Reply
Thread Tools View Mode
Old 24th Nov 2011, 20:48   #21
wejjy
Hypermodder
wejjy's Avatar
wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.
Great idea mate, like the build but dont understand how you can work in that basement
wejjy is offline   Reply With Quote
Old 24th Nov 2011, 21:23   #22
dynamis_dk
Grr... Grumpy!!
dynamis_dk's Avatar
dynamis_dk is the Cheesecake. Relix smiles down upon them.dynamis_dk is the Cheesecake. Relix smiles down upon them.dynamis_dk is the Cheesecake. Relix smiles down upon them.dynamis_dk is the Cheesecake. Relix smiles down upon them.dynamis_dk is the Cheesecake. Relix smiles down upon them.dynamis_dk is the Cheesecake. Relix smiles down upon them.dynamis_dk is the Cheesecake. Relix smiles down upon them.dynamis_dk is the Cheesecake. Relix smiles down upon them.dynamis_dk is the Cheesecake. Relix smiles down upon them.dynamis_dk is the Cheesecake. Relix smiles down upon them.dynamis_dk is the Cheesecake. Relix smiles down upon them.
lol, slowly with very little side to side movement
__________________
-: MM UF0 Duality :- 2700K, 16GB Ballistix Tracer 1600, P67A-GD65, RAID0@ 2x120GB Vertex3, 580GTX, AX1200 :-
-: Dual Loop Watercooling :- 2x Laing D5, 2x PA120.3, EK 580GTX Fullcover, EK Supreme HF, EK TubeRes :-
dynamis_dk is online now   Reply With Quote
Old 24th Nov 2011, 21:29   #23
wejjy
Hypermodder
wejjy's Avatar
Haha, makes it all the more amazing!! Keep it up dude!
Old 24th Nov 2011, 23:00   #24
bradders2125
Supermodder
bradders2125's Avatar
bradders2125 has yet to learn the way of the Dremel
I had the same idea a year or two ago, apart from I was going to use an old white non-hd box. Never got round to doing it though.
Gonna watch yours and see if I can get motivated to give it a go.
Brads
__________________
My Brute - Bit Tech is more than games and hardware - check out the mods too. Don't let modding die in Bit-Tech.net.
DEATH TO CONSOLIFICATION!!!
bradders2125 is offline   Reply With Quote
Old 24th Nov 2011, 23:04   #25
SilveR_172
Supermodder
SilveR_172 has yet to learn the way of the DremelSilveR_172 has yet to learn the way of the Dremel
Brilliant idea and i like the progress so far , not yet got into the side of Media pc as ive not got my own space but when i do i can see me doing this ^_^ ,
Never realized there was so much space to be has inside the Sky box , one thing that worries me about your goals is making the sky buttons still work how will you achieve this ?
SilveR_172 is offline   Reply With Quote
Old 29th Nov 2011, 11:09   #26
dynamis_dk
Grr... Grumpy!!
dynamis_dk's Avatar
Well u have a bit of a progress (or lack of) report on the buttons.
I started work on creating the pcb to replace the existing switch pcb. Initially I was just going to Dremel away the traces in the existing pct and wire up small patch cables I connect how I needed. Now decided to do things correctly (I say correctly, I'm not pcb designer so those in the know don't bash me too much!).
I'm not posting all the details as there are loads of how to guides for pcb design.
So into photoshop, layout designed, transferred to pcb, trimmer and ready for etching - doh!! Etching solution seems dead, presuming due to its age so I've ordered a 1l bottle of hydrochloric acid and some 6% peroxide which will become my etch fluid. After 1 1/2 hour in my existing stuff it hadn't so much as wore the ever edges never mind anything else.
As it stands not much progress on the case side too. Waiting till a get a few hours so I can do some more liking and start painting.
On a side note, 120mm fan in the case top or not?? I'm in two minds as although the system is fanless, a bit of air movement wouldn't hurt. I was thinking slipstream thin 120mm fan at 5v directly over the motherboard as an exhaust. Then a standard wire fan grill sprayed black...
Maybe my initial planning stage should have had - well - planning involve
__________________
Old 29th Nov 2011, 11:36   #27
goldstar0011
I *am* a Dremel
goldstar0011's Avatar
goldstar0011 is almost as Godly as yodasarmpitgoldstar0011 is almost as Godly as yodasarmpitgoldstar0011 is almost as Godly as yodasarmpitgoldstar0011 is almost as Godly as yodasarmpitgoldstar0011 is almost as Godly as yodasarmpitgoldstar0011 is almost as Godly as yodasarmpitgoldstar0011 is almost as Godly as yodasarmpitgoldstar0011 is almost as Godly as yodasarmpitgoldstar0011 is almost as Godly as yodasarmpitgoldstar0011 is almost as Godly as yodasarmpitgoldstar0011 is almost as Godly as yodasarmpit
I will be watching this and may have to do my own, have several boxes around not in use, didn't realise how much space there was either.
Interested on your final result on using the buttons
Good luck
goldstar0011 is online now   Reply With Quote
Old 29th Nov 2011, 11:58   #28
varkanoid
Professional Dribbler
varkanoid's Avatar
varkanoid can run Crysisvarkanoid can run Crysisvarkanoid can run Crysisvarkanoid can run Crysisvarkanoid can run Crysisvarkanoid can run Crysisvarkanoid can run Crysisvarkanoid can run Crysisvarkanoid can run Crysisvarkanoid can run Crysisvarkanoid can run Crysis
I would get a 60mm FAN and use existing Sky Fan mount as input and then think about extracting air maybe the other side with another 60mm fan ?
__________________
Intel i5 2500k @ 4.2ghz, Gigabyte Z68AP-D3, Corsair DDR3 8gb, Antec 750w, MSI GTX 560-TI 448, Coolermaster Elite 311 http://www.red-dwarf.net
varkanoid is offline   Reply With Quote
Old 29th Nov 2011, 12:01   #29
SilveR_172
Supermodder
i wouldnt put a fan on the top as it will ruin the idea of the Sky box look , it'd be awesome for it to look standard , id go for some rear fans like 80 millers or even smaller just to took at the side of the Io sheild ,
Old 29th Nov 2011, 14:39   #30
dynamis_dk
Grr... Grumpy!!
dynamis_dk's Avatar
Well that was what I was thinking as I was trying to go for 'as stock' as possilble look. I might have a play with the 60mm fans I have and see what the noise is like run at 5v - didn't really want to use small fans due to noise but mayne at 5v a 'in on one site' and 'out on the other' approach might work well. Really trying to avoid high ambient temps.
Good news, the PCB drills arrived today so that one bit out of the way lol.
SilveR_172 - Don't know how much of the start you read over but my solution to the button issues is a games controller called IPAC-2 - its basically an emulator for the keyboard so you can wire up a switch to one if its 32 inputs, then configure it so everytime you hit with switch, its send a 'P' for example - which could be configured as Play in the XBMC software - you get the idea
__________________
Old 29th Nov 2011, 14:50   #31
Shuttlemodder
Ultramodder
Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!Shuttlemodder - it's over 9000!!!!!!!!1!1!1!!!
have you thought about using the pci exhaust fans?
nice and quiet when run at a sensible speed.. and only take up 1.5cm in height
Shuttlemodder is offline   Reply With Quote
Old 29th Nov 2011, 15:04   #32
dynamis_dk
Grr... Grumpy!!
dynamis_dk's Avatar
Yeah I'd thought about those, I have one kicking around somewhere too. I thought maybe directly above the main heatsink could work well.
Think its going to be a case of dig out all my suitable fans and test at difference voltages. I want to be able to run quiet but fans always on so theres no need for any switches or controllers to be involved.
Also trying with idea of some kind of 45 degree housing / bracket so I can use a larger fan (say 80mm) and use the bracket as a duct to the case sides which hopefully would equal more air flow at set noise, or same air flow at less noise...
__________________
Old 29th Nov 2011, 15:06   #33
Noob?
Dremel?
Noob? is definitely a rep cheat.Noob? is definitely a rep cheat.Noob? is definitely a rep cheat.Noob? is definitely a rep cheat.Noob? is definitely a rep cheat.Noob? is definitely a rep cheat.Noob? is definitely a rep cheat.Noob? is definitely a rep cheat.Noob? is definitely a rep cheat.Noob? is definitely a rep cheat.Noob? is definitely a rep cheat.
Looking good mate!
Noob? is online now   Reply With Quote
Old 29th Nov 2011, 15:09   #34
Shuttlemodder
Ultramodder
what is the height of the unit? (i dont have one to hand at work)
Old 29th Nov 2011, 16:30   #35
dynamis_dk
Grr... Grumpy!!
dynamis_dk's Avatar
I'm not at home to measure up but I'd guess about 75mm. If the stock fan is 60mm there's a bit above and below
__________________
Old 1st Dec 2011, 10:14   #36
dynamis_dk
Grr... Grumpy!!
dynamis_dk's Avatar
While I'm still waiting on a few bits to be delivered this week I've had another bash as the PCB layout this morning. Now for those of you who are in the know, don't abuse me too much - I've little PCB knowledge and NO design knowledge at all. All this was done in photoshop.
This will be for the 9 buttons on the top of the box. There will be a 2nd board to make for the front (next, stop etc) buttons. The combination of the two will be linked to the IPAC-2 controller to emulate the keyboard presses, which in turn control the XBMC interface.
__________________
Old 2nd Dec 2011, 11:15   #37
dynamis_dk
Grr... Grumpy!!
dynamis_dk's Avatar
Got a few more goodies which will help towards the finished item.
1l Bottle hydrochloric acid, small bottle hydrogen peroxide, Box of Paxmate acoustuc mat and sat on top of the box (you may need to look close) a few sets of ATX style pins.
Did some more work on the layout and mounting. Decided the IPAC-2 is easiest to mount on some more stand offs as I'd initially decided to mount on the case vertical front but since I have spare space on the case bottom I kept it easy. This should aid in wiring too as the small slit in the front panel will be where my ribbon cable passes over for the front button PCB's.
For anyone familiar with Mountain Mods cases, I used some of there 120mm FAN/HDD mount plates to act as a HDD mount. Didn't bother with any antivibration on the HDD as my end game in for a SSD in here. Note the old HDD kindly acting as a spacer.
PicoPSU power in cable wasn't long enough to route neatly so stock connector cut, wires extended and a bit of braiding love. Should neatly route under the motherboard and along the back of the case now
In prep for tomorrow I've refilled some low spots on the rear IO area so should be able to sand that flats and give it a coat or two of black - just to tidy it up a little.
__________________
Old 2nd Dec 2011, 14:01   #38
Shuttlemodder
Ultramodder
Looking very tidy!!
Old 2nd Dec 2011, 17:44   #39
peteski
long live the pc
peteski's Avatar
peteski has yet to learn the way of the Dremel
coming along nice mate keep up the good work
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl,
peteski is offline   Reply With Quote
Old 2nd Dec 2011, 18:27   #40
Sheiken
Wat?
Sheiken's Avatar
Sheiken has yet to learn the way of the DremelSheiken has yet to learn the way of the DremelSheiken has yet to learn the way of the Dremel
Looking great! As far as cooling goes, why not mount a couple of rubber feet on the bottom to raise it from whatever it will be sitting on, and then mount a 120mm fan to the bottom? Should create lots of airflow.
__________________
Whoring Out My Hardware 3.2!
Portaputer - Clevo W540EU - 14" / i5 / 8GB / 256gb ssd
H@ck Pro Gigabyte Z77-DS3H / i5 2400/ 8GB DDR3 / vMod Gigabyte GTX 660 OC @ 1200mhz boost / Corsair Carbide 300r / 250GB / 1000GB
Sheiken is online now   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
