Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th Nov 2011, 11:44   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
ARM unveils next-gen multi-core GPU
New Mali-T658 GPU is equally at home playing games and handling GPGPU applications.
http://www.bit-tech.net/news/hardwar...next-gen-gpu/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 10th Nov 2011, 13:00   #2
kosch
Trango in the Mango
kosch's Avatar
kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.
Seems the CPU/GPU space for mobiles/tablets/superphones is quite exciting at the moment. Cant wait to look back in a few years and see how much its changed!
__________________
Living the dream since 2004 -
Become a Star Citizen & sign up with Bit-Sec the official Bit-Tech organisation Use my referral code for an extra 5,000 credits!
kosch is offline   Reply With Quote
Old 10th Nov 2011, 14:09   #3
KiNETiK
Multimodder
KiNETiK has yet to learn the way of the DremelKiNETiK has yet to learn the way of the DremelKiNETiK has yet to learn the way of the Dremel
but can it run crysis :P
KiNETiK is offline   Reply With Quote
Old 10th Nov 2011, 14:20   #4
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
wow amazing job arm! all i want to see now is a motherboard with pci or pci-e slots supporting an arm cpu and i'll move my linux build to that. seriously with the rate that arm is going at, they are really making VIA's stuff look bad and they're catching up with amd pretty quickly.
__________________
4.5GHz FX-6300 (on an AM3 board) with C'n'Q on, 8GB of RAM, R9 290, ADATA SP900 64GB SSD, Arch Linux 64 bit.
schmidtbag is offline   Reply With Quote
Old 10th Nov 2011, 15:01   #5
Evildead666
Supermodder
Evildead666's Avatar
Evildead666 has yet to learn the way of the Dremel
With most of the latest ARM based GPU's having DX10/11 support, won't that mean that we will at least be able to game in Win8 for ARM ?
If a DX10/11 driver is written (which it should be even to function in Win8 on Aero desktop) then quite a lot of games may be playable on such a system.
All we'd need then is for ARM or a vendor, to add PCIe support and add a discrete GPU in the mix.
__________________
Q9450@3.52GHz, 2x2048 Corsair XMS2 1066, Asus Maximus Formula X38, TR SI-128 SE cooling, Asus 5850, GTS8800-320Mb, SB Audigy 2ZS PCI, Intel Pro 1000 PCIe.
Evildead666 is offline   Reply With Quote
Old 10th Nov 2011, 15:20   #6
Picarro
I Mod, Therefore I Own
Picarro's Avatar
Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.
At the resolutions of a tablet - probably.
__________________
Intel Core i5 2500k @ 5gHz -:- Gigabyte Z68X-UD3H-B3 -:- 2x4 gbCorsair Vengeance 1,5v 1600mHz -:- Gigabyte Windforce X3 GTX 670 -:- Crucial M4 128 gb -:- Samsung F3 Spinpoint 640 gb -:- Corsair H60 with 2x Gentle Typhoon 1850 in push-pull -:- Corsair HX650 -:- Lian Li A05FN -:- Dell U2410 flanked by 2x Dell U2001FP -:- BenQ W1000+ -:-
Picarro is offline   Reply With Quote
Old 10th Nov 2011, 15:57   #7
warejon9
Multimodder
warejon9 has yet to learn the way of the Dremel
This could be great for power saving. Have a dedicated GPU for hardcore rendering, and a small ARM chip for desktop.
warejon9 is offline   Reply With Quote
Old 10th Nov 2011, 18:37   #8
Narishma
Multimodder
Narishma has yet to learn the way of the Dremel
It would also need the game to be compiled for the ARM version of Windows.
Narishma is offline   Reply With Quote
Old 10th Nov 2011, 22:45   #9
ch424
Design Warrior
ch424's Avatar
ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.
You can buy better than that http://www.linaro.org/low-cost-development-boards
ch424 is offline   Reply With Quote
Old 10th Nov 2011, 22:51   #10
Blazza181
SVM PLACENTA CASEI
Blazza181's Avatar
Blazza181 is definitely a rep cheat.Blazza181 is definitely a rep cheat.Blazza181 is definitely a rep cheat.Blazza181 is definitely a rep cheat.Blazza181 is definitely a rep cheat.Blazza181 is definitely a rep cheat.Blazza181 is definitely a rep cheat.Blazza181 is definitely a rep cheat.Blazza181 is definitely a rep cheat.Blazza181 is definitely a rep cheat.Blazza181 is definitely a rep cheat.
Sounds fantastic.
Especially since they're british.
__________________
"with 150m.. you could buy a real Pop Tart.. maybe one from the Saturdays" - Blarte
"That's nothing, I shave my pubes for fun " - Panomama
"Suddenly I really wish moose sex was legal. " - Kidmod-Southpaw
Blazza181 is offline   Reply With Quote
Old 15th Nov 2011, 08:53   #11
[USRF]Obiwan
I *am* a Dremel
[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.
At the rate this is going we have a full blown cheap ARM desktop processor in 5 years.
__________________
[USRF]Obiwan is offline   Reply With Quote
Old 17th Nov 2011, 20:32   #12
Fizzban
Man of Many Typos
Fizzban's Avatar
Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.
Go ARM!
__________________
-Banana in disc drive error-
To win the battle, is to be prepared to die - Miyamoto Musashi
Originally Posted by RedFlames View Post
Asking to pick between the main parties is like asking which testicle you want to be kicked in, you're gonna get kicked the nuts whoever you pick... Just have to hope whoever you pick aren't wearing steelies...
Fizzban is offline   Reply With Quote
Old 13th Dec 2011, 11:55   #13
Culinia
Minimodder
Culinia has yet to learn the way of the Dremel
Originally Posted by Blazza181 View Post
Sounds fantastic.
For now...
Culinia is offline   Reply With Quote
Old 13th Dec 2011, 17:17   #14
Blazza181
SVM PLACENTA CASEI
Blazza181's Avatar
Originally Posted by Culinia View Post
For now...
Oh, don't put a downer on such a momentous occasion.
__________________
Old 13th Dec 2011, 21:56   #15
fdbh96
I *am* a Dremel
fdbh96's Avatar
fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.
The next saamsung galaxy tab is meant to have a resolution of 2560x1600
fdbh96 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
