB SSD OCZ Sandforce driver/1TB WD Green 7200RPM Case:NZXT 810 Switch Black Last edited by towelie; 10th Feb 2012 at 15:08. |
#19 | |
towlie the pump is built into the cpu block
__________________
#20 |
What's a Dremel?
Check out my completed mod. I'm going to change two things next week that being the drain port from the current barb to the matching black ones I used and the fill port I'm going to do 1/2" Barb and tube to a 1/2 to 1/4 90degree elbow.
http://smg.photobucket.com/albums/v2...quid%20Cooled/ Last edited by xboxexpert; 13th Feb 2012 at 01:17. |
| Thread Tools | |
