Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 7th Nov 2011, 11:53   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Sapphire Pure Platinum A75 Review
Sapphire's latest Socket FM1 motherboard promises great overclocking potential.
http://www.bit-tech.net/hardware/mot...ack-in-black/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 7th Nov 2011, 16:58   #2
edzieba
Virtual Realist
edzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyan
As a result, having a mini PCI-E slot could be potentially useful for fitting a small, low-profile wireless card or even a mini PCI-E SD card adaptor; if fitted with a high-capacity card, this could allow for a small Windows or Linux installation.
Or use a mini-PCI SSD that won't cause your installation to drag along at a snails pace, and less likely to suddenly die due to NAND failure (an SSD controller is built to hand that kind of workload, an SD card controller is not). After buying an adapter and a SD card from a reputable brand, the price difference won't be too great either.
edzieba is offline   Reply With Quote
Old 7th Nov 2011, 19:48   #3
docodine
killed a guy once
docodine's Avatar
docodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for president
a sapphire pure motherboard that isn't white? come on
docodine is offline   Reply With Quote
Old 7th Nov 2011, 22:11   #4
randis1981
What's a Dremel?
randis1981 has yet to learn the way of the Dremel
please revision MSI Z68A-GD65 (G3)
randis1981 is offline   Reply With Quote
Old 8th Nov 2011, 00:03   #5
AlienwareAndy
Banned
AlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming Saiyan
I wouldn't even use a sapphire motherboard in you P.C.
Bios updates are non existant and they are impossible to communicate with as they all speak Engrish.
They should leave motherboards to the professionals.
AlienwareAndy is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
