Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 14th Nov 2011, 13:46   #1
Recknball
What's a Dremel?
Recknball has yet to learn the way of the Dremel
Project-WAR-HARDENED
whats up all this is a new mod i just starting its build is for the new Battlefield 3 game . well let get started .
To start i'm going to use the Cooler Master storm scout case
Products going in to this build are ..
Cooler Master
Storm Scout case
600w silent pro
2x 120mm fans and 3 140mm fans
ASUS
1155 P67 Sabertooth motherboard
EVGA
GTX 560 ti
Phobya
G-Changer 120x1
Phobya Balancer 250 Silver Nickel
Heatkiller
GTX 560 Hole Edition
Koolance
Nozzle Single, G 1/4" Compression [ID: 13mm (1/2"); OD: 19mm (3/4")]
Nozzle Single, G1/4 Swivel Angled [13mm, 1/2"] - Single Fitting
ok it was time to cut ad flip the motherboard tray and back .
new side with clear plex. in it .
ok some .45 holes and no cops showed up to the house lol .
Recknball is offline   Reply With Quote
Old 14th Nov 2011, 17:10   #2
sparkyboy22
Web Tinkerer
sparkyboy22's Avatar
sparkyboy22 has yet to learn the way of the Dremelsparkyboy22 has yet to learn the way of the Dremelsparkyboy22 has yet to learn the way of the Dremelsparkyboy22 has yet to learn the way of the Dremelsparkyboy22 has yet to learn the way of the Dremelsparkyboy22 has yet to learn the way of the Dremelsparkyboy22 has yet to learn the way of the Dremelsparkyboy22 has yet to learn the way of the Dremel
Reported as duplicate
http://forums.bit-tech.net/showthread.php?p=2874100
http://forums.bit-tech.net/showthread.php?t=220467
__________________
i5 2500k @ 4.5 GHz | Corsair H100 | Asus P8P67 Pro | 16GB Corsair Vengeance | EVGA GTX680 | Corsair Force 3 240GB SSD
Asus Xonar D2X | Corsair HX650 | Xigmatek Utgard | Dell U2311h 1920x1080
Logitech Z906 5.1 Speakers | Logitech K750 Solar Keyboard | Logitech Performance MX Mouse
sparkyboy22 is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
