#1 |
Technologic
Has anyone bought a HP Micro Server?
Hey all,
Noticed that the £100 cashback offer has extended till the end of Nov. Has anyone got one of these? How do they handle? I want to use it as a media file server, and I currently have all my media sitting on a 1TB HD that I am using in an external caddie. It's £240 before cashback at eBuyer: eBuyer Link Might be just what I need, but like to run it past the wonderful peeps here first!
__________________
BF3 Name: TibbyUK |
#2 |
What the?
Loads of us have one and think its great, including me! If you want to upgrade the RAM it works fine with non ECC memory.
#3 |
Hypermodder
Couldn't recommend them more highly, fantastic pieces of kit not to mention the price, just recieved my £100 cash back cheque at the end of last week (which took a while) but very pleased with it overall.
__________________
Core i7 860@4.2GHz // MSI P55-GD80 // 8GB G.Skill Ripjaws@1600Mhz C8 // EVGA GTX 680
OCZ Vertex 2 120GB // WD Green 2TB // Seasonic X-760 // 600T // BenQ XL2420T // HD 595's Magicool 360 + Phobya 200 Rads // MCP655 // Heatkiller 3.0 LT // EK FC-480 |
#4 |
Technologic
Sweet. Thanks all!
__________________
BF3 Name: TibbyUK |
#5 |
Total Noob
It's a nice machine. Pics and paragraph about it > http://mcompute.co.uk/showthread.php?tid=1129
I'm running FreeNAS on mine.
__________________
#6 |
Technologic
Just for reference, is it just a case of sending the invoice in the package to them?
__________________
BF3 Name: TibbyUK |
#7 |
I *am* the guy with two left hands
Yes, it is fine for the price. Even when i paid 240 euros for it (1 euro for 250GB hard drive, 1 euro for Windows Server 2008 Foundation, the rest for the Microserver N40 version with the DVD drive).
I disliked the fan noise a bit, but modifying any PWM fan for microserver is not hard at all : http://www.silentpcreview.com/article1193-page7.html In short - you take out all the pins, move the last one to the first and move every other by one pin. Did it easily with my Enermax Cluster. One thing to keep in mind - 550RPM is probably the minimum acceptable fan speed for Microserver if you are thinking about swapping the fan.
__________________
Cerberus Core i7-2600K Asus P8Z77-I Deluxe GSkill RipjawsX 2x8GB DDR3-1600CL9 watercooled EVGA GTX670 Samsung 830 256GB Bitfenix Prodigy Seasonic X-460 Windows 8 Pro Prometheus Xeon E3-1235 Asus P8B WS GSkill RipjawsX 2x4GB DDR3-1333CL7+2x8GB DDR3-1333CL9 Coolink Corator DS Force 3 240GB+4xWD30EFRX+2xWD20EARS+6xWD20EARX Nanoxia DS1 Seasonic X-460 Ubuntu 12.04 |
#8 |
Hypermodder
Ebuyer didn't include an invoice for me but it was just a case of printing one of the website that included the VAT no I think it was as well as a picture of the product page on the ebuyer website then sending that lot to HP, received my check after about 43 days.
__________________
#9 |
Ultramodder
What OS are people running on these? I'm tempted to get one as a backup NAS for work, can I run free NAS or something similar on it? are the drives hot swappable?
#10 | |
Total Noob
__________________
#11 |
Considered for President!! Moi??
I must say, i'm more and more tempted by one of these.
Sam
__________________
The Laptop: Dell Vostro 3450, SB i3 2350m, 8GB DDR3, 256GB 830 SSD, Intel 6235 Wifi N/BT 4.0, Dell 5550 3G/GPS The Server: Phenom 2 x6, 8GB DDR3, 3TB Seagate, 2TB WD Green, 2*1TB Samsung F1 |
#13 |
Total Noob
One of the main advantages SATA has over IDE is the native hot swapping. I've pulled a drive and degraded my RAID array in this thing, popped it back in and it re-build fine mwuahha!
__________________
#14 | |
This is the hot plug drive from HP: http://web.tradekorea.com/upload_fil...432341_B21.jpg Non-hot plug = bracket + screws + standard drive. It doesn't change the fact, that the port itself is hotplug - but the tray for drives is not the "HP Hot Plug" compatible. Hope it makes sense .
__________________
#15 |
Minimodder
All SATA is electrically hotswappable (i.e. you won't fry anything) but it's only actually hotswappable if the bios/sata controller bios can handle it. The microserver cannot, you have to reboot for the drive to show up unless it is the same model/same drive that was on that port before.
I have 3 Microservers, love them. Put 8 2tb drives in two, the third is my main pc while I upgrade. It even runs battlefield play4free! All you need is a usb sound card and it's a great desktop. Great as a NAS, cheaper than an actual NAS yet faster, more flexible. Very good build quality, reasonably quiet. The only down-side is the half-height expansion slots, and it can't quite handle 1080p (720 is fine). |
#16 |
Ultramodder
I love mine, got it running 4x2tb drives, and blueray drive and a boot ssd and 8gb of ram with a gt250, its a fantastic media server!
__________________
Main Rig: i7 D0 920 - Gigabyte X58A-UD7 - Ati HD 4890 - 6GB Dominator PC1600 RAM - 1x Intel 80GB SSD - 1x Samsung F2 1TB - LG CH08LS10 Blu Ray Burner - Samsung 2433 TFT |
#17 |
Just a small followup to my 4-pin PWM fan modification - there is one even better and easier choice (tested today). Grab a 3-pin fan extension and remove the guides on the end which goes to the motherboard. Put it on the first 3 pins of the HP microserver fan connector, so you will keep the one which is most deep in the case without connection. That is the control pin, we don't need that. The remaining pins lined up exactly as 3-pin fans need, so once you connected the 3-pin fan extension cable, you are free to connect a 3-pin fan or fan speed regulator on the other end of the extension cable. The only limit you will have is that your fan can't go slower than 550RPM. This way you will ignore the built in fan speed regulation, you can have fixed fan speed, which is often a better choice for noise.
__________________
#18 |
Ultramodder
I bought one last week, still haven't got it out the box yet....
#19 |
Is the daddy!
get it out the box asap, i love mine to bits.
Combined with a low profile nvidia G210 and a blu-ray drive it makes an awesome HTPC. The Neo CPU is bloody good for such a low clock speed it surprised the hell out of me, makes an atom look silly
__________________
Project log Mocha70 Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2 Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
#20 |
Of reasonable knowledge...
Hi folks,
This looks ideal for my needs. I use a NAS to stream media content to my hifi and WDTV Live, as well as a backup for photos and documents; currently I use Asset uPnP for the audio streaming and TwonkyMedia 6 for video. Does anyone know if this product will support these media server applications? Also, could I connect a printer to this so that any networked computers in my house could print? Still available with £100 cashback by the way... Cleggy.
__________________
Pooting: Antec 300, P6T SE, i7 920 (3.20), Corsair F120SSD, 3x1TB HDD, 9Gb (1600XMP), GTX560Ti 2Gb (880/1760/2100), Win7 x64. Grooving: Linn LP12, Klimax DS, Klimax Kontrol, Aktiv Akurate x 10 with Aktiv 242's. Watching: WDTV Live to 50" Panasonic. Serving: HP Proliant Microserver N40L running Openmediavault. |
| Thread Tools | |
