Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 19th Nov 2011, 13:52   #1
simeonipicker
Multimodder
simeonipicker's Avatar
simeonipicker is almost as Godly as yodasarmpitsimeonipicker is almost as Godly as yodasarmpitsimeonipicker is almost as Godly as yodasarmpitsimeonipicker is almost as Godly as yodasarmpitsimeonipicker is almost as Godly as yodasarmpitsimeonipicker is almost as Godly as yodasarmpitsimeonipicker is almost as Godly as yodasarmpitsimeonipicker is almost as Godly as yodasarmpitsimeonipicker is almost as Godly as yodasarmpitsimeonipicker is almost as Godly as yodasarmpitsimeonipicker is almost as Godly as yodasarmpit
Noctua NH-D14 VS Kuhler H20 920
Hi All,
I'm currently running a NH-D14 in my FT03 case and it's huge! I does a good job of cooling but I was considering moving to the Kuhler as I'd like to see some of my motherboard through the case window.
So, my questions are:
I understand the cooling performance is near identical of these two coolers but sound is very important to me, I like my case to be as quiet as possible and I know the 920 is very loud on max settings.
I'm tempted to change the antec fans for Noctua NF-F12 PWM http://www.youtube.com/watch?feature...&v=cSSI5_lPL7w which should be able to use the chill software from antec.
Does anyone have experiencing of changing fans on this cooler? and what temps and noise level were like?
Thanks in advance
__________________
Noctua'd Silverstone FT03 | Core i7-2600K/NH-D14 | Gigabyte Sniper M3 | 16GB Corsair Vengeance Pro DDR3 | EVGA GeForce GTX 780 SuperClocked ACX | XFX ProSeries 750W Black Edition | 2x NF-R8 PWM/1x NF-S12A FLX | Samsung 840 Pro 512GB SSD
simeonipicker is offline   Reply With Quote
Old 19th Nov 2011, 16:03   #2
Bloody_Pete
Technophile(and yes, thats 724Mb/s)
Bloody_Pete's Avatar
Bloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming Saiyan
From my use of Noctua fans, they're rubbish. Very quiet but little or no performance...
__________________
i5 3570k @ 4.6GHz (1.28v) on custom water loop/ Watercooling how-to, Asus Maximus 5 Gene, 16GB Corsair Vengence 1600MHz (2 black, 2 red), Asus 780 Posiedon Platinium, 512GB Crucial Mx1000, 3 x Samsung F1 1TB in RAID 5, Xigmatek Elysium, Enermax Revolution 85+ 850W, Corsair K60, Corsair SP2500 speakers, Dell U2311H & Asus VK222W.
Bloody_Pete is offline   Reply With Quote
Old 19th Nov 2011, 16:13   #3
lilgoth89
Captin Calliope
lilgoth89's Avatar
lilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyan
i changed them over on my Corsair h70 ( basically the same thing ) and i got better temps and better noise, not used the NF-F12 fans as they are VERY new. i used 2 gentle typhoons that wiped 2 degrees off while being alot quieter ( using a fan controller ) overall ive been very happy with mine
changing fans is easy just 4 long screws and a couple of washers for each fan.
lilgoth89 is offline   Reply With Quote
Old 19th Nov 2011, 16:39   #4
lilgoth89
Captin Calliope
lilgoth89's Avatar
Noctua fans are like marmite...you either love them or you hate them
some people rave about them, and see amazing performance. others dont see any at all
ive seen some good performance from my NF-P12's in my ( old ) antec 900
Old 19th Nov 2011, 17:38   #5
Arghnews
Multimodder
Arghnews has yet to learn the way of the Dremel
I think it's accpeted that NH-D14 is an amazing cooler, off the shelf.
But I also think it's generally accepted that Noctua's fans outside of that tend to be ultra quiet but don't really move much air.
Arghnews is offline   Reply With Quote
Old 19th Nov 2011, 17:44   #6
simeonipicker
Multimodder
Reviews seems to say such different things. Some say that they are quiet and shift a lot of air and low rpms and others say they dont... all very confusing....
I think they are ment to match Gentle Typhoon 1450s for air and noise levels.
__________________
Old 19th Nov 2011, 17:56   #7
SeñorTasty
Minimodder
SeñorTasty's Avatar
SeñorTasty has yet to learn the way of the Dremel
I have the kuhler 920, quite a good cooler imo. Cooling a i5 760 at 3.9, idle temps 24-29 and all cores never exceed 64 c under prime95 all on silent setting (which is whisper quite even with stock fans)
Definitely would recommend but having never used the NH-D14 can't really compare.
SeñorTasty is offline   Reply With Quote
Old 19th Nov 2011, 18:15   #8
Bloody_Pete
I moved from Noctua's to GT 1850's and I dropped 10-15C on my old TRUE, and the noise was barely louder...
__________________
Old 19th Nov 2011, 19:17   #9
Arghnews
Multimodder
Agree with you 100% man. Personally, for XMas, I'm getting 2 typhoons at 1450 for myself And 2 different sites can literally come to 2 completely different conclusions about something, for example -
Bit-tech concludes that the Thermaltake Frio is good at cooling and good value for money
It also concludes the Noctua NH-D14 is overpriced and sub-par at cooling
OC3D, on the other hand, says the opposite, that the Frio is OK, and the D-14 is the god of air cooling. Makes buying stuff really easy and clear cut, right
Old 19th Nov 2011, 19:24   #10
simeonipicker
Multimodder
Well my experience of the nh-d14 is that it's worth it's premium tag. I've been using it with the fans on full pelt and you can't really hear it all. For a test I decided to stick on the ULN adapters that noctua provide which drops the volts so that the fans are inaudible and the temps have litterally risen about 3c max!! Pretty impressed to be honest.
__________________
Old 19th Nov 2011, 19:25   #11
simeonipicker
Multimodder
oh and btw - typhoon 1450s are currently like £8 at aria - http://www.aria.co.uk/SuperSpecials/...ource=googleps
__________________
Old 20th Nov 2011, 14:24   #12
Arghnews
Multimodder
Ah, thanks very much! Was originally buying them for £12 each at scan
And ty for info about the noctua, was planning on buying one of those too
Old 20th Nov 2011, 14:28   #13
Arghnews
Multimodder
PS. Do you think there's a significant advantage in terms of noise with the 1450 over the 1850?
Old 20th Nov 2011, 18:15   #14
simeonipicker
Multimodder
I don't remember where I saw it but it did say that 1450 was the best cfm/db ratio. I think after that it became louder but you could always use down volt or use a fan controller.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
