Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 16th Nov 2011, 12:22   #1
Claave
You Rebel scum
Claave's Avatar
Claave has yet to learn the way of the DremelClaave has yet to learn the way of the DremelClaave has yet to learn the way of the Dremel
See the Antec P280 first at i44
The first chance to see Antec's forthcoming P280 is at i44 - are you going?
http://www.bit-tech.net/news/hardwar...first-at-i44/1
Claave is offline   Reply With Quote
Old 16th Nov 2011, 13:23   #2
Jipa
Avoiding the "I guess.." since 2004
Jipa's Avatar
Jipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run Crysis
To me it's NOT a shame not to see one of those damn 200 mm fans on the roof. If it's silence you're after, proper 120/140 mm fans are easy to find. BTW those new Antec fans actually are quiet...
And for more photos, there's a gallery over at: http://www.anandtech.com/Gallery/Album/1111
Looks good to me, might end up actually using this, or the new Solo II.
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2
Jipa is offline   Reply With Quote
Old 16th Nov 2011, 13:43   #3
Idioteque
Telephasic Mongoose
Idioteque's Avatar
Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.Idioteque is definitely a rep cheat.
I'm glad there's a new Antec case which focuses on classic smooth lines rather than those garish gaming cases they've been focusing on for the past two years. Looks nice.
That aside, as Jipa said. Is a 200mm+ fan in the top really so difficult?
__________________
Dreams are the subconscious mind's way of reminding people to go to school naked, and have all their teeth fall out.
Idioteque is offline   Reply With Quote
Old 16th Nov 2011, 13:44   #4
racingrob
What's a Dremel?
racingrob has yet to learn the way of the Dremel
I have just got rid of my P180 Mini after replacing the 200mm fan and that one chattered as well. being able to use any 120mm/140mm is a better option imho.
racingrob is offline   Reply With Quote
Old 16th Nov 2011, 13:48   #5
Idioteque
Telephasic Mongoose
Idioteque's Avatar
Well, there's that. I still love my delightfully silent Mini P180. Never had a problem with the top fan on low. Would be good to have the option of either 2*140mm or one 200mm+ fan.
__________________
Old 16th Nov 2011, 14:21   #6
bogie170
Supermodder
bogie170 has yet to learn the way of the Dremel
Does not look a patch on my Antec P182 SE mirror finish.
http://www.antec.com/Believe_it/prod...e=Mg==&id=Ng==
bogie170 is offline   Reply With Quote
Old 16th Nov 2011, 14:46   #7
Bede
Ultramodder
Bede's Avatar
Bede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for president
This is surely an advertisement for Antec and i44 and should be labelled as such..
__________________
Coolermaster 690 II Advanced (white edition) | i5-2500K | MSI P67-GD53 | Asus 970 Strix OC | 16gb Corsair Vengeance LP | Gelid Tranquillo
Asus Xonar DS | 700W Coolermaster Silent Pro M | Crucial M4 128GB | SanDisk Ultra II 480GB | Samsung Spinpoint F3 1TB
Bede is offline   Reply With Quote
Old 16th Nov 2011, 14:46   #8
RedFlames
...is a figment of your imagination
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
+1 for 'thank glod they've ditched the "big boy"', it was the first thing to go [break] on my 1200
__________________
Why are you still reading this? The post is over. Go Home.
RedFlames is offline   Reply With Quote
Old 16th Nov 2011, 14:47   #9
Evildead666
Supermodder
Evildead666's Avatar
Evildead666 has yet to learn the way of the Dremel
I hated the 200mm fan in my antec tower, it barely moved any air, and I just deemed it pointless.
Much happier with a dual 120/140mm setup.
__________________
Q9450@3.52GHz, 2x2048 Corsair XMS2 1066, Asus Maximus Formula X38, TR SI-128 SE cooling, Asus 5850, GTS8800-320Mb, SB Audigy 2ZS PCI, Intel Pro 1000 PCIe.
Evildead666 is offline   Reply With Quote
Old 16th Nov 2011, 14:51   #10
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
would love to be able to block those top vents like in Fractal Design cases. current configuration seems like a neg-pressure case with dust sucked through the back vents.
like the 2x120 fan placements. wonder if it's possible to put 2 240 radiators in this case? one on top, one on the HDD cage? that would make this an awesome watercooling case. there's more than enough room.
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 16th Nov 2011, 16:12   #11
delriogw
Multimodder
delriogw has yet to learn the way of the Dremel
d'oh, was planning on speccing for a couple of days, but can't afford to get there.
typical.
always been a fan on the range, but once i started attenting i-series i have to say i was less enamoured. they are not a great case to try and get to a LAN when you have no car and a very bad back hopefully this one will weigh a bit less than the usual baby elephant
delriogw is offline   Reply With Quote
Old 16th Nov 2011, 16:51   #12
Jipa
Jipa's Avatar
Yeah they sure aren't, but then again, that's kinda the whole point...
__________________
Old 16th Nov 2011, 16:56   #13
RevDarny
Supermodder
RevDarny's Avatar
RevDarny is definitely a rep cheat.RevDarny is definitely a rep cheat.RevDarny is definitely a rep cheat.RevDarny is definitely a rep cheat.RevDarny is definitely a rep cheat.RevDarny is definitely a rep cheat.RevDarny is definitely a rep cheat.RevDarny is definitely a rep cheat.RevDarny is definitely a rep cheat.RevDarny is definitely a rep cheat.RevDarny is definitely a rep cheat.
Do like the clean lines. This maybe the case to replace my P180
RevDarny is offline   Reply With Quote
Old 16th Nov 2011, 20:31   #14
azrael-
I'm special...
azrael-'s Avatar
azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!
The interior of the new case isn’t compartmentalised, however, which allows the P280 to be less massive than its predecessors at 231 x 561 x 526mm (W x D x H).
The dimensions of the P180 v3 are 514 mm (H) x 205 mm (W) x 507 mm (D), so one can hardly claim the P280 is smaller. The P280 seems to weigh in at a few kilos less than then P180 v3, though. Probably because it's a mere shade of its predecessors when it comes right down to it.
__________________
It's not the end of the world ...but you can see it from here.
Xeon E3-1245 v2 3.4 GHz | ASUS P8C WS | 16GB Kingston ECC DDR3 | Samsung 830 256GB | eVGA GTX670 2GB | SB Audigy | Seasonic X-560 | Corsair Obsidian 550D | Dell 2209WA
azrael- is offline   Reply With Quote
Old 16th Nov 2011, 21:41   #15
PingCrosby
Supermodder
PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.
I'll have a P please Bob.
PingCrosby is offline   Reply With Quote
Old 16th Nov 2011, 22:41   #16
Pookie
Level 0
Pookie's Avatar
Pookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming Saiyan
The fans in my antec 900 purchased in 2007 are all original and still as quiet as ever. I will be upgrading to this case over xmas, 900 gets too dusty.
__________________
Unlimited Fibre Broadband 38Inc Per month including line Rental!
http://pulse8broadband.co.uk/fibreoptic-broadband
Pookie is offline   Reply With Quote
Old 17th Nov 2011, 14:14   #17
Vo0Ds
Fake potato
Vo0Ds's Avatar
Vo0Ds has yet to learn the way of the DremelVo0Ds has yet to learn the way of the Dremel
Fractal R3 F.T.W.
__________________
Masara: i5 2500@4.2Ghz | Asus P8P67LE | EVGA GTX460SC | 8Gb Corsair 1600 | 1TB WD-C BLACK | Fractal R3 | LG 23" IPS
LEGO Ghetto HTPC: Broken-ass laptop pulled apart, now a HTPC... made of LEGO. UNDER CONSTRUCTION
Vo0Ds is offline   Reply With Quote
Old 17th Nov 2011, 22:37   #18
trig
god's little mistake
trig's Avatar
trig has yet to learn the way of the Dremeltrig has yet to learn the way of the Dremeltrig has yet to learn the way of the Dremeltrig has yet to learn the way of the Dremeltrig has yet to learn the way of the Dremel
this looks to be a killer...and with the issues of the fractal door, may swing my money in antec's direction...read a few reviews and it is looking nice, and for $140
__________________
i5-4670K @ stock w/scythe mugen 4-msi z97m gaming-8 GB 2400 mhz gskill-asus strix gtx 970-phantek enthoo evolv matx-evga 550 G2 psu-512 gb mushkin boot drive-wd black 1.5 tb 32mb cache & various other ssd storage-logitech gx9 mouse g510 keyboard-aoc g2460pg
trig is offline   Reply With Quote
Old 18th Nov 2011, 16:42   #19
Kiliv
Multimodder
Kiliv has yet to learn the way of the Dremel
i saw the case as it was being unpacked yesterday its very very shiny literally and fingerprints are a pain to get off even iff there is a cloth supplied for it, its built solid although looks like it would lack cooling which the sales rep from antec agreed with
__________________
Desktop, I7 970 @4.9Ghz - Gigabyte G1. guerrilla - 12Gb of Corsair Vengeance ram - EVGA SC GTX 670 4Gb. OCZ vertex 4 ssd.
Laptop, I7 Q740m - 8gb kingston ram - Ati 5870m - OCZ Vertex 3 SSD - 2x 500gb hdd in raid
LAN box I7-930 @ 4.4Ghz 12Gb Corsair Vengence ram, EVGA SC GTX 460, OCZ summit
Kiliv is offline   Reply With Quote
Old 18th Nov 2011, 19:34   #20
trig
trig's Avatar
can see that. looks like no fans on the front for intake come with it...but i would imagine a couple of good fans for the front would make it just as good as the fractal at cooling if not better. but honestly, you're not buying this case for world class cooling...
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
