Reply
Thread Tools View Mode
Old 14th Nov 2011, 00:36   #1
Gambo
What's a Dremel?
Gambo has yet to learn the way of the Dremel
2&˝
I everyone!
This will be my first build here, as it was my first scratch/finished build ever.
I made it earlier this year. Hope you like it.
Simple concept, motherboard on top, psu and storage at bottom.
TFX power supply, cage for 3 HDD and a sliding tray
of to the building!
main panel
HDD bay - Made some changes on the original concept. The 3 were a bit too tight on the case, so I took 1 out, raised them a bit to have more clearance and put an SSD on top.
SSD and some old HDDs for testing.
motherboard tray
structure
Hardware in
Front fan holder
silicone foam for less vibration
bottom backplate.
the right hole will have mesh covering...
and thats it for now. hope you all like it.
will post the rest soon.
Gambo is offline   Reply With Quote
Old 14th Nov 2011, 01:09   #2
jrs77
theorycrafting
jrs77's Avatar
jrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for president
Hi there. Nice start and it's another mini ITX, so I approve
What will you be using this system for, seeing that you're not using a dedicated GFX-card?
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB]
jrs77 is offline   Reply With Quote
Old 14th Nov 2011, 01:12   #3
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
Verry good start. gonna keep an eye in here.
k.3nny is offline   Reply With Quote
Old 14th Nov 2011, 11:59   #4
Gambo
What's a Dremel?
thanks guys.
the PC is for my father, so it doesn´t need that much power.
(although he already played COD5 in it and it managed. )
the idea was really "compact" and "sober"
I'll post lot more later tonight
Old 14th Nov 2011, 12:51   #5
Throbbi
I Mod, Therefore I Own
Throbbi's Avatar
Throbbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpitThrobbi is almost as Godly as yodasarmpit
Another mini-ITX build Seems to be a surge in them all of a sudden and they're all awesome The sliding tray is perfect for such a small build knowing how fiddly they can be
__________________
Steam - Throbbi ::WoT -Unpainted_Target ::BF3 - Throbbi
Phenom IIX4 B60 (core unlockedX2 560 @ 3.9ghz) - 2x4GB 1333DDR3 - 1.8TB Storage - XFX GTX260 kindly loaned by Lancer778544! rep him! Relix commands you! (he does, honest, told me yesterday)
::The rig made possible ONLY by this great community!
Share And Enjoy!
Throbbi is online now   Reply With Quote
Old 14th Nov 2011, 17:53   #6
soul_train
Multimodder
soul_train has yet to learn the way of the Dremel
Amazing work m8 keep it coming
soul_train is offline   Reply With Quote
Old 14th Nov 2011, 18:05   #7
DiamondFX
What's a Dremel?
DiamondFX's Avatar
DiamondFX has yet to learn the way of the Dremel
Nice start, I like
DiamondFX is offline   Reply With Quote
Old 14th Nov 2011, 18:40   #8
adidan
CPC_refugee
adidan's Avatar
adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.adidan is the Cheesecake. Relix smiles down upon them.
Looks like it's going to be a home made Lian-Li. Nice.
__________________
Don't do today what you can put off until tomorrow
Battlefield 3 adidan_uk BF3 Stats
i7 3770 3.4GHz // Asus P8Z77-M // Scythe Big Shuriken // Gainward 570 Phantom // 8Gb G.Skill Ripjaws 1600MHz //
250Gb Samsung 840 // 650W Be Quiet Dark Power Pro // Lian Li V351b Apache Filled // Samsung T220 22" // W7 64
adidan is offline   Reply With Quote
Old 15th Nov 2011, 00:48   #9
Gambo
What's a Dremel?
since the top, front and bottom are 1 piece only, it had to come out some way..
Hi mate!
saying it isn't inspired by it, would be a lie. I love the small Lian-Li, though this way fits me better.
more pics!
Slim-Sata adapter
sleeved and masked CPU fan.
B-magic!
PSU
cut all the wires to a more suitable lenght
more sleeving
2nd ODD holder, this time with riveted pieces instead of bending 1 whole piece.
more to come...
Old 15th Nov 2011, 06:57   #10
adidan
CPC_refugee
adidan's Avatar
I love their small cases too, impressive metalwork skills going on there I must say.
Keep up with the updates.
__________________
Old 15th Nov 2011, 13:05   #11
Razer2007
Building Proxima
Razer2007's Avatar
Razer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the Dremel
Good metalworking dude. I like the design. Keep it up +rep
__________________
Razer2007 is offline   Reply With Quote
Old 15th Nov 2011, 22:49   #12
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Canardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the Dremel
More than nice job... following your project.. Suscribed!!
Canardwc is offline   Reply With Quote
Old 15th Nov 2011, 22:54   #13
Gambo
What's a Dremel?
thanks guys! It was my first time working with a metal.
It's not any near perfect, but I'm very happy with it.
next...
painting..
some finishing details..
silicone foam to cover up some places
MB tray slides perfectly, no sound or vibrations.
back to the PSU
getting rid of some wires
cables needing a twist because of the inverted SSD.
finished PSU!
more case "padding"
Padded front fan
some assembling
cheers!
Old 15th Nov 2011, 22:54   #14
Gambo
What's a Dremel?
Thank you!
Old 16th Nov 2011, 11:17   #15
Vetalar
*learning english*
Vetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the Dremel
great metalwork and paintjob!
*watching*
Vetalar is online now   Reply With Quote
Old 16th Nov 2011, 11:39   #16
yassarikhan786
Ultramodder(Not)
yassarikhan786's Avatar
yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.yassarikhan786 is a hoopy frood who really knows where their towel is.
I'm mightily impressed with your metal work and brilliant paint job. Look's like it came straight out of a factory.
You say this is your first time working with metal. That makes it all the more impressive. Keep up the great work and I will be watching with interest .
__________________
|| Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: Gigabyte GTX 580 Super OC || Memory: Mushkin Blackline 8GB || SSD: Corsair Force 3 120GB || HDD: WD Caviar Black 2TB || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v || Keyboard: Logitech G510 || Mouse: Razer DeathAdder
yassarikhan786 is offline   Reply With Quote
Old 16th Nov 2011, 11:44   #17
Gtek
Supermodder
Gtek's Avatar
Gtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run Crysis
Really nice and clean job so far, keep it up
__________________
***gtek-computerdesign.com***
Gtek is offline   Reply With Quote
Old 16th Nov 2011, 23:27   #18
Gambo
What's a Dremel?
*watching*
Thanks!
I'm glad you like it.
It was a very nice experience, with lots of learning for me.
I too got impressed by the results.. wasn't that much confident when I started. lol
Thanks Peter! I truly appreciate it!
PSU in
ODD adapter
And mobo in.
SSD in.
bad picture just to show a 3.5" HDD next to the the case..
HDD in.
and some more pics
final cable sleeving..
Old 17th Nov 2011, 16:02   #19
nathandanielmorris
Minimodder
nathandanielmorris has yet to learn the way of the Dremel
Wow. I'm looking to build a compact low-profile HTPC, and if you don't mind me saying this has given me some inspiration and a few ideas that I think I might well pinch!
nathandanielmorris is offline   Reply With Quote
Old 17th Nov 2011, 16:06   #20
yassarikhan786
Ultramodder(Not)
Brilliant job on the sleeving and cable management.
Haha, I like the comparison with the HDD. I didn't think the case would be that small .
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
