Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 8th Nov 2011, 09:04   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Gainward GeForce GTX 560 Ti 2048MB Phantom Review
Gainward straps a Phantom cooler and 2GB of GDDR5 to the GTX 560 Ti.
http://www.bit-tech.net/hardware/gra...48mb-phantom/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 8th Nov 2011, 09:20   #2
murraynt
I Mod, Therefore I Own
murraynt's Avatar
murraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for president
Id say that extra 1gb would shine in BF3
__________________
l I5 4690k l MSI Z78I l 8GB corsair 1600mhz l Asus 5870 v2 l Fractal Node 304 l 60GB Crucial M4 l F3 1TB Spinner l 700Watt Thermaltake l Samsung IPS231 l
Steam: murraynt
murraynt is offline   Reply With Quote
Old 8th Nov 2011, 09:21   #3
Xir
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
Nice and quiet, appearently the extra memory isn't needed at the tested resolutions.
Pricewise it's very very close to the stock 570 though.
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 8th Nov 2011, 09:45   #4
Parge
the worst
Moderator
Parge's Avatar
Parge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming Saiyan
Time to get BF3 on the test bench! Its the only game that is going to push the higher end cards.
__________________
NCase M1 - 5820k @4.3Ghz - H105 - GTX 980ti - ASRock X99e ITX/ac - 16GB DDR4 - 3x SSD - 600w SFX - 29" Ultrawide - Xonar U7 - Bassshaker - RAT3 - Quickfire TK - Q90s - Orbweaver - Warthog
Parge is offline   Reply With Quote
Old 8th Nov 2011, 10:28   #5
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
Always thought a 2Gb 560 would be perfect for an SLI setup......
Hustler is online now   Reply With Quote
Old 8th Nov 2011, 11:13   #6
RedDethX
Multimodder
RedDethX's Avatar
RedDethX has yet to learn the way of the Dremel
Agreed. Among others, but mainly BF3 cause its so popular. Hoping that ALL graphics cards have a minimum of 1.5GB, hopefully 2GB of VRAM next gen, it's really starting to get used up fast with higher than 1920x1080 resolutions, 3D, Multimonitor, mods/pushing settings past default ones.
__________________
Intel Core i5 2500k @ 4.2GHz || Patriot G2 DDR3 1600MHz 8-9-8-24-1T|| Asus HD 6950 DirectCu II 2GB @ 950MHz/5400MHz || Gigabyte GA-Z68X-UD3H || WD Caviar Black 64MB Cache 640GB + 500GB WD Caviar Blue + 250GB WD Caviar Blue + 2TB Hitachi || CM HAF 922 || Cooler Master Hyper 212+
RedDethX is offline   Reply With Quote
Old 8th Nov 2011, 11:27   #7
nathandanielmorris
Minimodder
nathandanielmorris has yet to learn the way of the Dremel
Not necessarily just the quietness, but IMO this thing looks class.
nathandanielmorris is offline   Reply With Quote
Old 8th Nov 2011, 11:32   #8
xMathiasD
<Title></Title>
xMathiasD's Avatar
xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.xMathiasD is a hoopy frood who really knows where their towel is.
+1 for that!
__________________
i rep - do you?
xMathiasD is offline   Reply With Quote
Old 8th Nov 2011, 11:32   #9
SpAceman
Supermodder
SpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpit
Now that is one sexy looking GPU. I agree with having a BF3 benchmark.
__________________
i7 4770K | Asus Z87-Pro | 16GB Gskill DDR3-1866 | EVGA GTX 760
Silverstone Raven RV02 | Coolermaster V8 | Crucial M4 256GB | Corsair TX750
Dell U2412M | LG W2253TQ | Ducky DK9008 Pro PBT MX Cherry Greens | Naos 7000 | Logitech X-540 5.1 | Logitech G930
SpAceman is offline   Reply With Quote
Old 8th Nov 2011, 11:54   #10
Jipa
Avoiding the "I guess.." since 2004
Jipa's Avatar
Jipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run Crysis
I've had one for half a year now and really enjoy the silence. It also offers plenty of performance for my needs and frankly I don't care about the factory OC.. It comes at a premium price, but then again, buying a cheaper 560Ti and fitting it with a quiet aftermarket cooler isn't cheap, either and voids the warranty, so IMO there's definitely a market for cards like this.
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2
Jipa is offline   Reply With Quote
Old 8th Nov 2011, 14:39   #11
andrew8200m
Mod Master
andrew8200m's Avatar
andrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyan
This card is over 2x the speed on average with ULTRA settings and 4AA than the 1GB card in BF3.
Reviews need tests updating as they are providing a false sense of security to those thinkling about a 2GB card over a 1GB card with the illusion a 1GB will do.
__________________
Systems with parts from various manfacturers
andrew8200m is offline   Reply With Quote
Old 8th Nov 2011, 14:45   #12
l3v1ck
really joined on Dec 24th 2004.
l3v1ck's Avatar
l3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremel
Why include a VGA port? It would have been much better to have all the ports on teh bottom and a full length vent on the second row.
__________________
Originally Posted by Sifter3000
We swung the banhammer in his little stupid spamming face
The old Dennis Forums (CPC, PC Pro, Mac User etc) - Meeting Place lives on. You're welcome to visit it HERE
l3v1ck is offline   Reply With Quote
Old 8th Nov 2011, 14:52   #13
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
Citation needed methinks.
Not saying it's wrong, but something concrete over heresay please.
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 8th Nov 2011, 15:18   #14
thehippoz
Banned
thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!thehippoz - it's over 9000!!!!!!!!1!1!1!!!
think you guys might have mixed up the numbers on bc2- 1080p for the 6990
thehippoz is offline   Reply With Quote
Old 8th Nov 2011, 15:28   #15
matt_lumley
You're only supposed to...
matt_lumley's Avatar
matt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for presidentmatt_lumley should be considered for president
I've got a 2gb 560ti and its excellent, averages 45fps in bf3 and is super quiet, can here the hdd over it at most times.
Sent from my HTC Desire using Tapatalk
matt_lumley is offline   Reply With Quote
Old 8th Nov 2011, 15:36   #16
andrew8200m
Mod Master
We got MSI to do the testing for us who had the opinion of "cant be" only to find out it it was.
Old 8th Nov 2011, 16:31   #17
xaser04
Ba Ba Ba BANANA!
xaser04's Avatar
xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.xaser04 is definitely a rep cheat.
This still needs to be backed up with some form of evidence.
__________________
Daedalus - Clevo P170SM | i7 4700MQ @ 3.4Ghz | GTX780M 4GB @980/6000 | 16GB DDR3 | 17.3" 1920x1080 |
ZPM "VIVE" Mini - Fractal Node 202 | i7 4770S | GTX1070 | 8GB DDR3 | 4K TV / HTC VIVE |
Consoles / Retro - PS4 Pro | PS4 | Xbox One x2 | Dreamcast x2 (VGA) | WiiU | Retron5 |
xaser04 is offline   Reply With Quote
Old 8th Nov 2011, 16:33   #18
andrew8200m
Mod Master
Google is all you need
Old 8th Nov 2011, 16:41   #19
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
You'd be wrong! More info on that later this week though.
Baz is offline   Reply With Quote
Old 8th Nov 2011, 16:45   #20
andrew8200m
Mod Master
Disabling "Desktop Composition" isnt really an argument for or against just incase you plan on using that
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
