Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 18th Nov 2011, 09:19   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
CM Storm Trooper Review
CM Storm looks to take the LAN party market by, erm, storm with the Trooper case.
http://www.bit-tech.net/hardware/201...ooper-review/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 18th Nov 2011, 11:53   #2
Noob?
Banned
Noob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming Saiyan
Nice review.
Noob? is offline   Reply With Quote
Old 18th Nov 2011, 12:43   #3
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
I was interested in one of these when i first saw pictures of it....but i recently saw one in the flesh so to speak, and its..JUST HUGE, to the point of looking very unappealing at thought of it sitting on my desk, damn thing would blot out all sunlight from the nearby window..), and i'd have to stand up all the time just to plug stuff into the front ports...which would get old real quick.
So, i think I'll go with the more elegant Corsair 500R.....
Hustler is offline   Reply With Quote
Old 18th Nov 2011, 12:56   #4
Sarakon
The German
Sarakon's Avatar
Sarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming SaiyanSarakon is a Super Spamming Saiyan
For some reason i quite like the looks of this case (usually i also prefer the clean looks having a Corsair 650D myself)
And it does look very big indeed!!
__________________
Corsair 650D| Asus P8P67 EVO | Intel i5 2500K | OCZ Vertex 4 | Crucial BX100 | Corsair Vengeance 16GB | MSI GTX 660Ti PE OC
Sound Blaster Z | Cooler Master 850W Silent Pro M
Sarakon is offline   Reply With Quote
Old 18th Nov 2011, 13:52   #5
Woodspoon
Supermodder
Woodspoon's Avatar
Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.
Looks quite nice, maybe a little plasticy but quite nice.
Woodspoon is offline   Reply With Quote
Old 18th Nov 2011, 13:58   #6
Kovoet
I Mod, Therefore I Own
Kovoet's Avatar
Kovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming Saiyan
I actually like the look of this case and its good tests on the GPU cooling means that with a Corsair CPU water cooler will do the trick perfectly
__________________
MOBO[ Asus Maximus Formula VII ]CPU[I7 4770K]RAM[Corsair Vengeance PRO Red 2133mhz]SSD's[1TB Samsung EVO, 256GB Samsung, 128GB Mushkin, 128 GT Corsair]GPU[EVGA GTX980]PSU[Corsair AX1200i Red Cables]CASE[Corsair 540] Cooler[Corsair H100i]Screen[Dell U2913WM} Perp[Corsair K70, Logitech G502,Belkin razer N52TE,
HyperX Cloud II]
Kovoet is offline   Reply With Quote
Old 18th Nov 2011, 22:00   #7
Grimloon
Hypermodder
Grimloon's Avatar
Grimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpit
Hmm, looks OK in a "function over form" kind of way. I rather like it but there are a couple of things that puzzle me.
1) Is that handle truly functional? I did read the claim but it seems a little exaggerated considering the lack of any internal bracing to carry that sort of weight. Any chance of a Bit-Tech test where the case (without system) is loaded with bricks and given to Harry to move to a different part of the building? (BTW, what happened to the Harry button testing for durability? Did he suddenly become incapable of breaking them with a single press or is Coolermaster his kryptonite?)
2) The CPU delta T chart shows the high speed HDD cage perpendicular figures as being worse than the low speed HDD cage perpendicular results but the numbers are identical? Is that right or a slight faux pas with the figures? Not a dig, just curious.
Grimloon is offline   Reply With Quote
Old 18th Nov 2011, 22:16   #8
shrop
El Jefe of Sleeving
shrop's Avatar
shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.
Plastic and dog ugly. When will CM ever make a decent looking case?
__________________
shrop is offline   Reply With Quote
Old 18th Nov 2011, 23:53   #9
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.
ACTS 840?
Also, not in white? Disappoint.
__________________
The Box:i7 2700K@5.3GHz|EK Supreme LT+Coolstream XT 360|16GB HyperX DDR3@1866MHz|EVGA GTX780 ti+EK FC780ti|MSI P67A-GD55||M5 512|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Perixx MX2000 + Intuos 4M
Audio: PC->TosLink->TEAC UD-501->Fostex TH600|InEar LivePro 3|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Old 19th Nov 2011, 00:39   #10
shrop
El Jefe of Sleeving
shrop's Avatar
Originally Posted by Tangster View Post
ACTS 840?
I did say, 'good' looking. lol
__________________
Old 20th Nov 2011, 19:30   #11
grritsshawn
I'm not insane I'm a modder
grritsshawn's Avatar
grritsshawn has yet to learn the way of the Dremelgrritsshawn has yet to learn the way of the Dremelgrritsshawn has yet to learn the way of the Dremelgrritsshawn has yet to learn the way of the Dremelgrritsshawn has yet to learn the way of the Dremelgrritsshawn has yet to learn the way of the Dremel
Its about as useless as air cooling as the 800d....but with water cooling u got enough room
__________________
The reason of life is cheesecake and beer and sex....and the occasional mod
grritsshawn is offline   Reply With Quote
Old 25th Jan 2012, 19:48   #12
Howdy
What's a Dremel?
Howdy has yet to learn the way of the Dremel
I like and have this case, handle works fine but when carrying it does fell like all the wait is at the back compared to the storm scout which felt more balanced. No offence to the previous comments but I don't buy a case for looks just features and this case has the space and options for a lot of ideas.
Howdy is offline   Reply With Quote
Old 25th Jan 2012, 19:59   #13
Howdy
What's a Dremel?
I like and have this case. I have this one and the Scout but with the Trooper, most of the weight is at the back. Which you notice when lifting it compared to the Scout which had more evenly proportioned weight thanks to the handle deign.
The only thing letting the case down I would say is the manual........... As it wasn't very clear when changing the hard drive fan positions.
I'm not bothered about the look as it's the parts inside that make a pc, case is optional, but the majority desire a nice looking one
All in all I would give it 9/10, easy to work with but the manual needs improving or make it easier to change the fan positions for the hard drives.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
