#101 |
Resident Bulldozer Guru
What are you using to check the temps? HWmonitor and CoreTemp read temps about twelve degrees too low. Only AMDs' Overdrive appears to pick them up properly. (Thankfully Coretemp will let you Offset them. HWmonitor doesn't, sadly)
I know on the Archon, at 3.8Ghz, I max out at 47 and idle at 22, for a point of reference.
__________________
Dozy Beast: AMD FX8120 | Thermalright Archon | Asus Crosshair V Formula | 16GB (4x4GB) Corsair Vengeance LP | Asus Xonar DX/XD | 2X SLI KFA2 550Ti White Edition | Silverstone SSTG1000W | Silverstone Raven RV-02B V1.7 | OCZ Agility 3 60GB | 1.5TB in Drives | Lite-on Blu-ray ROM Acer H226HQL | Sennheiser HD 485s | Creative Gigaworks T40s | Logitech G13 | Microsoft Sidewinder X6 | Cyborg R.A.T 9 |
#102 |
R E V E N T O N
#103 |
I raise you 300mhz.
http://valid.canardpc.com/show_oc.php?id=2183391 Good job for hitting that on such a low voltage, though! You can see the crazy amount I had to use to achieve that.
__________________
#104 |
R E V E N T O N
#105 |
R E V E N T O N
my paint came in today
![]() ![]() ![]() so did a gift from a very good friend ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#106 |
R E V E N T O N
#107 |
long live the pc
cant wait to see the sleving done
__________________
i5 2500k, asrock z68 extreme 4, corsair 4x2gb 1600mhz,fractal define xl, ![]() |
#108 | |
Minimodder
#109 |
5Ghz on not far off 1.56V, not bad for a Bulldozer, especially considering how much heat these things tend to kick out in relation to the Intel equivilents, I just wish we had Load Line Calibration to play with or similar, just to keep vDroop in check.
I'll have that OC record back soon enough, though.
__________________
#110 |
R E V E N T O N
what do you think? it will be sleeved later.
#111 |
In cornichons I trust.
I'm very impressed : was it hard to change the original tubing of your Corsair H100 And fill it again ? Will you use the original radiator or another one ?
#112 |
Supermodder
Hi Paultan!
If you can keep the tubes together all the way it will look great (even better with sleeving!)Keep it up!
__________________
Latest Project: « «[ Little Angel ]» » (FINISHED!) Sponsors: *** Aquatuning | Atlas Informática | NZXT *** *** ProSilentPC | Seasonic | IzarMicro | E22 *** Follow me on Facebook! |
#113 |
long live the pc
looking good mate keep up the good work
__________________
#114 |
Multimodder
Interested in how you changed the tubing
#115 |
Making You Feel Old Since 2010
Looks like I missed the tubing mod, but it's really cool- well done!
Also, that's a lot of paint- can't wait to see it used! ![]() And once again, great photos, really want to see this stuff sleeveed!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#116 |
I Mod, Therefore I Own
This???
__________________
Big Bird - Arc Midi | 790fx-GD70 | 955BE | 8Gb RAM | 2 x HD4890 | 120Gb SSD | 3.5Tb HDD's | 3 x Dell U2412M
Bert & Ernie - 2 x Linksys NMH405 with 2 x 1Tb HDD's Gonzo - Apple 15" MacBook Pro |
#117 |
Keep calm & mod on. =)
Looking good mate
#118 | |||
R E V E N T O N
it was difficult but my friend helped me.Quote:
![]() just cut the old one and change it using a 1/4 tubing. filling in is the difficult part. Quote:
thanks waynio! thanks to my friend for helping me up
#119 |
Temps look great to me with the modded corsair cooler
![]() nice work . repAnd is that at 5ghz?
#120 |
Loading...
Another Masterpiece for sure! greats photos!
Good luck with the build! |
| Tags |
| batman, coolermaster, dark knight, mod, paultan |
| Thread Tools | |
| View Mode | |
