Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 7th Nov 2011, 13:49   #1
Ichigo27
What's a Dremel?
Ichigo27 has yet to learn the way of the Dremel
1x 120 XSPC VS Silver arrow
Hi!
Long time lurker here finally had to step out to ask for help. I am working on my 4th build, had been modding for a couple of years now . my current build is an I5-2500k on a Gigabyte z68-ud3h board. still on stock cooling and saving to buy a good cooler for moddest OC. budget wise, Im very limited, (had to make some painful compromises... ) So! my question is..
1. 1 x 120 XSPC better than say silver arrow or D14?
2. Can simply add another 240 rad in the future (when i have saved some more monies.)
can the pump handle it? as i've read from Dazmode that the stock pumps gets noisy after
some time..
Logically, i would go for a cooler and use the extra cash to get an SSD.. but as in my case, the modder inside me is drooling over a wc.. I know.. for moderate OC Air cool is ok.. i just love to tinker...
If only I've won the lottery... i wont have to deal with such stupid problems..
Ichigo27 is offline   Reply With Quote
Old 11th Nov 2011, 16:36   #2
Ichigo27
What's a Dremel?
any advice? very limited budget.. if the performance is about the same will pick SA. tried to google but comparisons are between h100 and sa which i dont think is helpful.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
