Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 21st Nov 2011, 12:45   #1
arcticstoat
Hypermodder
arcticstoat's Avatar
arcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysisarcticstoat can run Crysis
Intel LGA2011 CPU gets water-cooled
PC modder Coolmiester builds what we think is the first LGA2011 PC mod, complete with water-cooling.
http://www.bit-tech.net/news/2011/11...modding-comm/1
__________________
Ben Hardwidge
Custom PC Editor
arcticstoat is offline   Reply With Quote
Old 21st Nov 2011, 13:54   #2
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
4.8ghz on that watercooling setup, makes me wonder what temp's they are getting on air when people do that speed on air, unless that is what they wanted as the safe max overclock.
Think I will be waiting for the next stepping before I decide fully if I should get one or not.
Got to say though the mod looks great and well done.
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 21st Nov 2011, 14:43   #3
feathers
Banned
feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.feathers is a hoopy frood who really knows where their towel is.
Just realised these new CPU's are based on 32nm. Lame. So they cost a shitload and the performance isn't wonderful. I will be going with Z68 i5 2500k.
feathers is offline   Reply With Quote
Old 21st Nov 2011, 15:57   #4
Cyberpower-UK
Professional Overclocker
Cyberpower-UK's Avatar
Cyberpower-UK has yet to learn the way of the Dremel
Nice build, how much RAM did you stuff in it?
__________________
Currently Benching: i7 3000s and AMD 8000s
Cyberpower-UK is offline   Reply With Quote
Old 21st Nov 2011, 16:03   #5
gabe777
Minimodder
gabe777 has yet to learn the way of the Dremel
Is it really worth it to get 300 MHz more than the 4.5 easily attainable on air ?
WTF.
gabe777 is offline   Reply With Quote
Old 21st Nov 2011, 16:12   #6
damien c
Mad FPS Gamer
WTF.
You would be surprised when you are looking at using it for video encoding etc where the speed help's quite abit if you are doing allot of encoding.
Not to mention water cooling when done properly look's excellent compared to a great big hoofing HSF.
I am just waiting for the 12 month warranty to run out on the pre overclocked bundle I have in my pc, before I watercool it if I have not upgraded by then simply because I want to increase the overclock which I have done but only from 4.6 to 4.8ghz on air, but with water I know I can take the chip to 5.0ghz plus as it will do it on air now but the temp's are to high for me.
Normally also watercooling is quieter than air cooling, as you can use low rpm fans on the rad's and get lower temp's as well there are benefit's to it but it does cost more.
__________________
Old 21st Nov 2011, 16:20   #7
G0UDG
helping others costs nothing
G0UDG's Avatar
G0UDG is a Super Spamming SaiyanG0UDG is a Super Spamming SaiyanG0UDG is a Super Spamming SaiyanG0UDG is a Super Spamming SaiyanG0UDG is a Super Spamming SaiyanG0UDG is a Super Spamming SaiyanG0UDG is a Super Spamming SaiyanG0UDG is a Super Spamming SaiyanG0UDG is a Super Spamming SaiyanG0UDG is a Super Spamming SaiyanG0UDG is a Super Spamming Saiyan
Well done paul nice build, wish I had the skills to build a proper water cooling loop for my pc I would do it in a flash if i had
__________________
Hard to explain to someone who has no clue. Or doesn't believe you. It's a daily struggle being in pain or feeling sick on the inside while you look fine on the outside. Please put this as your signature for at least 1 hour if you or someone you know has an invisible illness (Pancreatitis, Crohn's, PTSD, Anxiety, Bipolar, Depression, Diabetes, LUPUS, Fibromyalgia, MS,Lupus, ME, Arthritis, Cancer, Heart Disease, Epilepsy, Autism,M.D. Evan Syndrome etc.) " Never judge what you don't understand.
G0UDG is offline   Reply With Quote
Old 22nd Nov 2011, 00:33   #8
kzinti1
Multimodder
kzinti1's Avatar
kzinti1 has yet to learn the way of the Dremel
What people need to be aware of is that these processors aren't worth the money just for gaming. If you're using software that can take advantage of these new cpu's and their extra cores, then fine. That's what they were made for.
NOT gaming! Stick with the i7-2500, 2600 or 2700 K-models for gaming. You'll save money over the way more expensive E-Models. That "E" is for Enterprise, not Enthusiast. You'll save money through using a lot less electricity, (Sandy Bridge E=130 Watts vs. Sandy Bridge K=95 Watts), and also you can use air-cooling or a closed loop watercooler instead of having to invest in a full-loop watercooling system. Even if you can find adapters for present day cpu waterblocks. I looked. EK Waterblocks has them on their site but they cost a fortune for shipping to the U.S. just to get an adapter kit. Not to mention the extreme prices that E-Model motherboards cost.
You'd do better to just wait a few more months or so for IvyBridge.
kzinti1 is offline   Reply With Quote
Old 22nd Nov 2011, 06:22   #9
fluxtatic
Supermodder
fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.
Originally Posted by kzinti1
NOT gaming!
Exactly. Check the benchmarks and OC results - you'll be better off with an i5 2500K or possibly an i7 2600K. For the average enthusiast applications, SB-E is not what you want. If you're looking to build a workstation for massively-threaded software, by all means. But most of the numbers I've seen, you'll get a handful of fps out of the SB-Es, at nearly double or nearly quadruple the cost (of the i5, at least)
It's a new age, people - Intel has blessed y'all with an embarrassment of riches. Just don't go for SB-E unless you need what it actually does, or you need a boost to your e-peen :P
fluxtatic is offline   Reply With Quote
Old 22nd Nov 2011, 10:42   #10
Snips
I can do dat, giz a job
Snips's Avatar
Snips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming Saiyan
Why disrespect the build when it has taken time and money to plan and put together. You don't know what he intends to use the system for so you cannot start bad mouthing him and his build because "it's a waste for Gaming!"
I think the build looks awesome and Coolmiester needs recognition for his excellent work he has done here. Well Done dude!
Snips is offline   Reply With Quote
Old 22nd Nov 2011, 11:00   #11
M7ck
Ⓜod Ⓜaster
M7ck's Avatar
M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.M7ck is a hoopy frood who really knows where their towel is.
This +1000
__________________
M7ck is offline   Reply With Quote
Old 22nd Nov 2011, 11:56   #12
damien c
Mad FPS Gamer
Well I said it's a nice build etc, and was only defending the choice of cooling etc.
The best cpu for gaming is the I7 2500K as the hyperthreading on the 2600K and 2700K in some games will make it perform worse than the 2500K, as I saw when I ran a 2600K and 2500K but it's not allot of difference.
The 6 core's and faster speed will help if you have the software to utilise it but I don't think there is much available, that is cheap enough for the average person to buy.
I like the build and I like the Sandy Bridge E chip's but at the moment I cannot justify the cost of them, but maybe when the next stepping is released they will be worth it for me.
Again really nice and clean build respect to you for that.
__________________
Old 22nd Nov 2011, 12:19   #13
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
Nice & tidy Paul I still think the CPU inbetween the RAM banks looks cool, SB-E not for my kinda usage but for those who it is it's a beast .
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 22nd Nov 2011, 12:28   #14
shaunster1011
Multimodder
shaunster1011 has yet to learn the way of the Dremel
Watercooling isn't only done to keep stuff 'cool', it also looks awesome and you don't have to have a massive piece of metal hanging off your mobo..
__________________
My PC in a desk
shaunster1011 is offline   Reply With Quote
Old 22nd Nov 2011, 19:36   #15
HackJoe
Hypermodder
HackJoe's Avatar
HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.HackJoe is definitely a rep cheat.
Saw this at i44, great build, the cable management is amongst the best I've seen. Well done that man.
J.
HackJoe is offline   Reply With Quote
Old 23rd Nov 2011, 10:41   #16
Margo Baggins
I'm good at Soldering
Moderator
Margo Baggins's Avatar
Margo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming Saiyan
what is this i7 2500k people keep speaking about!?
__________________
My Imgur
Get a Geek Box
i7 3820 4.3ghz - 8GB 2133mhz - GTX 970
keyboards.
Margo Baggins is offline   Reply With Quote
Old 23rd Nov 2011, 10:47   #17
damien c
Mad FPS Gamer
Lol I see what I did my mistake (slaps self in face)
The I5 2500K is what I meant.
__________________
Old 23rd Nov 2011, 19:11   #18
Tom @ CCL
AKA: Yewen
Tom @ CCL's Avatar
Tom @ CCL has yet to learn the way of the DremelTom @ CCL has yet to learn the way of the Dremel
CCL were over the moon to be showing one of Paul's creations on our stand again.
Truly amazing in person and a cut above almost all other mods I have seen, its the last 2% that makes Paul's mods seem like they were an off the shelf case and setup.
Tom @ CCL is offline   Reply With Quote
Old 24th Nov 2011, 04:02   #19
xxxsonic1971
W.O.T xxxsonic1971
xxxsonic1971's Avatar
xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.xxxsonic1971 is definitely a rep cheat.
very nice system mate,well done.
__________________
intel pentium 4 640, 1gb ddr2 @266mhz, radeon x600.
xxxsonic1971 is offline   Reply With Quote
Old 27th Nov 2011, 13:29   #20
[PUNK] crompers
Dremedial
[PUNK] crompers's Avatar
[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.
nicely put together traditional mod, you could almost call it old school!
why are people talking about the failings of SB-E for gaming here? anyone can read the bit-tech review its still on the front page
__________________
| Main Rig | FT02 BW | 2600k @ 4.3Ghz | Sabertooth Z77 | 16GB Corsair Vengance | GTX 1070 @ 2020Mhz | OCZ ARC100 480GB |1TB Samsung F3 | Corsair HX650W | U2711 | Filco Majestouch 2 Tenkeyless | Xonar Essence STX | ProSonus Eris 4.5 monitors |
| HTPC | Lian Li Q11-B | AMD A10 5800k | ASRock FM2A75M-ITX | 8GB XMS3 2000 | 1TB Seagate | SFX 350W |
[PUNK] crompers is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
