Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 8th Nov 2011, 21:28   #1
Arghnews
Multimodder
Arghnews has yet to learn the way of the Dremel
Analog or USB: the difference?
Sorry for being such a n00b but looking at headsets recently I'd just like to ask the simple questions :
Are there any differences except price/physicality between USB or Analog headsets?
Specifically, analog sets always seem cheaper so I've wondered do they have the same drivers?
Basically, been looking at whether to buy a Corsiar HS1 USB for about 50, or buy the analog version for less and then an Asus Xonar for about 50 on top.
So if I just bought the analog headset and plugged it in, would it be exactly the same as the USB version, or would the sound quality be worse? Do the drivers that effectively "replace" a soundcard only come in the USB version?
thanks in advance
Arghnews is offline   Reply With Quote
Old 8th Nov 2011, 22:17   #2
Darkwisdom
Level 99 Retro Nerd
Darkwisdom's Avatar
Darkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming Saiyan
There are differences. Analog headsets/phones are powered using your onboard sound, or dedicated soundcard.
USB has drivers built into the headset, so that you don't need a dedicated soundcard. If you don't want to buy a fantastic soundcard, but want good sound on your headset, USB is a good choice.
However, pair a great soundcard, with a great headset, the quality of sound normally beats a USB set.
With analog, you can also finetune in the soundcard's software to get the sound that suits you.
Darkwisdom is offline   Reply With Quote
Old 8th Nov 2011, 22:25   #3
wolfticket
Downwind from the bloodhounds
wolfticket's Avatar
wolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyan
The USB version basically has a built in external sound card. The analogue version will just have 3.5mm jacks for mic and headphone sockets. The USB version will install as a second sound card so act a little differently.
It's basically a matter of choice. If you have a decent sound card then the quality might be marginally better but with a gaming headset I doubt it will make that much difference.
I personally favour 3.5mm as they are a bit more versatile.
__________________
Wolfticket: Ambitious but rubbish
"A facility for quotation covers the absence of original thought."
Dorothy L. Sayers (1893 - 1957)
wolfticket is offline   Reply With Quote
Old 9th Nov 2011, 20:37   #4
Arghnews
Multimodder
Thanks for the posts back guys
So just to confirm, a headset with a 3.5mm connection has the same, or near as makes no difference, drivers/external soundcard as a USB headset. And therefore the type of connector will make almost no difference to sound quality, unless plugged into an internal soundcard?
I just wanna know that if I save myself 20 on a headset with a 3.5mm jack and plug it into the mobo, will I lose any sound quality vs. buying a headset and plugging it in via USB?
Cheers
Old 9th Nov 2011, 21:25   #5
Darkwisdom
Level 99 Retro Nerd
Darkwisdom's Avatar
A headset with a good soundcard would give slightly better quality.
If you have a crap soundcard, then it wouldn't be worth it.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
