Case Mod - In Progress Military PC Build for Raptr.com - Final Pics
Discussion in 'Project Logs' started by Boddaker, 18 Nov 2011.
  1. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Hey everyone,
    This case mod is being built for Raptr.com, for their Battlefield 3/Call of Duty Modern Warfare 3 Showdown. Members vote on which game they think is better, then I will base the theme of this case on which game gets the most votes. :)
    Here are some early conceptual designs I made up, using various cases:
    Around the same time I was building the Level 10GT case mod, and Raptr requested I incorporate some of the features used in that mod into this one. So the minigun was integrated into the design.
    Then Cooler Master came through and provided their new Trooper case, which lent itself well to the theme. So new concepts were drawn up:
    Fortunately, since both games are military styled, I don't have to wait for the outcome to get started. First, I'd like to thank the following sponsors for this project, especially Raptr for giving me this opportunity! :D
    Here are a couple shots of the Trooper case:
    And now we get to the goodies, courtesy Origin PC:
    And finally disassembly of the Trooper case:
    Now to start some actual work! :dremel:
  2. Boddaker
    30 Nov 2006
    First item up for build is the minigun. I'll be doing pretty much the same thing as I did in my Level 10GT mod, but this one will be slightly smaller. So I got some 3/4" acrylic tube, and cut some circles.
    Using my miter saw, I cut the tubes down to 1' lengths.
    Scuffed all parts.
    Starting assembly, fitting the tubes in the holes.
    All rings spaced appropriately.
    And a shot of the minigun in the case for placement.
    I'm thinking it will have to be lowered to accommodate the placement of the optical drive and Lamptron fan controller in the upper bays. The Trooper case features removable drive cages, so there will be plenty of room to work with. :)
  3. NoobNeb
    NoobNeb Enthusiastic Lurker
    14 Nov 2011
    Holy mother of **** that is INSANE :jawdrop: Definetly Battlefield 3 and my favourite design is the Silverstone FT02 :rock::rock::rock:
  4. AoE
    AoE What's a Dremel?
    4 Oct 2011
    awesome, cant wait to see it done
  5. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    I can never get enough of a good thing! So you just keep it up! :thumb:
  6. Cheapskate
    13 May 2007
    Geeze, man! Don't you ever slow down.:hehe:
    Is it too late to add a pintle mount tripod to the design?
  7. peteski
    peteski long live the pc
    8 Jun 2011
    cant wait to see how this one comes out .and love the mini gun :rock: :rock: :rock:
  8. Boddaker
    30 Nov 2006
    Thanks guys!
    Yeah, this has been a real busy year for me. :)
    So where do you propose I add a tripod? Under the whole case, or a smaller version on top, like maybe a dual 50cal sentry turret?
    Quick update!
    Working on the front bezel, making room for a 200mm fan. First thing I had to do was get some components in there and figure out where the minigun will be. This position looked too low, so I removed the lower bay cover and raised the minigun back up a bit.
    Once that was finally established, I could mount the rollers.
    Then it was time to hack off the lower half.
    Then I cut some flat bar and bent them around the minigun and fan to kind of group them together.
    Here's the new frame, pop riveted together.
    My idea is to add some mesh to fill in the areas around both the minigun and fan. But that will have to wait til next time.
  9. Sn00k3r
    Sn00k3r What's a Dremel?
    7 Apr 2011
    i will follow this :cooldude:
  10. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    I see enough reason to start following project logs at Bit-tech again :) Good luck with this.
  11. Cheapskate
    13 May 2007
    :worried: Maybe just some tripod feet under the front to jack the front up...
  12. Angel OD
    16 Sep 2007
    I lol'ed... The 2nd. time!
  13. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Any more work?
  14. Boddaker
    30 Nov 2006
    Yes, I got quite a bit of work done, and I'll be posting a new update very soon. Just been super busy! That, and my place of work recently installed a web filter to keep people from spending too much time on F-book and Y-tube. Unfortunately, it also blocked Bit-tech as a result :wallbash:
    so I can't post my updates during the day anymore, and I've been in the garage modding every night, which leaves little time to get my pics sorted and posted. :sigh:
  15. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    I'll be watching this.
    Like the concepts.
  16. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Mini-gun again? Cool. Always fun to get to do something again. That way you get to use any of those "lessons learned" things. So are you modding in full camo these days and will we need to send in an extraction team to get the crazed modder out of the jungle? :D
  17. Boddaker
    30 Nov 2006
    hehe yeah my wife may need a seal team to "liberate" me from the modding garage. :dremel:
    I don't normally repeat a case mod design, or its elements. I'm keen to always trying something new. But in this case, the customer saw the Level 10GT mod and wanted me to integrate some of those elements into this one. So I obliged with the mini-gun and first aid kit. And because I'm using a different case, it won't be exactly the same thing. :)
  18. Boddaker
    30 Nov 2006
    Ok, finally an update on this! :D
    Continuing on with the front bezel, I cut some mesh to fit inside my aluminum frame.
    I cut it wider than the frame...
    ...then bent the excess down so it would fit.
    Quick test fit on the case with gun. Got to fill the upper corners with something.
    So I cut some pieces from scrap black acrylic.
    Sanded them down and smoothed them out.
    A nice fit.
    Next up was to cut the hole for the 200mm fan into the mesh.
    I liked the Sniper style fan grill from MNPCTech, so I had Bill supersize it to fit the 200mm fan. :)
    Assembled the whole front bezel to see how it looks...
    And with some power to the fan... Sweet!
    I should have another update for you this weekend. 'til then!
  19. Nixjuh
    Nixjuh What's a Dremel?
    11 Dec 2011
    Wow, that really looks nice! :D
    I love how you just cut the case and produce a spare part yourself..
    And it fits wonderfully!
    I will follow this one for sure.
  20. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    If you placed red LED in the tubes at the rear of the barrels and scuffed the paint a little it would look like the barrels have become red hot through use. :)
